Bluetooth OTA fails: iOS DFU Library complains that Image 0 (slot 1) is already pending
We are suddenly getting lots of cases where devices aren't able to perform Bluetooth OTA via our iOS app.
Primarily this is what we are seeing is this: `error=There is no free slot to place the image`.
First we start the update:
This is what the image list response right before this looks like:
dfu: Image List response:
  Header:
    version   : "1"
    op        : 1
    flags     : 0
    length    : 248
    group     : 1
    seqNum    : 60
    commandId : 0
  Payload:
    images:
      - bootable  : true
        hash      : 0xAA00383B0829FA8BA63CC09BD126D7CBEF866D9A8DD8C9BFD176EE13A8FDAAA6
        active    : true
        permanent : false
        slot      : 0
        version   : "0.0.101"
        confirmed : true
        pending   : false
      - version   : "0.0.103"
        hash      : 0xA576F7F8B294DA3A26979D8846E0D2CCE6454370F8A57B0E9C7053EDD5526884
        active    : false
        slot      : 1
        pending   : true
        permanent : false
        bootable  : true
        confirmed : false
    splitStatus : 0
The library throws this error:
We also see `dfu: Image 0 (slot 1) is already pending.`
but proceeds to upload image. Device then restarts upon upload completion but seems to restart on the old firmware, showing the same image list. A further update attempt throws this error:
dfu: There is no free slot to place the image
and stops the update.
We use a `testOnly` strategy (not testAndConfirm) from the library so that we confirm the image in the app. This was working quite fun for a few months until now.
We see this commit which attempted to fix a similar issue but it seems like it did not resolve this specific case. Also saw this devzone ticket but we didn't make any changes to pm_static.yml and how the secondary slot is allocated.
We also tried force testing the image stuck in secondary slot using `mcumgr` with no luck.
  • Some additional logs from an OTA attempt that might be helpful:
    🟡 dfu: Secondary slot of image 0 is already confirmed
    🔵 dfu: Scheduling upload (hash: 0x5E5E75DFCF8A4E6FE6F069C533CA05875DE75A7452B942357F88F6BD5F6F69BF) for image 0 (slot: 1)
    🔵 Upgrade state moved from validate to upload
    🔵 dfu: Image Confirm response: Header: {"version": "1", "op": "3", "flags": 0, "length": 248, "group": 1, "seqNum": 167, "commandId": 0}, Payload: {"images" : {{"bootable" : true, "active" : true, "confirmed" : false, "permanent" : false, "slot" : 0, "pending" : false, "hash" : 0x024A54FAE4A4831EEFEAF04D6051BEE67332AEB05DA19B59E1116911BAD8F043, "version" : "0.0.111"}, {"pending" : false, "confirmed" : true, "version" : "0.0.108", "hash" : 0x056578B127AA68892BE5092D00DEC162E132490C49000BE5E62026F8EC26A51C, "permanent" : false, "bootable" : true, "slot" : 1, "active" : false}}, "splitStatus" : 0}
    🔵 dfu: Image List response: Header: {"version": "1", "op": "3", "flags": 0, "length": 248, "group": 1, "seqNum": 167, "commandId": 0}, Payload: {"images" : {{"bootable" : true, "active" : true, "confirmed" : false, "permanent" : false, "slot" : 0, "pending" : false, "hash" : 0x024A54FAE4A4831EEFEAF04D6051BEE67332AEB05DA19B59E1116911BAD8F043, "version" : "0.0.111"}, {"pending" : false, "confirmed" : true, "version" : "0.0.108", "hash" : 0x056578B127AA68892BE5092D00DEC162E132490C49000BE5E62026F8EC26A51C, "permanent" : false, "bootable" : true, "slot" : 1, "active" : false}}, "splitStatus" : 0}
    🟡 image: An image upload is already in progress
    🔴 dfu: There is no free slot to place the image
    🔴 image: Upload cancelled due to error: groupCode(iOSMcuManagerLibrary.McuMgrGroupReturnCode)
    🟡 Firmware update failed
  • What's crazy is `mcumgr` only shows one image despite the iOS library showing two:
    mcumgr -c acm0 -t 120 image list
    Images:
     image=0 slot=1
        version: 0.0.108
        bootable: true
        flags:
        hash: 056578b127aa68892be5092d00dec162e132490c49000be5e62026f8ec26a51c
    Split status: N/A (0)
    Thanks for sharing the complete log. I assume you are working with the nRF5340. Is this a custom board or a development kit? If it is a custom board, were you able to see the same issue on a development kit? Have you tried using the nRF Connect mobile application, and if so, are you experiencing a similar issue? I may need to report this internally, but first, please let me know if this is reproducible on a development kit.
    Kind Regards,
    Abhijith
