MBEDTLS time/date support with nRF Security
Is MBEDTLS date/time is not supported in nRF security ?
warning: MBEDTLS_HAVE_TIME_DATE (defined at modules/mbedtls/Kconfig.tls-generic:458,
modules/mbedtls/Kconfig.tls-generic:458) was assigned the value 'y' but got the value 'n'. Check
these unsatisfied dependencies: ((MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" &&
MBEDTLS) || (MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS && 0)) (=n).
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_HAVE_TIME_DATE and/or look up
MBEDTLS_HAVE_TIME_DATE in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
We would like to have certificate validity check, but unable to enable it.
    Can you provide information about your application?
    Can you provide complete build log and your project configuration?
    Dejan
  • This is a generic issue with nRF SDK, not tied to an application.
    I am using v2.7.0 SDK.
    For e.g. you can try building "aws_iot_mqtt" example on nRF7002DK. See the build log for the same below.
    Building aws_iot_mqtt
    west build --build-dir /home/vscode/workspaces/base-station-application/aws_iot_mqtt/build /home/vscode/workspaces/base-station-application/aws_iot_mqtt --pristine --board nrf7002dk/nrf5340/cpuapp/ns -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/home/vscode/workspaces/base-station-application
    -- Application: /home/vscode/workspaces/base-station-application/aws_iot_mqtt
    -- CMake version: 3.30.2
    -- Found Python3: /usr/bin/python3 (found suitable version "3.10.12", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: /home/vscode/workspaces/.cache/zephyr
    -- Zephyr version: 3.6.99 (/home/vscode/workspaces/external_dependencies/zephyr)
    -- Board: nrf7002dk, qualifiers: nrf5340/cpuapp/ns
    -- Found host-tools: zephyr 0.16.5 (/home/vscode/workspaces/external_dependencies/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.5 (/home/vscode/workspaces/external_dependencies/zephyr-sdk)
    -- Found Dtc: /usr/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/vscode/workspaces/external_dependencies/nrf/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_ns.dts
    -- Generated zephyr.dts: /home/vscode/workspaces/base-station-application/aws_iot_mqtt/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /home/vscode/workspaces/base-station-application/aws_iot_mqtt/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /home/vscode/workspaces/base-station-application/aws_iot_mqtt/build/zephyr/dts.cmake
    warning: MBEDTLS_MEMORY_DEBUG (defined at
    /home/vscode/workspaces/external_dependencies/nrf/subsys/nrf_security/Kconfig.tls:167,
    modules/mbedtls/Kconfig:166, modules/mbedtls/Kconfig:166) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: ((MBEDTLS_TLS_LIBRARY && NRF_SECURITY) ||
    (MBEDTLS_BUILTIN && MBEDTLS) || (MBEDTLS_BUILTIN && MBEDTLS && 0)) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_MEMORY_DEBUG and/or look up
    MBEDTLS_MEMORY_DEBUG in the menuconfig/guiconfig interface. The Application Development Primer,
    helpful too.
    warning: MBEDTLS_AES_ROM_TABLES (defined at
    /home/vscode/workspaces/external_dependencies/nrf/subsys/nrf_security/Kconfig.legacy:417,
    modules/mbedtls/Kconfig.tls-generic:261, modules/mbedtls/Kconfig.tls-generic:261) was assigned the
    value 'y' but got the value 'n'. Check these unsatisfied dependencies: ((!(OBERON_BACKEND ||
    CC3XX_BACKEND) && MBEDTLS_CIPHER_MODE_CBC && MBEDTLS_AES_C && MBEDTLS_LEGACY_CRYPTO_C &&
    NRF_SECURITY) || (MBEDTLS_CIPHER_AES_ENABLED && !(NRF_SECURITY || NORDIC_SECURITY_BACKEND) &&
    MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS) ||
    (MBEDTLS_CIPHER_AES_ENABLED && !(NRF_SECURITY || NORDIC_SECURITY_BACKEND) && MBEDTLS_BUILTIN &&
    MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS && 0)) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_AES_ROM_TABLES and/or look up
    MBEDTLS_AES_ROM_TABLES in the menuconfig/guiconfig interface. The Application Development Primer,
    helpful too.
    warning: MBEDTLS_SSL_ALPN (defined at modules/mbedtls/Kconfig.tls-generic:44,
    modules/mbedtls/Kconfig.tls-generic:44) was assigned the value 'y' but got the value 'n'. Check
    these unsatisfied dependencies: (((MBEDTLS_TLS_VERSION_1_0 || MBEDTLS_TLS_VERSION_1_1 ||
    MBEDTLS_TLS_VERSION_1_2) && MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS)
    || ((MBEDTLS_TLS_VERSION_1_0 || MBEDTLS_TLS_VERSION_1_1 || MBEDTLS_TLS_VERSION_1_2) &&
    MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS && 0)) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SSL_ALPN and/or look up
    MBEDTLS_SSL_ALPN in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    warning: MBEDTLS_PEM_CERTIFICATE_FORMAT (defined at modules/mbedtls/Kconfig.tls-generic:401,
    modules/mbedtls/Kconfig.tls-generic:401) was assigned the value 'y' but got the value 'n'. Check
    See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT and/or
    look up MBEDTLS_PEM_CERTIFICATE_FORMAT in the menuconfig/guiconfig interface. The Application
    Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
    the manual might be helpful too.
    warning: MBEDTLS_SERVER_NAME_INDICATION (defined at modules/mbedtls/Kconfig.tls-generic:446,
    modules/mbedtls/Kconfig.tls-generic:446) was assigned the value 'y' but got the value 'n'. Check
    See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SERVER_NAME_INDICATION and/or
    look up MBEDTLS_SERVER_NAME_INDICATION in the menuconfig/guiconfig interface. The Application
    helpful too.
    warning: MBEDTLS_SSL_MAX_CONTENT_LEN (defined at modules/mbedtls/Kconfig:73,
    modules/mbedtls/Kconfig:73) was assigned the value '16384' but got the value ''. Check these
    unsatisfied dependencies: ((MBEDTLS_BUILTIN && MBEDTLS) || (MBEDTLS_BUILTIN && MBEDTLS && 0)) (=n).
    See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN and/or look
    up MBEDTLS_SSL_MAX_CONTENT_LEN in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    warning: The choice symbol MBEDTLS_BUILTIN (defined at modules/mbedtls/Kconfig:30,
    modules/mbedtls/Kconfig:30) was selected (set =y), but MBEDTLS_LIBRARY_NRF_SECURITY (defined at
    /home/vscode/workspaces/external_dependencies/nrf/subsys/nrf_security/Kconfig:293) ended up as the
    choice selection. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_BUILTIN
    and/or look up MBEDTLS_BUILTIN in the menuconfig/guiconfig interface. The Application Development
    In the warning we can clearly see that MBEDTLS_HAVE_TIME_DATE is not being used.
    PSA Crypto does not support TIME_DATE. For now, legacy option must be used.
    Dejan
  • Does it mean that it is not possible to check expiry of certificates ?
    Could you provide information on how your project acquires time and how time is kept synchronized?
    Dejan
