I am working on specialized PCB's for my job, and we are trying to capture modem traces for our devices. Via JTag, I have serial access to pins P0.05 (TX) and P0.06 (RX) of the nRF9160. The JTag and any other connectors are NOT the issue. It is my understanding that CONFIG_NRF_MODEM_LIB)TRACE enables UART1 automatically, so I don't set the state to "okay".
After uploading a custom SLM to my device, I open Cellular Monitor and begin a modem trace.
I can see the Green Check Mark next to the text "Trace".
However, the only packets I ever see are startup packets. These show up every time I press Connected Devices > Reset Board in VS Code.
I am not sure what I am doing wrong, and would appreciate some assistance with configuring the project. I will include my configs below:
VERSIONS:
NCS: 2.4.2
MFW: 1.3.6
nrf9160dk_nrf9160_ns.overlay:
* Copyright (c) 2021 Nordic Semiconductor ASA
chosen {
nordic,modem-trace-uart = &uart1;
chosen {
ncs,slm-uart = &uart0;
&uart0 {
status = "okay";
hw-flow-control;
pinctrl-0 = <&uart0_default_alt>;
pinctrl-1 = <&uart0_sleep_alt>;
&pinctrl {
uart0_default_alt: uart0_default_alt {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 29)>,
<NRF_PSEL(UART_RX, 0, 28)>,
<NRF_PSEL(UART_RTS, 0, 2)>,
<NRF_PSEL(UART_CTS, 0, 3)>;
uart0_sleep_alt: uart0_sleep_alt {
group1 {
low-power-enable;
&uart1 {
current-speed = <1000000>;
pinctrl-0 = <&uart1_alt>;
pinctrl-1 = <&uart1_sleep_alt>;
&pinctrl {
uart1_alt: uart1_alt {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 5)>,
<NRF_PSEL(UART_RX, 0, 6)>;
uart1_sleep_alt: uart1_sleep_alt {
group1 {
low-power-enable;
&uart2 {
current-speed = <115200>;
status = "disabled";
hw-flow-control;
pinctrl-0 = <&uart2_default_alt>;
pinctrl-1 = <&uart2_sleep_alt>;
&i2c2 {
&pinctrl {
uart2_default_alt: uart2_default_alt {
group1 {
psels = <NRF_PSEL(UART_RX, 0, 11)>;
bias-pull-up;
group2 {
psels = <NRF_PSEL(UART_TX, 0, 10)>,
<NRF_PSEL(UART_RTS, 0, 12)>,
<NRF_PSEL(UART_CTS, 0, 13)>;
uart2_sleep_alt: uart2_sleep_alt {
group1 {
<NRF_PSEL(UART_RX, 0, 11)>,
low-power-enable;
&interface_to_nrf52840 {
gpio-map = <0 0 &gpio0 17 0>,
<1 0 &gpio0 18 0>,
<2 0 &gpio0 19 0>,
<3 0 &gpio0 21 0>,
<4 0 &gpio0 22 0>,
<5 0 &gpio0 23 0>;
&pwm0 {
/delete-node/ &{/pin-controller/spi3_default/group1/};
/delete-node/ &{/pin-controller/spi3_sleep/group1/};
///delete-node/ &{/leds/};
prj.conf:
# Copyright (c) 2020 Nordic Semiconductor ASA
# General config
# Added by DWHITE for modem trace
CONFIG_AT_HOST_LIBRARY=y
CONFIG_NRF_MODEM_LIB_TRACE=y
CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_UART=y
CONFIG_UART_ASYNC_API=y
CONFIG_SERIAL=y
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_STACK_SENTINEL=y
CONFIG_NEWLIB_LIBC=y
CONFIG_RING_BUFFER=y
# Segger RTT
CONFIG_USE_SEGGER_RTT=n
CONFIG_RTT_CONSOLE=n
CONFIG_UART_CONSOLE=y
CONFIG_LOG_BACKEND_RTT=n
CONFIG_LOG_BACKEND_UART=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_NATIVE=n
# Modem library
CONFIG_NRF_MODEM_LIB=y
# Align the max FD entry to NRF_MODEM_MAX_SOCKET_COUNT(8)
CONFIG_POSIX_MAX_FDS=8
# Enable below for modem trace
# Handle modem fault
CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC=y
# Use GPIO
CONFIG_GPIO=y
CONFIG_GPIO_NRFX=y
# UART interface
CONFIG_SERIAL=y
CONFIG_NRFX_TIMER2=y
# Stacks and heaps
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_AT_MONITOR_HEAP_SIZE=4096
# Device power management
CONFIG_PM_DEVICE=y
# FOTA
CONFIG_HTTP_PARSER_URL=y
CONFIG_FOTA_DOWNLOAD=y
CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
CONFIG_DFU_TARGET=y
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_IMG_MANAGER=y
# FLASH
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_STREAM_FLASH=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# Settings
CONFIG_SETTINGS=y
CONFIG_SETTINGS_FCB=y
CONFIG_FCB=y
# nRF Cloud
#CONFIG_NRF_CLOUD_IPV6=y
CONFIG_NRF_CLOUD_MQTT=y
CONFIG_NRF_CLOUD_FOTA=n
CONFIG_NRF_CLOUD_AGPS=y
CONFIG_NRF_CLOUD_AGPS_FILTERED=n
CONFIG_NRF_CLOUD_PGPS=y
CONFIG_NRF_CLOUD_LOCATION=y
CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_INF=y
CONFIG_DATE_TIME=y
CONFIG_MODEM_INFO=y
CONFIG_MODEM_INFO_ADD_DATE_TIME=n
CONFIG_AT_MONITOR=y
CONFIG_MODEM_JWT=y
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_INTERNAL_UUID=y
# SLM-specific configurations
CONFIG_SLM_CUSTOMIZED=n
CONFIG_SLM_LOG_LEVEL_INF=y
CONFIG_SLM_EXTERNAL_XTAL=n
CONFIG_SLM_START_SLEEP=n
CONFIG_SLM_DATAMODE_URC=n
# nRF Cloud based location services
CONFIG_SLM_AGPS=n
CONFIG_SLM_PGPS=n
CONFIG_SLM_LOCATION=n
# Serial DFU support
CONFIG_SLM_NRF52_DFU=n
CONFIG_SLM_NRF52_DFU_LEGACY=n
# Added by ## #####
CONFIG_SLM_WAKEUP_PIN=0
CONFIG_SLM_INDICATE_PIN=1
# Carrier Setup from ###
CONFIG_LWM2M_CARRIER=y
#CONFIG_LWM2M_CARRIER_CUSTOM_URI="#################"
CONFIG_LWM2M_CARRIER_IS_BOOTSTRAP_SERVER=y
CONFIG_LWM2M_CARRIER_VERIZON=y
CONFIG_LWM2M_CARRIER_ATT=n
CONFIG_LWM2M_CARRIER_LG_UPLUS=n
CONFIG_LWM2M_CARRIER_T_MOBILE=n
CONFIG_LWM2M_CARRIER_GENERIC=n
CONFIG_LWM2M_CARRIER_SOFTBANK=n
Edit: included modem FW version and NCS version, updated Baud rate to match correct build
