nRF5340 with internal load caps for 32M XTAL
The target MCU on nRF5340 DK seems to use internal load caps for the high frequency 32MHz XTAL because the board does not have external load caps.
The nRF5340 specification sheet mentions that the internal caps must be configured before enabling them.
Does it mean that every sample application configures this on the nRF5340?
When I load the "blinky" example, I see the following in the Output .config
1. In what config file is this configured and what are the default values?
2. What is the default startup clock of the SoC? Since the internal caps for the crystal must be configured first, I imagine the SoC must use another clock source before the external XTAL is enabled.
    You configure this with CONFIG_SOC_HFXO_CAP_INTERNAL=y and CONFIG_SOC_HFXO_CAP_INT_VALUE_X2 set to the value you want, as described in this thread.
    The default startup clock is the internal RC oscillator.
    After setting the prj.conf
    CONFIG_SOC_HFXO_CAP_INT_VALUE_X2=24
    Since C1/C2=12pF
    How to enable HFXO?
    Thank you,
    Mikael
  • Hi Mikael,
    The HFXO uses more power than the internal HFINT, and is normally only used when a high accuracy clock is needed. This is for instance whiel the radio is active, and our radio stacks (Bluetooht and others) will automatically enable it when needed. However, if you need an accurate in other cases you can enable it using z_nrf_clock_control_get_onoff() which you can see an example of in clock_init() the radio test sample. Note that unless power consumption is not important for your product, you should release/disble the HFXO when you no longer need an accurate clock.
  • Hi Einar,
    Thank you for the explanation. I was loading sample code from the Bluetooth Fundamentals course onto my board. This example is simply an advertising Nordic Beacon". The code works fine on the nRF5340 but on my board, the same code does not generate any activity on the 32MHz clock.
    For you reference I am not using an external LF XTAL, so I am using RC oscillator.
    And HF XTAL relies on internal caps. So these are the configurations I added to the example code:
    #Internal 32kHz RC Oscillator
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y
    #32MHz Clock
    CONFIG_SOC_ENABLE_LFXO=n
    Is anything else required to operate the HF 32MHz clock? I am getting these errors:
    Thank you,
    Mikael
  • This is the crystal I am using
    ABM11W-32.0000MHZ-8-B1U-T3
    32MHz, +-10ppm
    Cload = 8pF, so internal C1/C2 = 12pF
    ABM11W.pdf
    Instead of RC oscillators I used this and the radio is working now. So the radio can't work with RC oscillators?
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH
    =y
