spi handler never called
Hello. Since i migrated from 1 to 2 SPI bus, IRQ Handler at completion is not called. Can I use 2 easy DMA SPI ?
1 bus was working fine.
here is my config
/* SPI */
#define SPI0_ENABLED 1
#if (SPI0_ENABLED == 1)
#define SPI0_USE_EASY_DMA 1
#define SPI0_CONFIG_SCK_PIN         MPU9250_SCL_PIN_NUMBER
#define SPI0_CONFIG_MOSI_PIN        MPU9250_MOSI_PIN_NUMBER
#define SPI0_CONFIG_MISO_PIN        MPU9250_MISO_PIN_NUMBER
#define SPI0_CONFIG_IRQ_PRIORITY    APP_IRQ_PRIORITY_HIGH
#define SPI0_INSTANCE_INDEX 0
#define SPI1_ENABLED 1
#if (SPI1_ENABLED == 1)
#define SPI1_USE_EASY_DMA 1
#define SPI1_CONFIG_SCK_PIN         SCREEN_SCL_PIN_NUMBER
#define SPI1_CONFIG_MOSI_PIN        SCREEN_SI_PIN_NUMBER
#define SPI1_CONFIG_MISO_PIN        NRF_DRV_SPI_PIN_NOT_USED
#define SPI1_CONFIG_IRQ_PRIORITY    APP_IRQ_PRIORITY_LOW
#define SPI1_INSTANCE_INDEX (SPI0_ENABLED)
