USB Mass storage class
HI,
I am trying to write some local files on internal FAT on spi flash - which works.
now i will enable_usb_device_next()   (like the MSC example -- using the next usb stack)
But i want the fat fs to be mounted as Read only
i have tried some flags (FS_MOUNT_FLAG_READ_ONLY | FS_MOUNT_FLAG_NO_FORMAT)
before enable_usb_device_next() - but it does not work.
So i wonder if there is no support for a read only usb mass storage device on?
    I have not tested this.
    How does it not work? Does it build? Does some API return an error? Or are you still able to write to it?
    Edvin
  • local i can update file on fat from zephyr - when i "enable_usb_device_next()" and cable connected to my labtop (usb host) -
    a drive can be seen i can write and files from PC - so in general MSC do work.
    But i do NOT want the PC the write files to FAT drive. - what should i do to achieve this -
    i hope there is a setting so the whole fat dist can be set as  read only on runtime - any guidance will be very helpfull.
