We have a custom board in production, which is nRF52832, s132, nrf5 SDK.
Below I provide you some code regarding the peer manager. We use a static key to pair and connect to the devices. Usually only one device will connect to the board.
We recently have faced some issues regarding connection from our clients. The error 0x1006 from security fail event from peer manager is triggered, and the solution is always to unpair and pair again from the mobile phone. But, we cannot understand why this happens, what can trigger the bonds to be deleted? Or is there a way that we can track the reason from the event PM_EVT_PEERS_DELETE_SUCCEEDED?
The peer manager initialization:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
ret_code_t err_code;
err_code = pm_init();
hardfault = app_error_check_logger(err_code, true, log_str[PEER_MANAGER_INIT], 0, NULL);
// Security parameters to be used for all security procedures. These are common parameters for bonding.
sec_param.bond = 1;
sec_param.mitm = 0;
sec_param.lesc = 0;
sec_param.keypress = 0;
sec_param.io_caps = BLE_GAP_IO_CAPS_DISPLAY_ONLY;
sec_param.oob = 0;
sec_param.min_key_size = 7;
sec_param.max_key_size = 16;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
err_code = pm_sec_params_set(&sec_param); // sets security parameters for pairing and bonding
hardfault = app_error_check_logger(err_code, true, log_str[PEER_MANAGER_INIT], 1, NULL);
err_code = pm_register(pm_evt_handler); // register an event handler for the module
hardfault = app_error_check_logger(err_code, true, log_str[PEER_MANAGER_INIT], 2, NULL);
The peer manager event handler :
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt); // Logging peer events. Starts encryption if connected to a bonded device.
pm_handler_disconnect_on_sec_failure(p_evt); // Disconnects if the connection was not secured.
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
case PM_EVT_CONN_SEC_SUCCEEDED: //a link has been encrypted, result of a call of pm_conn_secure or of an action by the peer.
m_peer_id = p_evt->peer_id;
pm_local_database_has_changed();
case PM_EVT_PEERS_DELETE_SUCCEEDED: // a peer was cleared from flash storage (result of pm_peer_delete)
NRF_LOG_INFO("PM_EVT_PEERS_DELETE_SUCCEEDED");
hardfault = app_error_check_logger(1, false, "peersdel", 1, NULL);
advertising_start(false);
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED: // a piece of peer data was tored, updated or cleared in flash storage.
if ( p_evt->params.peer_data_update_succeeded.flash_changed
&& (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
NRF_LOG_INFO("New Bond. Peer data update succeeded.");
case PM_EVT_CONN_SEC_FAILED: // a pairing or encryption procedure has failed. in some cases, this means that security is not possible on this link.
NRF_LOG_INFO("Pairing or Encryption procedure failed. Peer id=%d, Error=%x, Procedure=%d, Source=%d", p_evt->peer_id, p_evt->params.conn_sec_failed.error,
p_evt->params.conn_sec_failed.procedure,p_evt->params.conn_sec_failed.error_src);
uint8_t proc=0;
if(p_evt->params.conn_sec_failed.error_src == 1)
proc = p_evt->params.conn_sec_failed.procedure + 10;
proc = p_evt->params.conn_sec_failed.procedure;
hardfault = app_error_check_logger(p_evt->params.conn_sec_failed.error, false, "secfail", proc, NULL);
m_scoliosense.err_code = p_evt->params.conn_sec_failed.error;
ble_error_sec_update(m_conn_handle, &m_scoliosense);
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Allow or reject pairing request from an already bonded peer.
NRF_LOG_INFO("Repairing Process was initiated.");
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = true};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
Any help is much appreciated!
Dimitra
