Problem writing to nrf52840
I am using the following chip: NRF52840-QIAA-R
boggi@getshop-boggi:~/....$ nrfjprog --program /home/boggi/..../build_1/zephyr/zephyr.hex --sectoranduicrerase --verify -f NRF52 --snr 1050385234 --log
[ #################### ] 5.321s | Erase file - Done erasing
[error] [ Client] - Encountered error -102: Command program_file executed for 389 milliseconds with result -102
[error] [ nRF52] - The write access failed, but no cause could be determined.
[error] [ nRF52] - It may be due to an unaligned access, accessing a nonexistent memory, or a communication issue.
[error] [ nRF52] - Failed while performing 'Write' operation on target address 0x00000000.
-102: An unknown error.
[error] [ nRF52] - Failed while reading device information.
[error] [ Worker] - An unknown error.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
boggi@getshop-boggi:~/....$ nrfjprog --memwr 0x00000000 --val 0x12345678 -f NRF52 --log
Parsing parameters.
Writing.
boggi@getshop-boggi:~/....$ nrfjprog --memwr 0x20000000 --val 0x12345678 -f NRF52 --log
Parsing parameters.
Writing.
Parsing parameters.
WARNING: Writing to a non-empty address may result in unexpected behavior.
Would you like to continue with the operation? [Y]/N
Writing.
Parsing parameters.
Writing.
[ #################### ] 5.327s | Erase file - Done erasing
[error] [ Client] - Encountered error -102: Command program_file executed for 392 milliseconds with result -102
Is there anything I am missing here?
I attach the log for all executions above.
316576.log.log
I have also tried nrfjprog --recover --log, it executes correct, but does not help
  • I know it is a bit "home-made". But i run out if wires and needed to remove soldered connection since that could be that somewhere it was improper connections. It is like this to make sure all connections where connected..
    Anyway it did not help..
    boggi@getshop-boggi:~$ nrfjprog --program /home/boggi/..../build_1/zephyr/zephyr.hex --recover --verify -f NRF52 --snr 1050385234 -c 500 --log
    [ #################### ] 1.147s | Erase file - Done erasing
    [error] [ Client] - Encountered error -102: Command program_file executed for 58 milliseconds with result -102
    boggi@getshop-boggi:~$ nrfjprog --recover
    Recovering device. This operation might take 30s.
    Erasing user code and UICR flash areas.
    boggi@getshop-boggi:~$ nrfjprog --program /home/boggi/..../build_1/zephyr/zephyr.hex --recover --verify -f NRF52 --snr 1050385234 --clockspeed 500 --log[ #################### ] 1.148s | Erase file - Done erasing
    [error] [ Client] - Encountered error -102: Command program_file executed for 57 milliseconds with result -102
    Attached log
    4454.log.log
    BTW; I have not nReset connected, could that cause this problems?
    Should not be needed. The debugger usually uses software reset, not pin reset.
    Does flashing that particular firmware work if you flash it to another nRF52840 device, like a DK? (I don't care if it doesn't run, but if it is possible to just flash it).
    And similarly, does it work programming other .hex files to that particular board?
    And finally, can you try with another DK as a debugger, or even an external debugger with your custom board.
    Edvin
  • Does flashing that particular firmware work if you flash it to another nRF52840 device, like a DK? (I don't care if it doesn't run, but if it is possible to just flash it).
    Yes
    No
    I don't have another DK, but I am able to program other custom boards the same way with the same DK, so I don't think there is a problem with the DK.
  • Ok, so you have one custom board that can't be programmed, and you don't have an external debugger to test with.
    So do you have several physical copies of that same custom board? And some of them are working, but one particular does not work?
    Or does none of that custom board work?
    Did the faulty device work at some point? Or did it never work?
    Edvin
  • Hi.
    I have different version of a custom board that works, but none of the same copy works here.
    They faulty one have never worked.
