Hi,I have been using nrf5340 audio DK Board to access the I2S .I am using SPH0645 mic with that i need to get mic data .I am getting mic data continuously but sure that I am not getting correct data.I have checked with clock SCK 1.024 MHz and LRCL of 16kHz but don't know where it's going wrong.Can you help me regarding this,I am attaching overlay and my main file .Please check and provide me a solution of getting correct mic data.I am converting 32 bit of data to 16 bit in process block function.
#include <zephyr/kernel.h>
#include <zephyr/drivers/i2s.h>
#include <string.h>
#include <zephyr/drivers/uart.h>
#define I2S_RX_NODE DT_NODELABEL(i2s_rxtx)
#define SAMPLE_FREQUENCY 16000
#define SAMPLE_BIT_WIDTH 32
#define BYTES_PER_SAMPLE sizeof(int16_t)
#define NUMBER_OF_CHANNELS 1
#define SAMPLES_PER_BLOCK ((SAMPLE_FREQUENCY / 10) * NUMBER_OF_CHANNELS)
#define INITIAL_BLOCKS 2
#define TIMEOUT 1000
#define BLOCK_SIZE (BYTES_PER_SAMPLE * SAMPLES_PER_BLOCK)
#define BLOCK_COUNT (INITIAL_BLOCKS + 2)
K_MEM_SLAB_DEFINE_STATIC(mem_slab, BLOCK_SIZE, BLOCK_COUNT, 4);
const struct device *const i2s_dev_rx = DEVICE_DT_GET(I2S_RX_NODE);
struct i2s_config config;
static int16_t echo_block[SAMPLES_PER_BLOCK];
uint8_t loopCnt = 0;
static void process_block_data(void *mem_block, uint32_t number_of_samples)
for (int i = 0; i < number_of_samples; ++i)
int16_t *sample = &((int16_t *)mem_block)[i];
echo_block[i] = *sample;
static bool configure_streams(const struct device *i2s_dev_rx, const struct i2s_config *config)
int ret = i2s_configure(i2s_dev_rx, I2S_DIR_RX, config);
if (ret == 0)
printk("Configure Stream Successful.\n");
return true;
printk("Failed to configure streams: %d\n", ret);
return false;
static bool trigger_command(const struct device *i2s_dev_rx, enum i2s_trigger_cmd cmd)
int ret = i2s_trigger(i2s_dev_rx, I2S_DIR_RX, cmd);
if (ret == 0)
printk("Trigger Command Successful.\n");
return true;
printk("Failed to trigger command %d: %d\n", cmd, ret);
return false;
static void i2sStreamInit(void){
printk("I2S echo sample\n");
if (!device_is_ready(i2s_dev_rx))
printk("%s is not ready\n", i2s_dev_rx->name);
return 0;
config.word_size = SAMPLE_BIT_WIDTH;
config.channels = NUMBER_OF_CHANNELS;
config.format = I2S_FMT_DATA_FORMAT_I2S;
config.options = I2S_OPT_BIT_CLK_MASTER | I2S_OPT_FRAME_CLK_MASTER;
config.frame_clk_freq = SAMPLE_FREQUENCY;
config.mem_slab = &mem_slab;
config.block_size = BLOCK_SIZE;
config.timeout = TIMEOUT;
if (!configure_streams(i2s_dev_rx, &config))
return 0;
if (!trigger_command(i2s_dev_rx, I2S_TRIGGER_START))
return 0;
i2sStreamInit();
printk("Streams started\n");
while (1)
void *mem_block;
uint32_t block_size;
int ret;
ret = i2s_read(i2s_dev_rx, &mem_block, &block_size);
if (ret < 0)
printk("Failed to read data: %d\n", ret);
process_block_data(mem_block, SAMPLES_PER_BLOCK);
k_mem_slab_free(&mem_slab, mem_block);
printk("Exiting main loop\n");
return 0;
&pinctrl {
i2s0_default: i2s0_default {
group1 {
psels = <NRF_PSEL(I2S_SCK_M, 0, 26)>,
<NRF_PSEL(I2S_LRCK_M, 0, 25)>,
<NRF_PSEL(I2S_SDIN, 0, 7)>,
<NRF_PSEL(I2S_MCK, 1, 0)>,
<NRF_PSEL(I2S_SDOUT, 0, 6)>;
i2s0_sleep: i2s0_sleep {
group1 {
&clock {
hfclkaudio-frequency = <11289600>;
i2s_rxtx: &i2s0 {
status = "okay";
pinctrl-0 = <&i2s0_default>;
pinctrl-1 = <&i2s0_sleep>;
clock-source = "ACLK";
pinctrl-names = "default","sleep";
Regards
Kashyap
