Simple SPI device
Hi
I am trying to make a SPI connection with a device which doesn't already have a driver build into Zephyr.
Is there some kind of genereic device i can use since i just need a simple SPI connection.
I've found a lot of very old examples, and i know i have to use the device tree to declare the spi, but i cannot seem to get it to work without using a already declared device.
This whole issue is especially annoying since it should be so simple, but due to all the abstraction has it become much more difficult.
Hope anyone can help!
    I suggest you have a look at this unofficial sample which demonstrate both SPI master and slave. Note that this use the Zephyr polling API with signals which makes sense in this particular case, but often it makes sense to do SPI communication as blocking operations in separate threads. This is just a minor change though, where you use the blocking SPI API functions insated (those without the _signal suffix). See the SPI API doc.
    (Attaching a modified version of the unofficial smaple I linked to here which use blocking calls in separate threads and in separate projects for separate boards. I did not test it now and honestly don't know if it works, but you can refer to it for inspiration: spi_master_slave_separate.zip)
  • Hi
    Thank you so much for your anwser, the attached zip file got the SPI up and running in no time!
    If there is someone else, like me, who is using the nRF9151dk then all you have to add is the following to the prj.conf file:
    CONFIG_TFM_SECURE_UART=n
    CONFIG_TFM_LOG_LEVEL_SILENCE=y
    I've also noticed that the deafult clock freq of 40MHz was gave errors in the readings when MOSI and MISO was shorted, so if you get errors then be sure to change the frequency in the spi_config struct.
    Again, thank you very much for the help!
