Issue with TLS on nRF7002DK
I believe I'm having a similar issue to this ticket  nRF7002DK and TLS Sockets -7100 error
[00:00:23.640,411] <err> net_sock_tls: TLS handshake error: -0x2700
[00:00:23.649,475] <err> mqtt_helper: mqtt_connect, error: -113
[00:00:23.649,475] <err> aws_iot: mqtt_helper_connect, error: -113
[00:00:23.649,475] <err> beacon_v3: aws_iot_connect, error: -113
I'm trying to connect to AWS IoT Core with an nRF7002DK by basing my work on the AWS IoT sample. I'm building the project for the nrf7002dk/nrf5340/cpuapp/ns target with NCS version 2.7.0. I'm adding the AWS Root CA 1 like this
err = tls_credential_add(CONFIG_MQTT_HELPER_SEC_TAG, TLS_CREDENTIAL_CA_CERTIFICATE,
				 ca_certificate, sizeof(ca_certificate));
	if (err < 0) {
		LOG_ERR("Failed to register public certificate: %d", err);
		return err;
and the certificate is defined in a header file like this:
static const unsigned char ca_certificate[] = { \
"-----BEGIN CERTIFICATE-----\n"\
"MIIDQTCCAimgAwIBAgITBmyfz5m/jAo54vB4ikPmljZbyjANBgkqhkiG9w0BAQsF\n" \
"ADA5MQswCQYDVQQGEwJVUzEPMA0GA1UEChMGQW1hem9uMRkwFwYDVQQDExBBbWF6\n" \
"b24gUm9vdCBDQSAxMB4XDTE1MDUyNjAwMDAwMFoXDTM4MDExNzAwMDAwMFowOTEL\n" \
"MAkGA1UEBhMCVVMxDzANBgNVBAoTBkFtYXpvbjEZMBcGA1UEAxMQQW1hem9uIFJv\n" \
"b3QgQ0EgMTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBALJ4gHHKeNXj\n" \
"ca9HgFB0fW7Y14h29Jlo91ghYPl0hAEvrAIthtOgQ3pOsqTQNroBvo3bSMgHFzZM\n" \
"9O6II8c+6zf1tRn4SWiw3te5djgdYZ6k/oI2peVKVuRF4fn9tBb6dNqcmzU5L/qw\n" \
"IFAGbHrQgLKm+a/sRxmPUDgH3KKHOVj4utWp+UhnMJbulHheb4mjUcAwhmahRWa6\n" \
"VOujw5H5SNz/0egwLX0tdHA114gk957EWW67c4cX8jJGKLhD+rcdqsq08p8kDi1L\n" \
"93FcXmn/6pUCyziKrlA4b9v7LWIbxcceVOF34GfID5yHI9Y/QCB/IIDEgEw+OyQm\n" \
"jgSubJrIqg0CAwEAAaNCMEAwDwYDVR0TAQH/BAUwAwEB/zAOBgNVHQ8BAf8EBAMC\n" \
"AYYwHQYDVR0OBBYEFIQYzIU07LwMlJQuCFmcx7IQTgoIMA0GCSqGSIb3DQEBCwUA\n" \
"A4IBAQCY8jdaQZChGsV2USggNiMOruYou6r4lK5IpDB/G/wkjUu0yKGX9rbxenDI\n" \
"U5PMCCjjmCXPI6T53iHTfIUJrU6adTrCC2qJeHZERxhlbI1Bjjt/msv0tadQ1wUs\n" \
"N+gDS63pYaACbvXy8MWy7Vu33PqUXHeeE6V/Uq2V8viTO96LXFvKWlJbYK8U90vv\n" \
"o/ufQJVtMVT8QtPHRh8jrdkPSHCa2XV4cdFyQzR1bldZwgJcJmApzyMZFo6IQ6XU\n" \
"5MsI+yMRQ+hDKXJioaldXgjUkK642M4UwtBV8ob2xJNDd2ZhwLnoQdeXeGADbkpy\n" \
"rqXRfboQnoZsG4q5WTP468SQvvG5\n" \
"-----END CERTIFICATE-----"
so I'm pretty sure it's not an issue of the certificate being wrong. I'm also adding the private key and device certificate.
My prj.conf file is
# CONFIG_HEAP_MEM_POOL_SIZE=120000
CONFIG_WIFI=y
CONFIG_WIFI_NRF700X=y
# CONFIG_WIFI_MGMT_EXT=y
CONFIG_WIFI_CREDENTIALS=y
CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
# WPA supplicant
CONFIG_WPA_SUPP=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
CONFIG_MBEDTLS_RSA_C=y
CONFIG_BASE64=y
CONFIG_MQTT_LIB_TLS=y
CONFIG_AWS_IOT=y
CONFIG_AWS_IOT_CLIENT_ID_STATIC="test-bcn3"
CONFIG_AWS_IOT_BROKER_HOST_NAME="sample.com"
# CONFIG_AWS_IOT_SEC_TAG=1
CONFIG_MQTT_HELPER_SEC_TAG=200
CONFIG_MQTT_HELPER_PROVISION_CERTIFICATES=n
CONFIG_NET_LOG=n
CONFIG_NET_IPV4=y
CONFIG_NET_UDP=y
CONFIG_NET_TCP=y
CONFIG_NET_DHCPV4=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=y
CONFIG_NET_L2_PPP=y
CONFIG_NET_IPV4=y
CONFIG_NET_UDP=y
CONFIG_NET_CONTEXT_RCVTIMEO=y
CONFIG_NET_INTERFACE_NAME=y
# DNS
CONFIG_DNS_RESOLVER=y
CONFIG_NET_L2_PPP_OPTION_DNS_USE=y
# Network management
CONFIG_NET_MGMT=y
CONFIG_NET_MGMT_EVENT=y
CONFIG_NET_CONNECTION_MANAGER=y
CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=2
CONFIG_NET_MAX_CONTEXTS=8
CONFIG_NET_CONTEXT_SYNC_RECV=y
CONFIG_INIT_STACKS=y
CONFIG_NET_L2_ETHERNET=y
CONFIG_NET_CONFIG_SETTINGS=y
CONFIG_NET_CONFIG_INIT_TIMEOUT=0
CONFIG_NET_SOCKETS_POLL_MAX=10
# Memories
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_NET_TX_STACK_SIZE=4096
CONFIG_NET_RX_STACK_SIZE=4096
# Kernel options
CONFIG_ENTROPY_GENERATOR=y
# Benchmarking
CONFIG_POSIX_MAX_FDS=16
CONFIG_BT=y
CONFIG_BT_SMP=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_MAX_CONN=2
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
CONFIG_BT_THROUGHPUT=y
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
CONFIG_BT_BUF_ACL_RX_SIZE=502
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_CONN_TX_MAX=10
CONFIG_BT_L2CAP_TX_BUF_COUNT=10
CONFIG_BT_L2CAP_TX_MTU=498
CONFIG_BT_BUF_ACL_TX_SIZE=502
CONFIG_BT_L2CAP_DYNAMIC_CHANNEL=y
CONFIG_NRF700X_MAX_TX_PENDING_QLEN=12
CONFIG_NRF700X_QSPI_LOW_POWER=n
#Added to fix BLE crash in coex enable cases.
CONFIG_NRF_RPC=n
CONFIG_NRF_RPC_CBOR=n
# CONFIG_POSIX_API=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
# Logging
CONFIG_LOG=y
CONFIG_NET_LOG=y
CONFIG_WIFI_LOG_LEVEL_DBG=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_BEACON_V3_LOG_LEVEL_INF=y
and my nrf7002dk_nrf5340_cpuapp_ns.conf file is
# Copyright (c) 2024 Nordic Semiconductor ASA
CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
# Using hardware crypto accelerator
CONFIG_MBEDTLS_HEAP_SIZE=81920
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
# TLS credentials
CONFIG_TLS_CREDENTIALS_BACKEND_PROTECTED_STORAGE=y
# Native network stack
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
# NET Sockets
CONFIG_NET_SOCKETS_TLS_MAX_CONTEXTS=2
If I try to implement the workaround in the ticket I referenced above, my project doesn't build due to some config dependency errors. Is this still a known issue? Or was it fixed sometime between 2.4.0 and 2.7.0?
    Have you built the AWS IoT sample for nrf7002dk/nrf5340/cpuapp/ns board target?
    Have you followed the setup guide and read the Note in the same setup section which specifies that for nrf70 devices certificates must be provisioned at runtime?
    Documentation provides information how to generate and provision certificates for nrf70 devices.
    Dejan
  • Yes I followed all those instructions. I placed the raw .pem files in the certs directory of the AWS IoT Sample, built and ran, and now I get
    [00:00:48.535,827] <err> mqtt_helper: mqtt_connect, error: -2
    [00:00:48.544,433] <err> aws_iot: mqtt_helper_connect, error: -2
    [00:00:48.553,314] <err> aws_iot_sample: aws_iot_connect, error: -2
    [00:00:48.562,438] <err> aws_iot_sample: Fatal error! Rebooting the device.
    Edit: I figured out that I had my CONFIG_MQTT_HELPER_CERTIFICATES_FOLDER variable set incorrectly. However, now I'm getting the same error that I had initially.
    I see that you initially got
    and now you are getting
    What do you refer to as "getting the same error"? Could you please clarify this?
    Could you provide complete log?
    Dejan
  • By getting the same error, I mean that I'm getting mqtt_connect, error: -113. Here's the entire log:
    *** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
    *** Using Zephyr OS v3.6.99-100befc70c74 ***
    [00:00:00.261,260] <inf> aws_iot_sample: The AWS IoT sample started, version: v1.0.0
    [00:00:00.271,636] <inf> aws_iot_sample: Bringing network interface up and connecting to the network
    [00:00:00.289,581] <dbg> mqtt_helper: mqtt_helper_poll_loop: Waiting for connection_poll_sem
    [00:00:00.338,867] <inf> wifi_mgmt_ext: Connection requested
    [00:00:00.354,278] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
    uart:~$ > wifi connect -s ssid -p pw -k 1
    Connected
    [00:00:11.434,204] <inf> aws_iot_sample: Network connectivity established
    [00:00:16.443,664] <inf> aws_iot_sample: Connecting to AWS IoT
    [00:00:16.452,362] <dbg> mqtt_helper: broker_init: Resolving IP address for iot.dev.slatesafety.com
    [00:00:16.560,272] <dbg> mqtt_helper: broker_init: IPv4 Address found 52.54.218.138 (AF_INET)
    [00:00:16.571,441] <inf> mqtt_helper: Provision cert success
    [00:00:16.579,742] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_DISCONNECTED --> MQTT_STATE_TRANSPORT_CONNECTING
    [00:00:17.064,300] <err> mqtt_helper: mqtt_connect, error: -113
    [00:00:17.073,089] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_TRANSPORT_CONNECTING --> MQTT_STATE_DISCONNECTED
    [00:00:17.087,554] <err> aws_iot: mqtt_helper_connect, error: -113
    [00:00:17.096,588] <err> aws_iot_sample: aws_iot_connect, error: -113
    [00:00:17.105,926] <err> aws_iot_sample: Fatal error! Rebooting the device.
    Looking at the mbedtls Github, I see that -0x2700 means
    /** Certificate verification failed, e.g. CRL, CA or signature check failed. */
    #define MBEDTLS_ERR_X509_CERT_VERIFY_FAILED               -0x2700
    If I change
    tls_cfg->peer_verify	        = TLS_PEER_VERIFY_REQUIRED;
    to
    tls_cfg->peer_verify	        = TLS_PEER_VERIFY_NONE;
    the sample is able to connect to the MQTT broker successfully. So I know that the issue concerns the CA certificate. I've thought of a few possible root causes:
    1. The CA certificate is formatted incorrectly
    2. My sample is missing some crypto config variable being set
    3. There's not enough heap memory for the TLS operations
    I think 1 is unlikely because I included the raw PEM files in my certs directory. They're formatted the same as my device certificate and private key and I'm able to connect to the server and publish messages.
    I think 3 is unlikely because I have set
    CONFIG_MBEDTLS_HEAP_SIZE=120000
    which should be plenty of space. I'll include the entire config files that I'm using for the AWS IoT sample.
    # Copyright (c) 2023 Nordic Semiconductor ASA
    # Configuration file for nRF7002 DK
    # This file is merged with prj.conf in the application folder, and options
    # set here will take precedence if they are present in both files.
    # General
    CONFIG_POSIX_CLOCK=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_HEAP_MEM_POOL_SIZE=81920
    CONFIG_LOG_MODE_IMMEDIATE=y
    CONFIG_HW_STACK_PROTECTION=y
    CONFIG_HW_ID_LIBRARY_SOURCE_NET_MAC=y
    CONFIG_POSIX_MAX_FDS=25
    # Optimize Wi-Fi stack to save some memory
    CONFIG_NRF700X_RX_NUM_BUFS=16
    CONFIG_NRF700X_MAX_TX_AGGREGATION=4
    # Wi-Fi
    CONFIG_WIFI=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    # Shell
    CONFIG_SHELL=y
    CONFIG_SHELL_STACK_SIZE=6144
    # WPA
    CONFIG_WPA_SUPP=y
    # NET sockets
    CONFIG_NET_UDP=y
    CONFIG_NET_TCP=y
    CONFIG_NET_SOCKETS_OFFLOAD=n
    CONFIG_NET_DHCPV4=y
    CONFIG_NET_CONTEXT_SNDTIMEO=y
    CONFIG_NET_RX_STACK_SIZE=2048
    # DNS
    CONFIG_NET_SOCKETS_DNS_TIMEOUT=30000
    # Make the MQTT helper library provision credentials prior to establishing a TLS connection.
    # Credentials needs to be pasted into their respective entry under samples/net/aws_iot/certs/.
    CONFIG_MQTT_HELPER_PROVISION_CERTIFICATES=y
    CONFIG_MBEDTLS=y
    # NET Sockets
    # Zephyr NET Connection Manager Connectivity layer.
    CONFIG_L2_WIFI_CONNECTIVITY=y
    CONFIG_L2_WIFI_CONNECTIVITY_AUTO_CONNECT=n
    CONFIG_L2_WIFI_CONNECTIVITY_AUTO_DOWN=n
    # Serial Peripheral Interface (SPI) - Used to communicate with the mx25r64 external flash memory.
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_SPI_NOR_SFDP_DEVICETREE=y
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    # Bootloader and FOTA related configurations
    # MCUBOOT
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    # Image manager
    CONFIG_IMG_MANAGER=y
    CONFIG_STREAM_FLASH=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # AWS FOTA
    CONFIG_AWS_FOTA=y
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_DFU_TARGET=y
    # Download client (needed by AWS FOTA)
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=4096
    CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_4096=y
    # TLS credentials
    # CONFIG_TLS_CREDENTIALS_BACKEND_PROTECTED_STORAGE=y
    # Optimize TF-M
    CONFIG_TFM_PROFILE_TYPE_SMALL=y
    CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0xc000
    CONFIG_PM_PARTITION_SIZE_TFM=0x1fe00
    and prj.conf
    # Copyright (c) 2020 Nordic Semiconductor ASA
    # General
    CONFIG_LOG=y
    CONFIG_LOG_BUFFER_SIZE=2048
    CONFIG_HW_ID_LIBRARY=y
    CONFIG_ASSERT=y
    CONFIG_JSON_LIBRARY=y
    CONFIG_REBOOT=y
    # Heap and stacks
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_L2_WIFI_SHELL=y
    # AWS IoT library
    CONFIG_AWS_IOT=y
    CONFIG_MQTT_HELPER_SEC_TAG=301
    CONFIG_MQTT_HELPER_CERTIFICATES_FOLDER="src/certs"
    CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y
    CONFIG_AWS_IOT_TOPIC_GET_ACCEPTED_SUBSCRIBE=y
    CONFIG_AWS_IOT_TOPIC_GET_REJECTED_SUBSCRIBE=y
    CONFIG_MBEDTLS_SERVER_NAME_INDICATION=y
    # MQTT helper library
    CONFIG_MQTT_HELPER=y
    CONFIG_MQTT_HELPER_LAST_WILL=y
    CONFIG_MQTT_HELPER_STACK_SIZE=4096
    CONFIG_MQTT_HELPER_LOG_LEVEL_DBG=y
    # MQTT - Maximum MQTT keepalive timeout specified by AWS IoT Core
    CONFIG_MQTT_KEEPALIVE=1200
    CONFIG_MQTT_CLEAN_SESSION=y
    To check ca_certificate[], you could try to specify your ca_certificate[] as mentioned in the lesson 5 of Wi-Fi Fundamentals course. When you do that, do you still get the same error -113?
    Dejan
