After upgrading to NCS 2.7.0 I noticed the MX25R1635F (A very commonly used / well supported chip for zephyr) no longer enters deep power down. On further investigation, changes were made to ncs/v2.7.0/zephyr/drivers/flash/spi_nor.c that only load device tree settings for the flash when CONFIG_SPI_NOR_SFDP_RUNTIME=n. At least for the chip I mentioned, acquiring the serial flash discovery parameters (sfdp) makes no attempt to set the values that are now being ignored in the device tree.
The following parameters aren't populated from the devicetree when CONFIG_SPI_NOR_SFDP_RUNTIME=n
#define INST_CONFIG_STRUCT_GEN(idx) \ DEFINE_PAGE_LAYOUT(idx) \ .flash_size = DT_INST_PROP(idx, size) / 8, \ .jedec_id = DT_INST_PROP(idx, jedec_id), \ .dpd_exist = DT_INST_PROP(idx, has_dpd), \ .dpd_wakeup_sequence_exist = DT_INST_NODE_HAS_PROP(idx, dpd_wakeup_sequence), \ .mxicy_mx25r_power_mode_exist = DT_INST_NODE_HAS_PROP(idx, mxicy_mx25r_power_mode), \ .reset_gpios_exist = DT_INST_NODE_HAS_PROP(idx, reset_gpios), \ .requires_ulbpr_exist = DT_INST_PROP(idx, requires_ulbpr), \ .wp_gpios_exist = DT_INST_NODE_HAS_PROP(idx, wp_gpios), \ .hold_gpios_exist = DT_INST_NODE_HAS_PROP(idx, hold_gpios), \ IF_ENABLED(INST_HAS_LOCK(idx), (.has_lock = DT_INST_PROP(idx, has_lock),)) \ IF_ENABLED(CONFIG_SPI_NOR_SFDP_MINIMAL, (CONFIGURE_4BYTE_ADDR(idx))) \ IF_ENABLED(CONFIG_SPI_NOR_SFDP_DEVICETREE, \ (.bfp_len = sizeof(bfp_##idx##_data) / 4, \ .bfp = (const struct jesd216_bfp *)bfp_##idx##_data,)) \ IF_ENABLED(ANY_INST_HAS_DPD, (INIT_T_ENTER_DPD(idx),)) \ IF_ENABLED(UTIL_AND(ANY_INST_HAS_DPD, ANY_INST_HAS_T_EXIT_DPD), (INIT_T_EXIT_DPD(idx),))\ IF_ENABLED(ANY_INST_HAS_DPD_WAKEUP_SEQUENCE, (INIT_WAKEUP_SEQ_PARAMS(idx),)) \ IF_ENABLED(ANY_INST_HAS_MXICY_MX25R_POWER_MODE, (INIT_MXICY_MX25R_POWER_MODE(idx),)) \ IF_ENABLED(ANY_INST_HAS_RESET_GPIOS, (INIT_RESET_GPIOS(idx),)) \ IF_ENABLED(ANY_INST_HAS_WP_GPIOS, (INIT_WP_GPIOS(idx),)) \ IF_ENABLED(ANY_INST_HAS_HOLD_GPIOS, (INIT_HOLD_GPIOS(idx),))
This seems like a pretty big oversight as people may not notice their device is sleeping at a higher than expected level. As a short term fix, I heavily modified the spi_nor.c file to do the following:
- heavily reduce the reliance on macros so I could understand what is going on.
- Removed several features such as reset-gpios, hold-gpios, wp-gpios, has_lock, mxicy, dpd_sequence and a few others (mostly for readability).
- directly set the spi_nor_config from the device tree
- Prevent rapid successive calls to enter_dpd() & exit_dpd() as this significantly impacts filesystem performance.
It would be nice if Nordic could prioritize integrating the latest changes from zephyr as it looks like they are attempting to fix this stuff. In the interim, hopefully this modified source file can be a good starting point to others having similar issues to me.
* Copyright (c) 2018 Savoir-Faire Linux.
* Copyright (c) 2020 Peter Bigot Consulting, LLC
* Copyright (c) 2023 Intercreate, Inc.
* This driver is heavily inspired from the spi_flash_w25qxxdv.c SPI NOR driver.
#define DT_DRV_COMPAT jedec_spi_nor
#include <errno.h>
#include <zephyr/drivers/flash.h>
#include <zephyr/drivers/spi.h>
#include <zephyr/init.h>
#include <string.h>
#include <zephyr/sys_clock.h>
#include <zephyr/pm/device.h>
#include "spi_nor.h"
#include "jesd216.h"
#include "flash_priv.h"
LOG_MODULE_REGISTER(spi_nor, CONFIG_FLASH_LOG_LEVEL);
/* Device Power Management Notes
* These flash devices have several modes during operation:
* * When CSn is asserted (during a SPI operation) the device is
* active.
* * When CSn is deasserted the device enters a standby mode.
* * Some devices support a Deep Power-Down mode which reduces current
* to as little as 0.1% of standby.
* The power reduction from DPD is sufficient to warrant allowing its
* use even in cases where Zephyr's device power management is not
* available. This is selected through the SPI_NOR_IDLE_IN_DPD
* Kconfig option.
* When mapped to the Zephyr Device Power Management states:
* * PM_DEVICE_STATE_ACTIVE covers both active and standby modes;
* * PM_DEVICE_STATE_SUSPENDED, and PM_DEVICE_STATE_OFF all correspond to
* deep-power-down mode.
#define SPI_NOR_MAX_ADDR_WIDTH 4
/* Build-time data associated with the device. */
struct spi_nor_config {
/* Devicetree SPI configuration */
struct spi_dt_spec spi;
/* Runtime SFDP stores no static configuration. */
/* Size of device in bytes, from size property */
uint32_t flash_size;
/* Flash page layout can be determined from devicetree. */
struct flash_pages_layout layout;
/* Expected JEDEC ID, from jedec-id property */
uint8_t jedec_id[SPI_NOR_MAX_ID_LEN];
uint16_t t_enter_dpd; /* in microseconds */
uint16_t t_dpdd_ms; /* in microseconds */
uint16_t t_exit_dpd; /* in microseconds */
* struct spi_nor_data - Structure for defining the SPI NOR access
* @sem: The semaphore to access to the flash
struct spi_nor_data {
struct k_sem sem;
/* Low 32-bits of uptime counter at which device last entered
* deep power-down.
uint32_t ts_enter_dpd;
/* Miscellaneous flags */
/* If set addressed operations should use 32-bit rather than
* 24-bit addresses.
* This is ignored if the access parameter to a command
* explicitly specifies 24-bit or 32-bit addressing.
bool flag_access_32bit: 1;
/* Minimal SFDP stores no dynamic configuration. Runtime and
* devicetree store page size and erase_types; runtime also
* stores flash size and layout.
struct jesd216_erase_type erase_types[JESD216_NUM_ERASE_TYPES];
/* Number of bytes per page */
uint16_t page_size;
/* Size of flash, in bytes */
struct k_work_delayable enter_dpd_work;
const struct device* self;
/* Register writes should be ready extremely quickly */
#define WAIT_READY_REGISTER K_NO_WAIT
/* Page writes range from sub-ms to 10ms */
#define WAIT_READY_WRITE K_TICKS(1)
/* Erases can range from 45ms to 240sec */
#define WAIT_READY_ERASE K_MSEC(50)
static int spi_nor_write_protection_set(const struct device *dev,
bool write_protect);
/* Get pointer to array of supported erase types. Static const for
* minimal, data for runtime and devicetree.
static inline const struct jesd216_erase_type *
dev_erase_types(const struct device *dev) {
const struct spi_nor_data *data = dev->data;
return data->erase_types;
/* Get the size of the flash device. Data for runtime, constant for
* minimal and devicetree.
static inline uint32_t dev_flash_size(const struct device *dev) {
return data->flash_size;
/* Get the flash device page size. Constant for minimal, data for
* runtime and devicetree.
static inline uint16_t dev_page_size(const struct device *dev) {
return data->page_size;
static const struct flash_parameters flash_nor_parameters = {
.write_block_size = 1,
.erase_value = 0xff,
/* Check the current time against the time DPD was entered and delay
* until it's ok to initiate the DPD exit process.
static inline void delay_until_exit_dpd_ok(const struct device *const dev) {
const struct spi_nor_config *const driver_config = dev->config;
struct spi_nor_data *const driver_data = dev->data;
int32_t since = (int32_t)(k_uptime_get_32() - driver_data->ts_enter_dpd);
/* If the time is negative the 32-bit counter has wrapped,
* which is certainly long enough no further delay is
* required. Otherwise we have to check whether it's been
* long enough taking into account necessary delays for
* entering and exiting DPD.
if (since >= 0) {
/* Subtract time required for DPD to be reached */
since -= driver_config->t_enter_dpd;
/* Subtract time required in DPD before exit */
since -= driver_config->t_dpdd_ms;
/* If the adjusted time is negative we have to wait
* until it reaches zero before we can proceed.
if (since < 0) {
k_sleep(K_MSEC((uint32_t)-since));
/* Indicates that an access command includes bytes for the address.
* If not provided the opcode is not followed by address bytes.
#define NOR_ACCESS_ADDRESSED BIT(0)
/* Indicates that addressed access uses a 24-bit address regardless of
* spi_nor_data::flag_32bit_addr.
#define NOR_ACCESS_24BIT_ADDR BIT(1)
/* Indicates that addressed access uses a 32-bit address regardless of
#define NOR_ACCESS_32BIT_ADDR BIT(2)
/* Indicates that an access command is performing a write. If not
* provided access is a read.
#define NOR_ACCESS_WRITE BIT(7)
* @brief Send an SPI command
* @param dev Device struct
* @param opcode The command to send
* @param access flags that determine how the command is constructed.
* See NOR_ACCESS_*.
* @param addr The address to send
* @param data The buffer to store or read the value
* @param length The size of the buffer
* @return 0 on success, negative errno code otherwise
static int spi_nor_access(const struct device *const dev,
uint8_t opcode, unsigned int access,
off_t addr, void *data, size_t length)
const struct spi_nor_config *const driver_cfg = dev->config;
bool is_addressed = (access & NOR_ACCESS_ADDRESSED) != 0U;
bool is_write = (access & NOR_ACCESS_WRITE) != 0U;
uint8_t buf[5] = { 0 };
struct spi_buf spi_buf[2] = {
.buf = buf,
.len = 1,
.buf = data,
.len = length
buf[0] = opcode;
if (is_addressed) {
bool access_24bit = (access & NOR_ACCESS_24BIT_ADDR) != 0;
bool access_32bit = (access & NOR_ACCESS_32BIT_ADDR) != 0;
bool use_32bit = (access_32bit
|| (!access_24bit
&& driver_data->flag_access_32bit));
union {
uint32_t u32;
uint8_t u8[4];
} addr32 = {
.u32 = sys_cpu_to_be32(addr),
if (use_32bit) {
memcpy(&buf[1], &addr32.u8[0], 4);
spi_buf[0].len += 4;
} else {
memcpy(&buf[1], &addr32.u8[1], 3);
spi_buf[0].len += 3;
const struct spi_buf_set tx_set = {
.buffers = spi_buf,
.count = (length != 0) ? 2 : 1,
const struct spi_buf_set rx_set = {
.buffers = spi_buf,
.count = 2,
if (is_write) {
return spi_write_dt(&driver_cfg->spi, &tx_set);
return spi_transceive_dt(&driver_cfg->spi, &tx_set, &rx_set);
#define spi_nor_cmd_read(dev, opcode, dest, length) \
spi_nor_access(dev, opcode, 0, 0, dest, length)
#define spi_nor_cmd_addr_read(dev, opcode, addr, dest, length) \
spi_nor_access(dev, opcode, NOR_ACCESS_ADDRESSED, addr, dest, length)
#define spi_nor_cmd_write(dev, opcode) \
spi_nor_access(dev, opcode, NOR_ACCESS_WRITE, 0, NULL, 0)
#define spi_nor_cmd_addr_write(dev, opcode, addr, src, length) \
spi_nor_access(dev, opcode, NOR_ACCESS_WRITE | NOR_ACCESS_ADDRESSED, \
addr, (void *)src, length)
* @brief Wait until the flash is ready
* @note The device must be externally acquired before invoking this
* function.
* This function should be invoked after every ERASE, PROGRAM, or
* WRITE_STATUS operation before continuing. This allows us to assume
* that the device is ready to accept new commands at any other point
* in the code.
* @param dev The device structure
* @param poll_delay Duration between polls of status register
static int spi_nor_wait_until_ready(const struct device *dev, k_timeout_t poll_delay)
int ret;
uint8_t reg;
ARG_UNUSED(poll_delay);
while (true) {
ret = spi_nor_cmd_read(dev, SPI_NOR_CMD_RDSR, ®, sizeof(reg));
/* Exit on error or no longer WIP */
if (ret || !(reg & SPI_NOR_WIP_BIT)) {
/* Don't monopolise the CPU while waiting for ready */
k_sleep(poll_delay);
return ret;
* @brief Read content from the SFDP hierarchy
* function.
static int read_sfdp(const struct device *const dev,
/* READ_SFDP requires a 24-bit address followed by a single
* byte for a wait state. This is effected by using 32-bit
* address by shifting the 24-bit address up 8 bits.
return spi_nor_access(dev, JESD216_CMD_READ_SFDP,
NOR_ACCESS_32BIT_ADDR | NOR_ACCESS_ADDRESSED,
addr << 8, data, length);
static int enter_dpd(const struct device *const dev) {
int ret = 0;
ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_DPD);
if (ret == 0) {
driver_data->ts_enter_dpd = k_uptime_get_32();
return ret;
static void spi_nor_enter_dpd_work(struct k_work *work) {
struct k_work_delayable* dw = k_work_delayable_from_work(work);
struct spi_nor_data* driver_data = CONTAINER_OF(dw, struct spi_nor_data, enter_dpd_work);
if (IS_ENABLED(CONFIG_MULTITHREADING)) {
if(k_sem_take(&driver_data->sem, K_NO_WAIT) == -EBUSY) {
k_work_schedule(&driver_data->enter_dpd_work, K_MSEC(1000));
return;
enter_dpd(driver_data->self);
k_sem_give(&driver_data->sem);
static int exit_dpd(const struct device *const dev)
int ret = 0;
const struct spi_nor_config *cfg = dev->config;
delay_until_exit_dpd_ok(dev);
ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_RDPD);
if (ret == 0) {
k_sleep(K_MSEC(cfg->t_exit_dpd));
return ret;
/* Everything necessary to acquire owning access to the device.
* This means taking the lock and, if necessary, waking the device
* from deep power-down mode.
static void acquire_device(const struct device *dev) {
k_sem_take(&driver_data->sem, K_FOREVER);
if (IS_ENABLED(CONFIG_SPI_NOR_IDLE_IN_DPD)) {
int ret = k_work_delayable_busy_get(&driver_data->enter_dpd_work);
if(ret == 0) {
exit_dpd(dev);
return;
if((ret & K_WORK_QUEUED) || (ret & K_WORK_DELAYED)) {
k_work_cancel_delayable(&driver_data->enter_dpd_work);
/* Everything necessary to release access to the device.
* This means (optionally) putting the device into deep power-down
* mode, and releasing the lock.
static void release_device(const struct device *dev) {
* @brief Read the status register.
* function.
* @return the non-negative value of the status register, or an error code.
static int spi_nor_rdsr(const struct device *dev)
uint8_t reg;
int ret = spi_nor_cmd_read(dev, SPI_NOR_CMD_RDSR, ®, sizeof(reg));
if (ret == 0) {
ret = reg;
return ret;
static int spi_nor_read(const struct device *dev, off_t addr, void *dest,
size_t size)
const size_t flash_size = dev_flash_size(dev);
int ret;
/* should be between 0 and flash size */
if ((addr < 0) || ((addr + size) > flash_size)) {
return -EINVAL;
acquire_device(dev);
ret = spi_nor_cmd_addr_read(dev, SPI_NOR_CMD_READ, addr, dest, size);
release_device(dev);
return ret;
static int spi_nor_write(const struct device *dev, off_t addr,
const void *src,
size_t size)
const uint16_t page_size = dev_page_size(dev);
int ret;
if ((addr < 0) || ((size + addr) > flash_size)) {
return -EINVAL;
ret = spi_nor_write_protection_set(dev, false);
if (ret == 0) {
while (size > 0) {
size_t to_write = size;
/* Don't write more than a page. */
if (to_write >= page_size) {
to_write = page_size;
/* Don't write across a page boundary */
if (((addr + to_write - 1U) / page_size)
!= (addr / page_size)) {
to_write = page_size - (addr % page_size);
spi_nor_cmd_write(dev, SPI_NOR_CMD_WREN);
ret = spi_nor_cmd_addr_write(dev, SPI_NOR_CMD_PP, addr,
src, to_write);
if (ret != 0) {
size -= to_write;
src = (const uint8_t *)src + to_write;
addr += to_write;
spi_nor_wait_until_ready(dev, WAIT_READY_WRITE);
int ret2 = spi_nor_write_protection_set(dev, true);
if (!ret) {
ret = ret2;
return ret;
static int spi_nor_erase(const struct device *dev, off_t addr, size_t size)
int ret;
/* erase area must be subregion of device */
return -EINVAL;
/* address must be sector-aligned */
if (!SPI_NOR_IS_SECTOR_ALIGNED(addr)) {
return -EINVAL;
/* size must be a multiple of sectors */
if ((size % SPI_NOR_SECTOR_SIZE) != 0) {
return -EINVAL;
while ((size > 0) && (ret == 0)) {
if (size == flash_size) {
/* chip erase */
spi_nor_cmd_write(dev, SPI_NOR_CMD_CE);
size -= flash_size;
} else {
const struct jesd216_erase_type *erase_types =
dev_erase_types(dev);
const struct jesd216_erase_type *bet = NULL;
for (uint8_t ei = 0; ei < JESD216_NUM_ERASE_TYPES; ++ei) {
const struct jesd216_erase_type *etp =
&erase_types[ei];
if ((etp->exp != 0)
&& SPI_NOR_IS_ALIGNED(addr, etp->exp)
&& (size >= BIT(etp->exp))
&& ((bet == NULL)
|| (etp->exp > bet->exp))) {
bet = etp;
if (bet != NULL) {
spi_nor_cmd_addr_write(dev, bet->cmd, addr, NULL, 0);
addr += BIT(bet->exp);
size -= BIT(bet->exp);
} else {
LOG_DBG("Can't erase %zu at 0x%lx",
size, (long)addr);
ret = -EINVAL;
#ifdef __XCC__
* FIXME: remove this hack once XCC is fixed.
* Without this volatile return value, XCC would segfault
* compiling this file complaining about failure in CGPREP
* phase.
volatile int xcc_ret =
spi_nor_wait_until_ready(dev, WAIT_READY_ERASE);
if (!ret) {
ret = ret2;
return ret;
/* @note The device must be externally acquired before invoking this
* function.
bool write_protect)
int ret;
ret = spi_nor_cmd_write(dev, (write_protect) ?
SPI_NOR_CMD_WRDI : SPI_NOR_CMD_WREN);
return ret;
static int spi_nor_sfdp_read(const struct device *dev, off_t addr,
void *dest, size_t size)
int ret = read_sfdp(dev, addr, dest, size);
return ret;
static int spi_nor_read_jedec_id(const struct device *dev,
uint8_t *id)
if (id == NULL) {
return -EINVAL;
int ret = spi_nor_cmd_read(dev, SPI_NOR_CMD_RDID, id, SPI_NOR_MAX_ID_LEN);
return ret;
/* Put the device into the appropriate address mode, if supported.
* On successful return spi_nor_data::flag_access_32bit has been set
* (cleared) if the device is configured for 4-byte (3-byte) addresses
* for read, write, and erase commands.
* @param dev the device
* @param enter_4byte_addr the Enter 4-Byte Addressing bit set from
* DW16 of SFDP BFP. A value of all zeros or all ones is interpreted
* as "not supported".
* @retval -ENOTSUP if 4-byte addressing is supported but not in a way
* that the driver can handle.
* @retval negative codes if the attempt was made and failed
* @retval 0 if the device is successfully left in 24-bit mode or
* reconfigured to 32-bit mode.
static int spi_nor_set_address_mode(const struct device *dev,
uint8_t enter_4byte_addr)
int ret = 0;
/* Do nothing if not provided (either no bits or all bits
* set).
if ((enter_4byte_addr == 0)
|| (enter_4byte_addr == 0xff)) {
return 0;
LOG_DBG("Checking enter-4byte-addr %02x", enter_4byte_addr);
/* This currently only supports command 0xB7 (Enter 4-Byte
* Address Mode), with or without preceding WREN.
if ((enter_4byte_addr & 0x03) == 0) {
return -ENOTSUP;
if ((enter_4byte_addr & 0x02) != 0) {
/* Enter after WREN. */
ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_WREN);
if (ret == 0) {
ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_4BA);
if (ret == 0) {
data->flag_access_32bit = true;
return ret;
static int spi_nor_process_bfp(const struct device *dev,
const struct jesd216_param_header *php,
const struct jesd216_bfp *bfp)
struct jesd216_erase_type *etp = data->erase_types;
const size_t flash_size = jesd216_bfp_density(bfp) / 8U;
LOG_INF("%s: %u MiBy flash", dev->name, (uint32_t)(flash_size >> 20));
/* Copy over the erase types, preserving their order. (The
* Sector Map Parameter table references them by index.)
memset(data->erase_types, 0, sizeof(data->erase_types));
for (uint8_t ti = 1; ti <= ARRAY_SIZE(data->erase_types); ++ti) {
if (jesd216_bfp_erase(bfp, ti, etp) == 0) {
LOG_DBG("Erase %u with %02x", (uint32_t)BIT(etp->exp), etp->cmd);
++etp;
data->page_size = jesd216_bfp_page_size(php, bfp);
data->flash_size = flash_size;
LOG_DBG("Page size %u bytes", data->page_size);
/* If 4-byte addressing is supported, switch to it. */
if (jesd216_bfp_addrbytes(bfp) != JESD216_SFDP_BFP_DW1_ADDRBYTES_VAL_3B) {
struct jesd216_bfp_dw16 dw16;
int rc = 0;
if (jesd216_bfp_decode_dw16(php, bfp, &dw16) == 0) {
rc = spi_nor_set_address_mode(dev, dw16.enter_4ba);
if (rc != 0) {
LOG_ERR("Unable to enter 4-byte mode: %d\n", rc);
return rc;
return 0;
static int spi_nor_process_sfdp(const struct device *dev) {
int rc;
/* For runtime we need to read the SFDP table, identify the
* BFP block, and process it.
const uint8_t decl_nph = 2;
union {
/* We only process BFP so use one parameter block */
uint8_t raw[JESD216_SFDP_SIZE(decl_nph)];
struct jesd216_sfdp_header sfdp;
} u_header;
const struct jesd216_sfdp_header *hp = &u_header.sfdp;
rc = spi_nor_sfdp_read(dev, 0, u_header.raw, sizeof(u_header.raw));
if (rc != 0) {
LOG_ERR("SFDP read failed: %d", rc);
return rc;
uint32_t magic = jesd216_sfdp_magic(hp);
if (magic != JESD216_SFDP_MAGIC) {
LOG_ERR("SFDP magic %08x invalid", magic);
return -EINVAL;
LOG_INF("%s: SFDP v %u.%u AP %x with %u PH", dev->name,
hp->rev_major, hp->rev_minor, hp->access, 1 + hp->nph);
const struct jesd216_param_header *php = hp->phdr;
const struct jesd216_param_header *phpe = php + MIN(decl_nph, 1 + hp->nph);
while (php != phpe) {
uint16_t id = jesd216_param_id(php);
LOG_INF("PH%u: %04x rev %u.%u: %u DW @ %x",
(php - hp->phdr), id, php->rev_major, php->rev_minor,
php->len_dw, jesd216_param_addr(php));
if (id == JESD216_SFDP_PARAM_ID_BFP) {
union {
uint32_t dw[MIN(php->len_dw, 20)];
struct jesd216_bfp bfp;
} u_param;
const struct jesd216_bfp *bfp = &u_param.bfp;
rc = spi_nor_sfdp_read(dev, jesd216_param_addr(php),
u_param.dw, sizeof(u_param.dw));
if (rc == 0) {
rc = spi_nor_process_bfp(dev, php, bfp);
if (rc != 0) {
LOG_INF("SFDP BFP failed: %d", rc);
++php;
return rc;
static int setup_pages_layout(const struct device *dev) {
const uint32_t layout_page_size = CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE;
uint8_t exp = 0;
/* Find the smallest erase size. */
for (size_t i = 0; i < ARRAY_SIZE(data->erase_types); ++i) {
const struct jesd216_erase_type *etp = &data->erase_types[i];
if ((etp->cmd != 0)
&& ((exp == 0) || (etp->exp < exp))) {
exp = etp->exp;
if (exp == 0) {
return -ENOTSUP;
uint32_t erase_size = BIT(exp);
/* Error if layout page size is not a multiple of smallest
* erase size.
if ((layout_page_size % erase_size) != 0) {
LOG_ERR("layout page %u not compatible with erase size %u",
layout_page_size, erase_size);
return -EINVAL;
/* Warn but accept layout page sizes that leave inaccessible
* space.
if ((flash_size % layout_page_size) != 0) {
LOG_INF("layout page %u wastes space with device size %zu",
layout_page_size, flash_size);
data->layout.pages_size = layout_page_size;
data->layout.pages_count = flash_size / layout_page_size;
LOG_DBG("layout %u x %u By pages", data->layout.pages_count, data->layout.pages_size);
return 0;
* @brief Configure the flash
* @param dev The flash device structure
* @param info The flash info structure
static int spi_nor_configure(const struct device *dev) {
int rc;
/* Validate bus and CS is ready */
if (!spi_is_ready_dt(&cfg->spi)) {
return -ENODEV;
/* After a soft-reset the flash might be in DPD or busy writing/erasing.
* Exit DPD and wait until flash is ready.
rc = exit_dpd(dev);
if (rc < 0) {
LOG_ERR("Failed to exit DPD (%d)", rc);
return -ENODEV;
rc = spi_nor_rdsr(dev);
if (rc > 0 && (rc & SPI_NOR_WIP_BIT)) {
LOG_WRN("Waiting until flash is ready");
spi_nor_wait_until_ready(dev, WAIT_READY_REGISTER);
/* now the spi bus is configured, we can verify SPI
* connectivity by reading the JEDEC ID.
rc = spi_nor_read_jedec_id(dev, jedec_id);
if (rc != 0) {
LOG_ERR("JEDEC ID read failed: %d", rc);
return -ENODEV;
/* For devicetree and runtime we need to process BFP data and
* set up or validate page layout.
rc = spi_nor_process_sfdp(dev);
if (rc != 0) {
return -ENODEV;
rc = setup_pages_layout(dev);
if (rc != 0) {
LOG_ERR("layout setup failed: %d", rc);
return -ENODEV;
&& (enter_dpd(dev) != 0)) {
return -ENODEV;
return 0;
static int spi_nor_pm_control(const struct device *dev, enum pm_device_action action)
int rc = 0;
switch (action) {
#ifdef CONFIG_SPI_NOR_IDLE_IN_DPD
case PM_DEVICE_ACTION_SUSPEND:
case PM_DEVICE_ACTION_RESUME:
#else
rc = enter_dpd(dev);
rc = exit_dpd(dev);
#endif /* CONFIG_SPI_NOR_IDLE_IN_DPD */
case PM_DEVICE_ACTION_TURN_ON:
/* Coming out of power off */
rc = spi_nor_configure(dev);
#ifndef CONFIG_SPI_NOR_IDLE_IN_DPD
if (rc == 0) {
/* Move to DPD, the correct device state
* for PM_DEVICE_STATE_SUSPENDED
case PM_DEVICE_ACTION_TURN_OFF:
rc = -ENOSYS;
return rc;
* @brief Initialize and configure the flash
* @param name The flash name
static int spi_nor_init(const struct device *dev) {
k_sem_init(&driver_data->sem, 1, K_SEM_MAX_LIMIT);
k_work_init_delayable(&driver_data->enter_dpd_work, spi_nor_enter_dpd_work);
return pm_device_driver_init(dev, spi_nor_pm_control);
static void spi_nor_pages_layout(const struct device *dev,
const struct flash_pages_layout **layout,
size_t *layout_size) {
/* Data for runtime, const for devicetree and minimal. */
*layout = &data->layout;
*layout_size = 1;
static const struct flash_parameters *
flash_nor_get_parameters(const struct device *dev) {
ARG_UNUSED(dev);
return &flash_nor_parameters;
static const struct flash_driver_api spi_nor_api = {
.read = spi_nor_read,
.write = spi_nor_write,
.erase = spi_nor_erase,
.get_parameters = flash_nor_get_parameters,
.page_layout = spi_nor_pages_layout,
.sfdp_read = spi_nor_sfdp_read,
.read_jedec_id = spi_nor_read_jedec_id,
#define GENERATE_CONFIG_STRUCT(idx) \
static const struct spi_nor_config spi_nor_##idx##_config = { \
.spi = SPI_DT_SPEC_INST_GET(idx, SPI_WORD_SET(8), CONFIG_SPI_NOR_CS_WAIT_DELAY), \
.layout = { \
.pages_count = DT_INST_PROP(idx, size) / 8 / CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE, \
.pages_size = CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE, \
.t_enter_dpd = DIV_ROUND_UP(DT_INST_PROP(idx, t_enter_dpd), NSEC_PER_MSEC), \
.t_exit_dpd = DIV_ROUND_UP(DT_INST_PROP(idx, t_exit_dpd), NSEC_PER_MSEC), \
.t_dpdd_ms = 0 \
#define ASSIGN_PM(idx) \
PM_DEVICE_DT_INST_DEFINE(idx, spi_nor_pm_control);
#define SPI_NOR_INST(idx) \
ASSIGN_PM(idx) \
static struct spi_nor_data spi_nor_##idx##_data = { \
.self = DEVICE_DT_INST_GET(idx) \
DEVICE_DT_INST_DEFINE(idx, &spi_nor_init, PM_DEVICE_DT_INST_GET(idx), \
&spi_nor_##idx##_data, &spi_nor_##idx##_config, \
POST_KERNEL, CONFIG_SPI_NOR_INIT_PRIORITY, &spi_nor_api);
DT_INST_FOREACH_STATUS_OKAY(SPI_NOR_INST)
