mesh dfu timeout
Hello
I'm exploring the mesh dfu transfer, get some strange results
Here is the setup
1 distributor, 1 target
On the distributor I start  the transfer with mesh models dfd start 0 0 command
In about 40 minutes it completes, and the image is applied but I get a timeout message on the distributor side
However on the target I see a message from the mcuboot that the new message was applied successfully - and actually it is working just fine
Log from the distributor and the target below
Another question
The progress in the JSON below is "50" which I think is because the function that calculates progress divides by 2:
Function cmd_dfd_receivers_get()  in dfd.c  has this lihe
uint8_t progress = bt_mesh_dfu_cli_progress(&dfd_srv->dfu) / 2;
However if I use
mesh models dfu cli progress command it returns
DFU progress: 100 %
Bug?
Thank you
Andy
Logs
Distributor
rtt:~$ [00:40:51.061,126] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
rtt:~$ [00:40:51.061,157] <dbg> bt_mesh_dfu_cli: dfu_complete:
rtt:~$ [00:40:51.061,187] <dbg> bt_mesh_dfd_srv: dfu_ended: reason: 0, phase: 1, apply: 1
rtt:~$ Distribution phase changed to Applying Update
rtt:~$ [00:40:51.061,218] <dbg> bt_mesh_dfu_cli: apply:
rtt:~$ rtt:~$ [00:40:51.061,248] <dbg> bt_mesh_blob_cli: blob_cli_broadcast: 1 targets
rtt:~$ rtt:~$ [00:40:51.271,606] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 6, cur state: 4
rtt:~$ [00:40:51.271,636] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x01a2 receiving transfer
rtt:~$ rtt:~$ [00:41:00.282,928] <dbg> bt_mesh_blob_cli: retry_timeout: 5
rtt:~$ rtt:~$ [00:41:09.441,864] <dbg> bt_mesh_blob_cli: retry_timeout: 4
rtt:~$ rtt:~$ [00:41:18.604,400] <dbg> bt_mesh_blob_cli: retry_timeout: 3
rtt:~$ rtt:~$ [00:41:27.766,143] <dbg> bt_mesh_blob_cli: retry_timeout: 2
rtt:~$ rtt:~$ [00:41:36.924,011] <dbg> bt_mesh_blob_cli: retry_timeout: 1
rtt:~$ [00:41:36.924,041] <dbg> bt_mesh_blob_cli: retry_timeout: Transfer timed out.
rtt:~$ [00:41:36.924,041] <dbg> bt_mesh_blob_cli: drop_remaining_targets:
rtt:~$ [00:41:36.924,072] <wrn> bt_mesh_blob_cli: Dropping 0x01a2: 9
rtt:~$ [00:41:36.924,072] <err> bt_mesh_dfu_cli: Target 0x01a2 failed: 3
rtt:~$ [00:41:36.924,102] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
rtt:~$ [00:41:36.924,102] <dbg> bt_mesh_dfu_cli: dfu_failed: 3
rtt:~$ [00:41:36.924,133] <dbg> bt_mesh_dfd_srv: dfu_ended: reason: 3, phase: 3, apply: 1
rtt:~$ Distribution phase changed to Failed
rtt:~$ rtt:~$ mesh models dfd receivers-get 0 1
"target_cnt": 1,
"targets": {
"0": { "blob_addr": 418, "phase": 6, "status": 3, "blob_status": 9, "progress": 50, "img_idx": 0 }
Target
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
Current image version: 2.1.0+8
~$ Firmware upload started
~$ Firmware upload succeeded
Applying the new firmware
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x1, image_ok=0x3
I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Image index: 0, Swap type: test
I: Starting swap using move algorithm.
I: Bootloader chainload address offset: 0x8000
I: Jumping to the first image slot
Current image version: 2.1.0+9
  • I am using unmodified samples you provided. Yes bt_mesh_dfu_srv_applied is called on the target side.
    No composition changes in the image, Just the version number
    Tried with and without a custom timeout, no difference. Image is transferred, applied and runs on the target just fine, but on the distributor side there is an error after the "apply" step. See logs above
    Also, what is phase 10 ? Saw that several times. It's not defined in the headers. Uninitialized variable?
    Another quirk I'd like to resolve is  why it fails to proceed with the batch transfer if one of the target nodes is offline
    Thanks for clarifying the "50" progress thing
    Can't see this in the logs.
    Can you provide the full log?
    I may also suggest to increase timeout_base value
    This one (if you use shell to start dfu transfer): https://github.com/zephyrproject-rtos/zephyr/blob/zephyr-v3.5.0/doc/connectivity/bluetooth/api/mesh/shell.rst?plain=1#L1411
  • Can you provide the full log?
    See the first log in the ticket. It is from a distribution to 8 nodes with "apply" option. As soon as the transfer to one of the nodes completed, the image was applied. That caused a timeout and the whole batch stopped.
    I tried timeout 10, will try something bigger and let you know
    Thank you
    Here is the  status 10 example.
    mesh models dfd receivers-get 0 20
    "target_cnt": 8,
    "targets": {
    "0": { "blob_addr": 407, "phase": 2, "status": 0, "blob_status": 0, "progress": 0, "img_idx": 0 },
    "1": { "blob_addr": 406, "phase": 2, "status": 0, "blob_status": 0, "progress": 0, "img_idx": 0 },
    "2": { "blob_addr": 992, "phase": 10, "status": 0, "blob_status": 0, "progress": 0, "img_idx": 0 },
    "3": { "blob_addr": 409, "phase": 2, "status": 0, "blob_status": 0, "progress": 0, "img_idx": 0 },
    "4": { "blob_addr": 418, "phase": 2, "status": 0, "blob_status": 0, "progress": 0, "img_idx": 0 },
    "5": { "blob_addr": 995, "phase": 2, "status": 0, "blob_status": 0, "progress": 0, "img_idx": 0 },
    "6": { "blob_addr": 214, "phase": 2, "status": 0, "blob_status": 0, "progress": 0, "img_idx": 0 },
    "7": { "blob_addr": 419, "phase": 2, "status": 0, "blob_status": 0, "progress": 0, "img_idx": 0 }
    Thank you
  • A new problem
    I did a firmware distribution of 1 device and the transfer succeeded, so I know the process works fine
    Then I  tried to distribute to 8 devices - see node list above. 992 is offline.
    Its phase is listed as 10 which does not exist in phase enumeration. But that's the least of my worries
    After I sent  "mesh models dfd start 0 0 0 false 7 120"  command I did
    "mesh models dfd receivers-get 0 20" periodically but the
    "progress" field remained at 0 for over 5 minutes at which point I canceled the distribution with
    "mesh models dfd cancel" command
    After that all my 8 target nodes fail to boot.
    Messages in the target node:
     Recovering the firmware upload
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Image index: 0, Swap type: none
    messages repeat
    In the image recovery handler of the target sample there is  this comment
        /* TODO: Need to recover the effect. */
    Why is this handler called after the distribution was cancelled?
    How do I fix this ?
    I am curious, did you test batch distribution? How many targets?  Did you test with some nodes offline? Did you test with more targets than the default 8?
    Makes me nervous to deploy this feature if  a simple cancel bricks all devices. Hope this is something that I am doing wrong and there is a fix
    Thanks
