HI there,
I'm a bit confused with how the Data Mode would work for receiving data.
Our setup / situation:
- UART connection with the nRF9160
- Regular AT commands work good.
- Creating a secure MQTT connection to AWS using AT-mode, XSOCKET and XSEND / XRECV kinda works --> The part that doesn't work is receiving published data by the MQTT server because we are not listening all the time
Because of this I was thinking to use the data mode of the nRF, however I'm not quite sure what to expect as the documentation only talks in detail about sending data.
- What can I expect to receive over UART when the nRF receives data and it is in data mode?
- Will it just put the data on the UART? Or do I need to do a XRECV anyway?
- Is the data followed or prefixed by something (like \r\nOK\r\n?)
- I've set
CONFIG_SLM_DATAMODE_URC=y ,but from my understanding/experience this will only send an URC when I've sent data to the nRF modem, not when the nRF modem has completed a sent towards my MCU. - I've looked at the MQTT client , but this doesn't look like a solution for us as we can only read the MQTT certificate from the security chip from our device, the nRF would be an add-on with only UART connections + some pins.
Thank you in advance!
