About NUS connection
I have implemented NUS on device A and confirmed that it can be connected from a PC by making it the advertising sender.
Device B can scan device A's advertisements and obtain values ​​from the advertisement data.
I would like to add an NUS function to device B so that device B can search for a specific Bluetooth ID from the advertisement and set it on device A via an NUS connection.
I am currently adding NUS_C to device B and trying to run it, but ble_nus_c_init() returns 14.
Please tell me what to do.
  • I solved the above post myself, but a new problem has arisen.
    I am trying to perform a BLE scan, find the specified Bluetooth ID, and perform an NUS connection.
    When I execute sd_ble_gap_connect, it returns 8, so I added sd_ble_gap_scan_stop before sd_ble_gap_connect, but sd_ble_gap_scan_stop also returns 8.
    The Scan event function is as follows.
    void scan_evt_handler(scan_evt_t const * p_scan_evt)
        switch (p_scan_evt->scan_evt_id)
            case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                NRF_LOG_INFO("Scan timeout.");
            case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                NRF_LOG_ERROR("Connection error.");
            case NRF_BLE_SCAN_EVT_CONNECTED:
                NRF_LOG_INFO("Connected to device.");
            case NRF_BLE_SCAN_EVT_FILTER_MATCH:
                // アドバタイジングレポートを取得
                ble_gap_evt_adv_report_t const * p_adv_report = p_scan_evt->params.filter_match.p_adv_report;
                // アドバタイジングデータを取得
                const uint8_t * p_data = p_adv_report->data.p_data; // ble_data_t から p_data を取得
                uint16_t data_len = p_adv_report->data.len; // ble_data_t からデータ長を取得
                // デバイス名の取得
                char device_name[BLE_GAP_DEVNAME_MAX_LEN + 1]; // デバイス名用のバッファ
                memset(device_name, 0, sizeof(device_name)); // バッファをクリア
                // アドバタイジングデータからデバイス名を探す
                uint8_t * p_name_data = ble_advdata_parse((uint8_t *)p_data, data_len, BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME);
                if (p_name_data != NULL)
                    // デバイス名の長さを取得
                    uint8_t name_len = strlen((const char *)p_name_data);
    //                if(name_len > 6)
    //                    break;
    //                if (name_len > BLE_GAP_DEVNAME_MAX_LEN) {
    //                    name_len = BLE_GAP_DEVNAME_MAX_LEN; // 長さが最大を超えないようにする
                    strncpy(device_name, (char *)p_name_data, name_len);
                    device_name[name_len] = '\0'; // NULL で終端
                    device_name[6] = '\0';
                    // デバイス名が一致する場合、接続を開始
                    if (strcmp(device_name, TARGET_DEVICE_NAME) == 0)
                        // 接続先デバイスのアドレスを設定
                        ble_gap_addr_t addr;
                        addr.addr_id_peer = 0; // プライベートアドレスでない場合は0
                        addr.addr_type = p_adv_report->peer_addr.addr_type; // アドレスのタイプを設定
                        memcpy(addr.addr, p_adv_report->peer_addr.addr, BLE_GAP_ADDR_LEN); // アドレスをコピー
                        // スキャンパラメータの初期化
                        ble_gap_scan_params_t scan_params;
                        memset(&scan_params, 0, sizeof(scan_params)); // ゼロ初期化
                        scan_params.extended = 0; // 拡張スキャンを使用しない場合は0
                        scan_params.active = 1; // アクティブスキャンを有効にする
                        scan_params.report_incomplete_evts = 0; // 不完全なイベントを報告しない
                        scan_params.scan_phys = BLE_GAP_PHY_1MBPS; // スキャンするPHYを設定
                        scan_params.interval = MSEC_TO_UNITS(100, UNIT_1_25_MS); // スキャン間隔を設定
                        scan_params.window = MSEC_TO_UNITS(50, UNIT_1_25_MS); // スキャンウィンドウを設定
                        scan_params.timeout = 0; // タイムアウトなし
                        // 接続パラメータの初期化
                        ble_gap_conn_params_t conn_params;
                        memset(&conn_params, 0, sizeof(conn_params)); // ゼロ初期化
                        conn_params.min_conn_interval = MIN_CONN_INTERVAL; // 最小接続間隔
                        conn_params.max_conn_interval = MAX_CONN_INTERVAL; // 最大接続間隔
                        conn_params.slave_latency = SLAVE_LATENCY; // スレーブレイテンシ
                        conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT; // 接続スーパーバイスタイムアウト
                        // スキャンを停止
                        uint32_t err_code = sd_ble_gap_scan_stop();
                        if (err_code != NRF_SUCCESS){
                            // スキャン停止のエラーハンドリング
                        // 接続を開始
                        err_code = sd_ble_gap_connect(&addr, &scan_params, &conn_params, con_cfg_tag);
                            // エラーハンドリング
    I see you are using the nRF5 SDK. That incldues the Nordic UART Service Client example, which is a Central and does what you describe here (this works together with the UART/Serial Port Emulation over BLE peripehral example).
    Regardign the -8 error you get, that is NRF_ERROR_INVALID_STATE. And you typically get this from sd_ble_gap_connect() if a connection is allready in progress. You will also get this error cod eif you call sd_ble_gap_scan_stop when it is not scanning (if you just wanted to terminate scanning if active you can shoose to ignore this error code, for instance by only calling APP_ERROR_CHECK if the error is different from NRF_ERROR_INVALID_STATE).
    But as the description you have match well with the central NUS example linked above, I suggest you test with this first and either base your client on that or copy-past the relevant parts into your application as that i a known working implementation.
  • Thank you for your answer.
    By adding UART initialization, the NRF_ERROR_INVALID_STATE problem is resolved.
    However, when I execute err_code2 = sd_ble_gap_connect(&addr, &scan_params, &conn_params, con_cfg_tag);, 0x05 (NRF_ERROR_NOT_FOUND) is returned and I cannot connect.
    What could be the cause?
            case BLE_GAP_EVT_ADV_REPORT:
                // Get Advertising Report
                // Get advertising data
                const uint8_t * p_data = p_adv_report->data.p_data; // Get p_data from ble_data_t
                uint16_t data_len = p_adv_report->data.len; 		// Get the data length from ble_data_t
                // Get Device Name
                char device_name[BLE_GAP_DEVNAME_MAX_LEN + 1]; 		// A buffer for the device name
                memset(device_name, 0, sizeof(device_name)); 		// Clear the buffer
                // Finding device names from advertising data
                    // Get the length of the device name
                    device_name[name_len] = '\0'; 					// NULL terminated
                    // If the device names match, the connection is initiated.
                        // Set the address of the destination device
                        Name_acquisition_flag = 1;
                        addr.addr_id_peer = 0; 												// 0 if not a private address
                        addr.addr_type = p_adv_report->peer_addr.addr_type; 				// Set the address type (0x01)
                        memcpy(addr.addr, p_adv_report->peer_addr.addr, BLE_GAP_ADDR_LEN); 	// Copy address
                        // Initialize scan parameters
                        memset(&scan_params, 0, sizeof(scan_params)); 						// Zero Initialization
                        scan_params.extended = 0; 											// 0 if you do not want to use extended scanning
                        scan_params.active = 1; 											// Enable Active Scanning
                        scan_params.report_incomplete_evts = 0; 							// Do not report incomplete events
                        scan_params.scan_phys = BLE_GAP_PHY_1MBPS; 							// Back PHY and feeling  (0x01)
                        scan_params.interval = 160; 										// Set the scan interval
                        scan_params.window = 72; 											// Set the scan window
                        scan_params.timeout = 0; 											// No timeout
                        // Initializing connection parameters
                        memset(&conn_params, 0, sizeof(conn_params)); 						// Zero Initialization
                        conn_params.min_conn_interval = MIN_CONN_INTERVAL; 					// Minimum Connection Interval (160)
                        conn_params.max_conn_interval = MAX_CONN_INTERVAL; 					// Maximum Connection Interval (320)
                        conn_params.slave_latency = SLAVE_LATENCY; 							// Slave Latency  (0)
                        conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT; 					// Connection Supervision Timeout (MSEC_TO_UNITS(4000, UNIT_10_MS)
                        int attempts = 0;
    //                    if (is_scanning)
    //                        err_code2 = sd_ble_gap_scan_stop();
    //                        if (err_code2 != NRF_SUCCESS)
    //                            is_scanning = true;
    //                        else
    //                            is_scanning = false;
                        // Start a connection
                        if (!is_connected)
                            nrf_delay_ms(200);
                            if(err_code2 == NRF_ERROR_NOT_FOUND)
                                for(int i = 0 ; i < 5 ; i++)
                                    nrf_delay_ms(1000);
                                    if(err_code2 == 0)
                            is_connected = true;
    sd_ble_gap_connect() will return NRF_ERROR_NOT_FOUND if conn_cfg_tag (the last parameter) cannot be found. Which value did you set it to, and did you call nrf_sdh_ble_default_cfg_set with that value (search for APP_BLE_CONN_CFG_TAG in the SDK to see examples of this)?
