Zephyr Initialization of I2C and Sensor
I have a custom board with an I2C connected sensor ADXL345. I have to do GPI/O initialization to select the I2C. This works because I can read the ADXL with custom I2C commands. But the sensor driver doesn't work. Here is what I get on the console (very first message before the kernel boots):
[00:00:00.875,915] <err> ADXL345: Read PART ID failed: 0xfffffffb (0)
I know that it is a software error because I get the following messages from a direct I2C read:
[00:00:00.876,708] <inf> adxl344: Call to 'i2c_reg_read_byte_dt': address = 0x00, chip_id = 0xE6
which is the correct I2C.
Here is my board definition file:
&i2c0 {
    compatible = "nordic,nrf-twi";
    status = "okay";
    pinctrl-0 = <&i2c0_default>;
    pinctrl-1 = <&i2c0_sleep>;
    adxl344: adxl344@53 {
        compatible = "adi,adxl345";
        status = "okay";
        reg = < 0x53 >;
This is my board pre-initialization:
static int board_nrf52840dongle_nrf52840_init(void)
    nrf_gpio_cfg_output(NRF_GPIO_PIN_MAP(0, 5));
    nrf_gpio_cfg_output(NRF_GPIO_PIN_MAP(0, 27));
    nrf_gpio_pin_set(NRF_GPIO_PIN_MAP(0, 5));
    nrf_gpio_pin_clear(NRF_GPIO_PIN_MAP(0, 27));
    return 0;
SYS_INIT(board_nrf52840dongle_nrf52840_init, PRE_KERNEL_1, CONFIG_KERNEL_INIT_PRIORITY_DEFAULT);
What am I doing wrong?
    Looking at the sensor driver implementation, I see that it prints the returned error code as a hexadecimal value rather than a decimal value. I believe the error code should be -5, which corresponds to -EIO. The i2c driver will return this error if the transaction fails due to a data or address NACK. Do you have external pull-ups on the bus lines?
    It is interesting that you are able to read the ID from the device later in the boot process. Please ensure that the i2c driver is set to have a higher init priority than the adx driver by looking at the generated .config file for your application project.
    Are these the SDA and SCL lines? In that case, it should be redundant to configure them here as the pin states defined in 'i2c0_default' will be applied during initialization of the driver.
    Vidar
    EDIT: Could you also try changing the binding to nordic,nrf-twim instead of nordic,nrf-twi? This will include the driver for the TWIM (easyDMA) peripheral instead of the legacy TWI peripheral. It's not related to the problem, but I think the TWIM driver will give you are more detailed error message in case of an address or data NACK.
