I am trying to measure the battery voltage on my custom board which is based on the nRF52832 device. I am using nRF Connect SDK 2.7.0 in VS Code. The dts file for this custom board contains (among other things that aren't germane to this question):
model = "rwe_152001_01_nrf52832";
compatible = "rwe,rwe_152001_01_nrf52832";
zephyr,user {
io-channels = <&adc 7>; // Use channel 0 for VDD measurement
&adc {
status = "okay";
My code is as follows and I have tried various channels (0, 4, and 7 at the 'suggestion" of Copilot), but I keep getting " <err> adc_nrfx_saadc: Channel 7 not configured
ADC read failed: -22" in the console. I think I am close but I just can't seem to figure it out. Please forgive my newbiness.
#pragma GCC diagnostic ignored "-Wmain"
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/adc.h>
#include <zephyr/devicetree/io-channels.h>
#include <stdio.h>
#define ADC_RESOLUTION 10
#define ADC_GAIN ADC_GAIN_1_6
#define ADC_REFERENCE ADC_REF_INTERNAL
#define ADC_ACQUISITION_TIME ADC_ACQ_TIME_DEFAULT
static const struct adc_dt_spec adc_spec = ADC_DT_SPEC_GET_BY_IDX(DT_PATH(zephyr_user), 0);
static int16_t sample_buffer;
void main(void)
int err;
printk("a\n");
if (!device_is_ready(adc_spec.dev))
printk("ADC device not found\n");
return;
printk("b\n");
struct adc_channel_cfg channel_cfg = {
.gain = ADC_GAIN,
.reference = ADC_REFERENCE,
.acquisition_time = ADC_ACQ_TIME_DEFAULT,
.channel_id = adc_spec.channel_id,
err = adc_channel_setup(adc_spec.dev, &channel_cfg);
printk("c\n");
if (err)
printk("ADC channel setup failed: %d\n", err);
return;
const struct adc_sequence sequence = {
.channels = BIT(adc_spec.channel_id),
.buffer = &sample_buffer,
.buffer_size = sizeof(sample_buffer),
.resolution = ADC_RESOLUTION,
while (1)
err = adc_read(adc_spec.dev, &sequence);
if (err)
printk("ADC read failed: %d\n", err);
// Convert the raw sample to voltage
//float voltage = (sample_buffer * 3.6) / 1024; // Assuming 3.6V reference and 10-bit resolution
//char voltage_str;
printk("ADC sample: %d\n", sample_buffer);
k_sleep(K_MSEC(1000));
