Couldn't do FOTA over BLE after add CONFIG_SECURE_BOOT=y
I am trying implement signature keys feature in light ctrl sample.  Before I do this, I have implemented FOTA over BLE feature in it successfully.
However, after I add CONFIG_SECURE_BOOT=y and some config about key file, FOTA would be failed.
Actually, the Device Manager app show upload completely. but the NRF5340 DK doesn't be upgraded after I reboot it.
What's wrong with it? Can someone help me to find out?
I am developing in macOS and NCS2.5.0
Thanks.
prj.conf
# Copyright (c) 2020 Nordic Semiconductor ASA
# CONFIG_NCS_SAMPLES_DEFAULTS=y
# Deffered logging helps improve LPN power consumption
# when friendship is established.
CONFIG_LOG_MODE_DEFERRED=y
# General configuration
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_NVS_LOOKUP_CACHE=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS_NAME_CACHE=y
CONFIG_HWINFO=y
CONFIG_DK_LIBRARY=y
CONFIG_PWM=y
CONFIG_PM_SINGLE_IMAGE=y
# CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x8000
CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE=y
# Bluetooth configuration
CONFIG_BT=y
CONFIG_BT_COMPANY_ID=0x0059
CONFIG_BT_DEVICE_NAME="Mesh Light Fixture"
CONFIG_BT_L2CAP_TX_BUF_COUNT=8
CONFIG_BT_OBSERVER=y
CONFIG_BT_PERIPHERAL=y
# Disable unused Bluetooth features
CONFIG_BT_CTLR_DUP_FILTER_LEN=0
CONFIG_BT_CTLR_LE_ENC=n
CONFIG_BT_PHY_UPDATE=n
CONFIG_BT_CTLR_CHAN_SEL_2=n
CONFIG_BT_CTLR_MIN_USED_CHAN=n
CONFIG_BT_CTLR_PRIVACY=n
# Bluetooth mesh configuration
CONFIG_BT_MESH=y
CONFIG_BT_MESH_RELAY=y
CONFIG_BT_MESH_FRIEND=y
CONFIG_BT_MESH_TX_SEG_MAX=10
CONFIG_BT_MESH_PB_GATT=y
CONFIG_BT_MESH_PROXY_USE_DEVICE_NAME=y
CONFIG_BT_MESH_GATT_PROXY=y
CONFIG_BT_MESH_ADV_EXT_GATT_SEPARATE=y
CONFIG_BT_MESH_DK_PROV=y
CONFIG_BT_MESH_NLC_PERF_CONF=y
CONFIG_BT_MESH_NLC_PERF_LIGHTNESS_CTRL=y
CONFIG_BT_MESH_MODEL_EXTENSION_LIST_SIZE=18
# Bluetooth mesh models
CONFIG_BT_MESH_LIGHT_CTRL_SRV=y
CONFIG_BT_MESH_LIGHT_CTRL_SRV_TIME_ON=3
CONFIG_BT_MESH_LIGHT_CTRL_SRV_TIME_PROLONG=3
CONFIG_BT_MESH_LIGHT_CTRL_SRV_RESUME_DELAY=30
CONFIG_BT_MESH_SCENE_SRV=y
CONFIG_BT_MESH_SENSOR_SRV=y
CONFIG_REBOOT=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE=y
CONFIG_BT_SMP=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
CONFIG_UPDATEABLE_IMAGE_NUMBER=2
CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS=y
CONFIG_ZCBOR=y
CONFIG_MCUMGR=y
CONFIG_MCUMGR_TRANSPORT_BT=y
CONFIG_STREAM_FLASH=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUMGR_GRP_IMG=y
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y
CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y
CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS=y
CONFIG_MCUMGR_GRP_IMG_UPLOAD_CHECK_HOOK=y
CONFIG_SB_SIGNING_KEY_FILE="/opt/nordic/ncs/v2.5.0/bootloader/mcuboot/priv_a.pem"
create child_image/mcuboot.conf
# Enable flash simulator
CONFIG_FLASH=y
CONFIG_FPROTECT=y
CONFIG_PCD_APP=y
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
CONFIG_FLASH_SIMULATOR_STATS=n
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=16
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_BOOT_MAX_IMG_SECTORS=256
CONFIG_NRF53_MULTI_IMAGE_UPDATE=y
CONFIG_BOOT_UPGRADE_ONLY=y
CONFIG_BOOT_IMAGE_ACCESS_HOOK_NRF5340=y
CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
CONFIG_FW_INFO_FIRMWARE_VERSION=1
CONFIG_BOOT_SIGNATURE_KEY_FILE="/opt/nordic/ncs/v2.5.0/bootloader/mcuboot/priv_a.pem"
CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
add this into child_image/hci_rpmsg.conf
add this into boards/nrf5340dk_nrf5340_cpuapp.overlay
	chosen {
		nordic,pm-ext-flash = &mx25r64;
add smp_bt_register(); to main.c
