Hello All,
I am having issues using the Async zephyr API to control the UART. I am using the Seeed studio xiao nrf52480 sense board.
I have followed a couple of nordic tutorials and using the sample nordic code and both give me the same following error:
The uart_callback_set function give me the error -88 which is a ENOSYS, function is not implemented.
Looking into the source code I see this:
In terms of configuration in the proj.conf I have also included the two below lines (as stated by many tutorial):
* Copyright (c) 2016 Intel Corporation
/* Controlling LEDs through UART. Press 1-3 on your keyboard to toggle LEDS 1-3 on your development
* kit */
#include <zephyr/kernel.h>
#include <zephyr/device.h>
/* STEP 3 - Include the header file of the UART driver in main.c */
#include <zephyr/drivers/uart.h>
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS 1000
/* STEP 10.1.1 - Define the size of the receive buffer */
#define RECEIVE_BUFF_SIZE 10
/* STEP 10.2 - Define the receiving timeout period */
#define RECEIVE_TIMEOUT 100
/* STEP 5.1 - Get the device pointers of the LEDs through gpio_dt_spec */
/* The nRF7002dk has only 2 LEDs so this step uses a compile-time condition to reflect the DK you
* are building for */
#if defined(CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP) || \
defined(CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP_NS)
static const struct gpio_dt_spec led0 = GPIO_DT_SPEC_GET(DT_ALIAS(led0), gpios);
static const struct gpio_dt_spec led1 = GPIO_DT_SPEC_GET(DT_ALIAS(led1), gpios);
#else
static const struct gpio_dt_spec led2 = GPIO_DT_SPEC_GET(DT_ALIAS(led2), gpios);
/* STEP 4.1 - Get the device pointer of the UART hardware */
const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart0));
/* STEP 9.1 - Define the transmission buffer, which is a buffer to hold the data to be sent over
* UART */
static uint8_t tx_buf[] = {
"nRF Connect SDK Fundamentals Course\r\n"
"Press 1-3 on your keyboard to toggle LEDS 1-3 on your development kit\r\n"};
/* STEP 10.1.2 - Define the receive buffer */
static uint8_t rx_buf[RECEIVE_BUFF_SIZE] = {0};
/* STEP 7 - Define the callback function for UART */
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
switch (evt->type) {
case UART_RX_RDY:
if ((evt->data.rx.len) == 1) {
if (evt->data.rx.buf[evt->data.rx.offset] == '1') {
gpio_pin_toggle_dt(&led0);
} else if (evt->data.rx.buf[evt->data.rx.offset] == '2') {
gpio_pin_toggle_dt(&led1);
#else
} else if (evt->data.rx.buf[evt->data.rx.offset] == '3') {
gpio_pin_toggle_dt(&led2);
case UART_RX_DISABLED:
uart_rx_enable(dev, rx_buf, sizeof rx_buf, RECEIVE_TIMEOUT);
int ret;
/* STEP 4.2 - Verify that the UART device is ready */
if (!device_is_ready(uart)) {
printk("UART device not ready\n");
return 1;
/* STEP 5.2 - Verify that the LED devices are ready */
if (!device_is_ready(led0.port)) {
printk("GPIO device is not ready\n");
return 1;
/* STEP 6 - Configure the GPIOs of the LEDs */
ret = gpio_pin_configure_dt(&led0, GPIO_OUTPUT_ACTIVE);
if (ret < 0) {
return 1;
ret = gpio_pin_configure_dt(&led1, GPIO_OUTPUT_ACTIVE);
if (ret < 0) {
return 1;
#else
if (ret < 0) {
return 1;
if (ret < 0) {
return 1;
ret = gpio_pin_configure_dt(&led2, GPIO_OUTPUT_ACTIVE);
if (ret < 0) {
return 1;
k_msleep(SLEEP_TIME_MS*3);
printk("System Working\n");
/* STEP 8 - Register the UART callback function */
ret = uart_callback_set(uart, uart_cb, NULL);
if (ret) {
printk("Error with uart_callback_set: %d\n", ret);
return 1;
/* STEP 9.2 - Send the data over UART by calling uart_tx() */
ret = uart_tx(uart, tx_buf, sizeof(tx_buf), SYS_FOREVER_MS);
if (ret) {
printk("Error with uart_tx: %d\n", ret);
return 1;
/* STEP 10.3 - Start receiving by calling uart_rx_enable() and pass it the address of the
* receive buffer */
ret = uart_rx_enable(uart, rx_buf, sizeof rx_buf, RECEIVE_TIMEOUT);
if (ret) {
printk("Error with uart_rx_enable: %d\n", ret);
return 1;
while (1) {
k_msleep(SLEEP_TIME_MS);
printk("System working in the loop\n");
