Problem writing to nrf52840
I am using the following chip: NRF52840-QIAA-R
boggi@getshop-boggi:~/....$ nrfjprog --program /home/boggi/..../build_1/zephyr/zephyr.hex --sectoranduicrerase --verify -f NRF52 --snr 1050385234 --log
[ #################### ] 5.321s | Erase file - Done erasing
[error] [ Client] - Encountered error -102: Command program_file executed for 389 milliseconds with result -102
[error] [ nRF52] - The write access failed, but no cause could be determined.
[error] [ nRF52] - It may be due to an unaligned access, accessing a nonexistent memory, or a communication issue.
[error] [ nRF52] - Failed while performing 'Write' operation on target address 0x00000000.
-102: An unknown error.
[error] [ nRF52] - Failed while reading device information.
[error] [ Worker] - An unknown error.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
boggi@getshop-boggi:~/....$ nrfjprog --memwr 0x00000000 --val 0x12345678 -f NRF52 --log
Parsing parameters.
Writing.
boggi@getshop-boggi:~/....$ nrfjprog --memwr 0x20000000 --val 0x12345678 -f NRF52 --log
Parsing parameters.
Writing.
Parsing parameters.
WARNING: Writing to a non-empty address may result in unexpected behavior.
Would you like to continue with the operation? [Y]/N
Writing.
Parsing parameters.
Writing.
[ #################### ] 5.327s | Erase file - Done erasing
[error] [ Client] - Encountered error -102: Command program_file executed for 392 milliseconds with result -102
Is there anything I am missing here?
I attach the log for all executions above.
316576.log.log
I have also tried nrfjprog --recover --log, it executes correct, but does not help
  • Could it be soldering issues? Perhaps the chip is not properly soldered on the board?
    Unless you have an external debugger to test with, then I would say that you need to try to look at the soldering, or send it to us if you suspect it is a faulty device. In that case, we can desolder the chip, and test it in a socket board that we have.
    Alternatively, what you can do first is to send us your schematics and PCB layout files for review. In that case, please create a new ticket, so that it will be assigned to someone who knows what to look for in PCB reviews (because I don't).
    Edvin
