I am attempting to implement the TWI drivers from the SDK for a nrf52832 chip for a pca10040 board. I am using the twi_hw_master files to drive my TWI and insofar I have been unable to implement it because I am having the following issue when building:
twi_hw_master.c:53:21: error: 'NRF_TWI_Type {aka struct <anonymous>}' has no member named 'POWER'
That particular Struct is defined in the nrf52.h file. As far as I can tell this is entirely true and there actually is no member called POWER in NRF_TWI_Type, only in :
typedef struct {
__IO uint32_t POWER; /*!< Description cluster[0]: RAM0 power control register */
__O uint32_t POWERSET; /*!< Description cluster[0]: RAM0 power control set register */
__O uint32_t POWERCLR; /*!< Description cluster[0]: RAM0 power control clear register */
__I uint32_t RESERVED0;
} POWER_RAM_Type;
Also, I am getting the following popup when I try to open declaration:
(the path covered in red is exactly the same in both instances)
Is it possible I am including the file nrf52.h twice?
Can anyone lend a hand?
Thanks in advance!
