broadcast_sink and broadcast_source simultaneously.
hi:
I am use broadcast_sink and broadcast_source of nrf5340_audio simultaneously.
use a button to switch source or sink. i am use NCS v2.6.2
if switch to sink mode is show below.
<wrn> broadcast_sink: Unable to sync to broadcast source, ret: -12
it can help me or support sample code.
                                                     thank
HL [00:00:12.831,207] <dbg> broadcast_sink: base_recv_cb: Subgroup: 0 BIS: 0 index = 1
HL [00:00:12.831,237] <dbg> broadcast_sink: get_codec_info: Retrieve the codec configuration for LC3
HL [00:00:12.831,237] <dbg> broadcast_sink: base_recv_cb: Stream 0 in subgroup 0 from broadcast sink
HL [00:00:12.831,268] <dbg> broadcast_sink: base_recv_cb: Subgroup: 0 BIS: 1 index = 2
HL [00:00:12.831,268] <dbg> broadcast_sink: get_codec_info: Retrieve the codec configuration for LC3
HL [00:00:12.831,298] <dbg> broadcast_sink: base_recv_cb: Stream 1 in subgroup 0 from broadcast sink
HL [00:00:12.831,359] <dbg> broadcast_sink: base_recv_cb: Channel HL active
HL [00:00:12.831,359] <dbg> broadcast_sink: base_recv_cb: Waiting for syncable
HL [00:00:12.831,451] <dbg> broadcast_sink: syncable_cb: Broadcast sink is syncable
HL [00:00:12.831,451] <inf> broadcast_sink: Syncing to broadcast stream index 0
HL [00:00:12.831,481] <wrn> broadcast_sink: Unable to sync to broadcast source, ret: -12
HL [00:00:12.831,573] <inf> main: Presentation delay 20000 us is set
HL [00:00:13.231,201] <dbg> broadcast_sink: base_recv_cb: Received BASE with 1 subgroup(s) from broadcast sink
LOG_DBG("nRF5340 BPT APP core started");
ret = nrf5340_audio_dk_init();
ERR_CHK(ret);
ret = nrf5340_audio_common_init();
ERR_CHK(ret);
ret = zbus_subscribers_create();
ERR_CHK_MSG(ret, "Failed to create zbus subscriber threads");
ret = zbus_link_producers_observers();
ERR_CHK_MSG(ret, "Failed to link zbus producers and observers");
ret = broadcast_source_enable();
ERR_CHK_MSG(ret, "Failed to enable broadcaster");
ret = audio_system_config_set(
bt_audio_codec_cfg_freq_to_freq_hz(CONFIG_BT_AUDIO_PREF_SAMPLE_RATE_VALUE),
CONFIG_BT_AUDIO_BITRATE_BROADCAST_SRC, VALUE_NOT_SET);
ERR_CHK_MSG(ret, "Failed to set sample- and bitrate");
broadcast_source_adv_get(&ext_adv, &ext_adv_size, &per_adv, &per_adv_size);
ret = bt_mgmt_adv_start(ext_adv, ext_adv_size, per_adv, per_adv_size, false);
ERR_CHK_MSG(ret, "Failed to start advertiser");
ret = le_audio_rx_init();
ERR_CHK_MSG(ret, "Failed to initialize rx path");
case BUTTON_5:
bt_le_ext_adv_stop(ext_adv);
broadcast_source_stop();
k_msleep(100);
ret = broadcast_sink_enable(le_audio_rx_data_handler);
ret = bt_mgmt_scan_start(0, 0, BT_MGMT_SCAN_TYPE_BROADCAST,
CONFIG_BT_AUDIO_BROADCAST_NAME,
BRDCAST_ID_NOT_USED);
    Are you saying that you have two DKs, with one being a broadcast sink and one being a broadcast source?
    Or do you have both configurations running on the same board, and if so, I am not sure I understand what source you want to sync to?
    Elfving
  • hello,
    I have two DKs, with  being all broadcast source.
    one DK use button switch form source to sink. (broadcast source off,broadcast sink on)
    The sink is show
    I see. -12 means ENOMEM; it is out of memory. It might be interesting to debug it, to figure out exactly where this warning is coming from.
    Are you running into the same issue when just having a source and a sink, and running the default test suggested here?
    Elfving
  • 1.
    -12 means ENOMEM;-->
    it's return from
    ../ncs/v2.6.2/zephyr/subsys/bluetooth/audio/bap_broadcast_sink.c
     static int bt_bap_broadcast_sink_setup_stream(struct     bt_bap_broadcast_sink *sink,
                              struct bt_bap_stream *stream,
                              struct bt_audio_codec_cfg *codec_cfg)
        struct bt_bap_iso *iso;
        struct bt_bap_ep *ep;
        if (stream->group != NULL) {
            LOG_DBG("Stream %p already in group %p", stream, stream->group);
            return -EALREADY;
        ep = broadcast_sink_new_ep(sink->index);
        if (ep == NULL) {
            LOG_DBG("Could not allocate new broadcast endpoint");
            return -ENOMEM;
        iso = bt_bap_iso_new();
        if (iso == NULL) {
            LOG_DBG("Could not allocate iso");
            return -ENOMEM;
    2.
    Are you running into the same issue when just having a source and a sink, and running the default test suggested here?-->
    it's sync ok and audio out.
    3.
    if run broadcast_source_disable() that sink  is sync ok audio out,But then executing broadcast_source_enable() returns a failure.
  • Sorry about the wait, I have been OOO for a few days.
        if (ep == NULL) {
            return -ENOMEM;
        if (iso == NULL) {
            return -ENOMEM;
    Could you check which of these two the error is coming from?
    So if I am understanding you correctly, you are not only getting this issue when you disable source and enable sink, but you also get this when you try to disable source and and then re-enable it?
    Elfving
