mesh dfu timeout
Hello
I'm exploring the mesh dfu transfer, get some strange results
Here is the setup
1 distributor, 1 target
On the distributor I start  the transfer with mesh models dfd start 0 0 command
In about 40 minutes it completes, and the image is applied but I get a timeout message on the distributor side
However on the target I see a message from the mcuboot that the new message was applied successfully - and actually it is working just fine
Log from the distributor and the target below
Another question
The progress in the JSON below is "50" which I think is because the function that calculates progress divides by 2:
Function cmd_dfd_receivers_get()  in dfd.c  has this lihe
uint8_t progress = bt_mesh_dfu_cli_progress(&dfd_srv->dfu) / 2;
However if I use
mesh models dfu cli progress command it returns
DFU progress: 100 %
Bug?
Thank you
Andy
Logs
Distributor
rtt:~$ [00:40:51.061,126] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
rtt:~$ [00:40:51.061,157] <dbg> bt_mesh_dfu_cli: dfu_complete:
rtt:~$ [00:40:51.061,187] <dbg> bt_mesh_dfd_srv: dfu_ended: reason: 0, phase: 1, apply: 1
rtt:~$ Distribution phase changed to Applying Update
rtt:~$ [00:40:51.061,218] <dbg> bt_mesh_dfu_cli: apply:
rtt:~$ rtt:~$ [00:40:51.061,248] <dbg> bt_mesh_blob_cli: blob_cli_broadcast: 1 targets
rtt:~$ rtt:~$ [00:40:51.271,606] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 6, cur state: 4
rtt:~$ [00:40:51.271,636] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x01a2 receiving transfer
rtt:~$ rtt:~$ [00:41:00.282,928] <dbg> bt_mesh_blob_cli: retry_timeout: 5
rtt:~$ rtt:~$ [00:41:09.441,864] <dbg> bt_mesh_blob_cli: retry_timeout: 4
rtt:~$ rtt:~$ [00:41:18.604,400] <dbg> bt_mesh_blob_cli: retry_timeout: 3
rtt:~$ rtt:~$ [00:41:27.766,143] <dbg> bt_mesh_blob_cli: retry_timeout: 2
rtt:~$ rtt:~$ [00:41:36.924,011] <dbg> bt_mesh_blob_cli: retry_timeout: 1
rtt:~$ [00:41:36.924,041] <dbg> bt_mesh_blob_cli: retry_timeout: Transfer timed out.
rtt:~$ [00:41:36.924,041] <dbg> bt_mesh_blob_cli: drop_remaining_targets:
rtt:~$ [00:41:36.924,072] <wrn> bt_mesh_blob_cli: Dropping 0x01a2: 9
rtt:~$ [00:41:36.924,072] <err> bt_mesh_dfu_cli: Target 0x01a2 failed: 3
rtt:~$ [00:41:36.924,102] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
rtt:~$ [00:41:36.924,102] <dbg> bt_mesh_dfu_cli: dfu_failed: 3
rtt:~$ [00:41:36.924,133] <dbg> bt_mesh_dfd_srv: dfu_ended: reason: 3, phase: 3, apply: 1
rtt:~$ Distribution phase changed to Failed
rtt:~$ rtt:~$ mesh models dfd receivers-get 0 1
"target_cnt": 1,
"targets": {
"0": { "blob_addr": 418, "phase": 6, "status": 3, "blob_status": 9, "progress": 50, "img_idx": 0 }
Target
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
Current image version: 2.1.0+8
~$ Firmware upload started
~$ Firmware upload succeeded
Applying the new firmware
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x1, image_ok=0x3
I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Image index: 0, Swap type: test
I: Starting swap using move algorithm.
I: Bootloader chainload address offset: 0x8000
I: Jumping to the first image slot
Current image version: 2.1.0+9
  • phase 10 is the DFU phase, not the dfd phase and is unknown phase which means that no response was ever received from that node:
    - https://github.com/zephyrproject-rtos/zephyr/blob/39917ae5e6423fe74edce399b927ddff38670817/include/zephyr/bluetooth/mesh/dfu.h#L73-L74
    - https://github.com/zephyrproject-rtos/zephyr/blob/39917ae5e6423fe74edce399b927ddff38670817/include/zephyr/bluetooth/mesh/dfu_cli.h#L63-L64
    Progress 0 is because the node with address 992 didn't respond to the Firmware Update Start message, but by the dfu procedure the distributor must get a response from all nodes before starting sending the blob.
    timeout_base 120 means that the actual timeout for each DFU phase is 10 * 1000 * (120 + 2) + 7 * 100 = ~20 minutes.
    The distributor will repeat the request CONFIG_BT_MESH_BLOB_CLI_BLOCK_RETRIES times, which is 5 by default. So, it will repeat every 4 minutes. The reason I asked to increase timeout_base is because most likely the timeout was shorter than the time needed for devices to flash the new firmware. They need to adjust the timeout based on their setup.
    Also, since it is a unicast transfer, every chunk transmission will require confirmation from a node which may delay the transfer even more. I recommend to use multicast transfer for nodes more than 2. For this, they need to subscribe all DFU and blob models to the same address and set `group` field to that address in `mesh models dfd start` command.
    The comment `/* TODO: Need to recover the effect. */` means that the image effect (`img_effect` variable) which is set in `dfu_meta_check` function is not stored anywhere. This code is called after reboot when DFU model recovers the abandoned DFU transfer and is needed to take a decision at the apply phase (see `dfu_appply` function in the same sample).
    If target devices start to reboot cyclically I suggest to check if `CONFIG_RESET_ON_FATAL_ERROR` Kconfig option is enabled in `build/target/zephyr/.config` and disable it explicitly in the prj.conf. Then run the devices again.
    I still would like to see the complete log from the distributor and target nodes. Like the first one from RTT that you attached.
  • Regarding the multicast transfer
    I assume you are referring to the target nodes?
    This is unfortunate. On a live mesh network with many nodes there will always be a node that would not respond for a variety of reasons. If the whole process is blocked by just one node it makes it not very usable in a real life situation.
    I will provide the logs you requested. May take a while
    Thanks a lot for your help
  • Here is the log from the distributor right before the image finished transferring
    Questions
    1. What do the  warnings about "no free slots for segmented messages" mean? Is it something that needs to be addressed? Number of slots increased?
    2. Timeout base was set to 10. Still got an error applying on the distributor side. On the target side the image was applied and is running
    Thoughts?
    Thank you
    rtt:~$ [05:11:41.929,473] <dbg> bt_mesh_blob_cli: blob_cli_broadcast: 8 targets
    rtt:~$ rtt:~$ [05:11:42.036,682] <dbg> bt_mesh_blob_cli: handle_block_status: status: 0 block: 98 encoding: 1
    rtt:~$ [05:11:42.036,712] <dbg> bt_mesh_blob_cli: rx_block_status: 0x0197: block: 98 status: 0
    rtt:~$ [05:11:42.036,712] <dbg> bt_mesh_blob_cli: rx_block_status: Target 0x0197 received all chunks
    rtt:~$ [05:11:42.036,743] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0197, pending: 8
    rtt:~$ [05:11:42.059,356] <dbg> bt_mesh_blob_cli: handle_block_status: status: 0 block: 98 encoding: 1
    rtt:~$ [05:11:42.059,387] <dbg> bt_mesh_blob_cli: rx_block_status: 0x0196: block: 98 status: 0
    rtt:~$ [05:11:42.059,387] <dbg> bt_mesh_blob_cli: rx_block_status: Target 0x0196 received all chunks
    rtt:~$ [05:11:42.059,417] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0196, pending: 7
    rtt:~$ [05:11:42.150,360] <dbg> bt_mesh_blob_cli: handle_block_status: status: 0 block: 98 encoding: 1
    rtt:~$ [05:11:42.150,390] <dbg> bt_mesh_blob_cli: rx_block_status: 0x03e5: block: 98 status: 0
    rtt:~$ [05:11:42.150,421] <dbg> bt_mesh_blob_cli: rx_block_status: Target 0x03e5 received all chunks
    rtt:~$ [05:11:42.150,421] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x03e5, pending: 6
    rtt:~$ [05:11:42.162,811] <dbg> bt_mesh_blob_cli: handle_block_status: status: 0 block: 98 encoding: 1
    rtt:~$ rtt:~$ [05:11:42.162,811] <dbg> bt_mesh_blob_cli: rx_block_status: 0x0199: block: 98 status: 0
    rtt:~$ [05:11:42.162,841] <dbg> bt_mesh_blob_cli: rx_block_status: Target 0x0199 received all chunks
    rtt:~$ [05:11:42.162,841] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0199, pending: 5
    rtt:~$ [05:11:42.222,076] <dbg> bt_mesh_blob_cli: handle_block_status: status: 0 block: 98 encoding: 1
    rtt:~$ [05:11:42.222,106] <dbg> bt_mesh_blob_cli: rx_block_status: 0x01a2: block: 98 status: 0
    rtt:~$ [05:11:42.222,106] <dbg> bt_mesh_blob_cli: rx_block_status: Target 0x01a2 received all chunks
    rtt:~$ [05:11:42.222,137] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x01a2, pending: 4
    rtt:~$ [05:11:42.265,563] <dbg> bt_mesh_blob_cli: handle_block_status: status: 0 block: 98 encoding: 1
    rtt:~$ [05:11:42.265,594] <dbg> bt_mesh_blob_cli: rx_block_status: 0x03e3: block: 98 status: 0
    rtt:~$ [05:11:42.265,594] <dbg> bt_mesh_blob_cli: rx_block_status: Target 0x03e3 received all chunks
    rtt:~$ [05:11:42.265,625] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x03e3, pending: 3
    rtt:~$ [05:11:42.356,536] <dbg> bt_mesh_blob_cli: handle_block_status: status: 0 block: 98 encoding: 1
    rtt:~$ rtt:~$ [05:11:42.356,567] <dbg> bt_mesh_blob_cli: rx_block_status: 0x00d6: block: 98 status: 0
    rtt:~$ [05:11:42.356,597] <dbg> bt_mesh_blob_cli: rx_block_status: Target 0x00d6 received all chunks
    rtt:~$ [05:11:42.356,597] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x00d6, pending: 2
    rtt:~$ [05:11:42.400,756] <dbg> bt_mesh_blob_cli: handle_block_status: status: 0 block: 98 encoding: 1
    rtt:~$ [05:11:42.400,787] <dbg> bt_mesh_blob_cli: rx_block_status: 0x01a0: block: 98 status: 0
    rtt:~$ [05:11:42.400,787] <dbg> bt_mesh_blob_cli: rx_block_status: Target 0x01a0 received all chunks
    rtt:~$ [05:11:42.400,817] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x01a0, pending: 1
    rtt:~$ [05:11:42.400,848] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
    rtt:~$ [05:11:42.400,848] <dbg> bt_mesh_blob_cli: block_check_end:
    rtt:~$ [05:11:42.400,878] <dbg> bt_mesh_blob_cli: block_check_end: No more missing chunks for block 98
    rtt:~$ [05:11:42.400,970] <dbg> bt_mesh_blob_cli: confirm_transfer:
    rtt:~$ [05:11:42.401,000] <dbg> bt_mesh_blob_cli: blob_cli_broadcast: 8 targets
    rtt:~$ rtt:~$ [05:11:42.569,824] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:42.639,770] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:42.643,768] <dbg> bt_mesh_blob_cli: handle_xfer_status: status: 0 push phase: 4 f7f9a7fa30859b6a
    rtt:~$ [05:11:42.643,798] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0197, pending: 8
    rtt:~$ [05:11:42.716,674] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:42.761,138] <dbg> bt_mesh_blob_cli: handle_xfer_status: status: 0 push phase: 4 f7f9a7fa30859b6a
    rtt:~$ [05:11:42.761,138] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0196, pending: 7
    rtt:~$ [05:11:42.801,971] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:42.835,601] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:42.839,111] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:42.876,678] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:42.897,613] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:42.927,093] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:42.970,275] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:42.971,496] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:42.989,379] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ rtt:~$ [05:11:43.002,807] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ rtt:~$ [05:11:43.040,893] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:43.082,519] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:43.103,149] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:43.114,624] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:43.160,095] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ [05:11:43.280,578] <dbg> bt_mesh_blob_cli: handle_xfer_status: status: 0 push phase: 4 f7f9a7fa30859b6a
    rtt:~$ [05:11:43.280,609] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x03e5, pending: 6
    rtt:~$ [05:11:43.350,433] <dbg> bt_mesh_blob_cli: handle_xfer_status: status: 0 push phase: 4 f7f9a7fa30859b6a
    rtt:~$ [05:11:43.350,433] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0199, pending: 5
    rtt:~$ [05:11:43.616,241] <dbg> bt_mesh_blob_cli: handle_xfer_status: status: 0 push phase: 4 f7f9a7fa30859b6a
    rtt:~$ [05:11:43.616,271] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x01a2, pending: 4
    rtt:~$ [05:11:43.660,980] <wrn> bt_mesh_transport: No free slots for new incoming segmented messages
    rtt:~$ rtt:~$ [05:11:43.712,341] <dbg> bt_mesh_blob_cli: handle_xfer_status: status: 0 push phase: 4 f7f9a7fa30859b6a
    rtt:~$ [05:11:43.712,371] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x03e3, pending: 3
    rtt:~$ rtt:~$ [05:11:43.828,063] <dbg> bt_mesh_blob_cli: handle_xfer_status: status: 0 push phase: 4 f7f9a7fa30859b6a
    rtt:~$ [05:11:43.828,094] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x00d6, pending: 2
    rtt:~$ [05:11:44.346,954] <dbg> bt_mesh_blob_cli: handle_xfer_status: status: 0 push phase: 4 f7f9a7fa30859b6a
    rtt:~$ [05:11:44.346,954] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x01a0, pending: 1
    rtt:~$ [05:11:44.346,984] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
    rtt:~$ [05:11:44.347,015] <dbg> bt_mesh_blob_cli: end: 1
    rtt:~$ [05:11:44.347,015] <dbg> bt_mesh_dfu_cli: refresh:
    rtt:~$ [05:11:44.347,045] <dbg> bt_mesh_blob_cli: blob_cli_broadcast: 8 targets
    rtt:~$ [05:11:44.537,017] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 4, cur state: 2
    rtt:~$ [05:11:44.537,048] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x0197 receiving transfer
    rtt:~$ [05:11:44.537,048] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0197, pending: 8
    rtt:~$ [05:11:44.576,599] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 4, cur state: 2
    rtt:~$ rtt:~$ [05:11:44.576,629] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x0196 receiving transfer
    rtt:~$ [05:11:44.576,629] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0196, pending: 7
    rtt:~$ [05:11:44.639,038] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 4, cur state: 2
    rtt:~$ [05:11:44.639,038] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x03e5 receiving transfer
    rtt:~$ [05:11:44.639,068] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x03e5, pending: 6
    rtt:~$ rtt:~$ [05:11:44.805,175] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 4, cur state: 2
    rtt:~$ [05:11:44.805,206] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x0199 receiving transfer
    rtt:~$ [05:11:44.805,206] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0199, pending: 5
    rtt:~$ [05:11:44.937,713] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 4, cur state: 2
    rtt:~$ [05:11:44.937,713] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x01a2 receiving transfer
    rtt:~$ [05:11:44.937,744] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x01a2, pending: 4
    rtt:~$ [05:11:45.050,140] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 4, cur state: 2
    rtt:~$ [05:11:45.050,140] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x03e3 receiving transfer
    rtt:~$ [05:11:45.050,170] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x03e3, pending: 3
    rtt:~$ [05:11:45.217,559] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 4, cur state: 2
    rtt:~$ [05:11:45.217,590] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x00d6 receiving transfer
    rtt:~$ [05:11:45.217,620] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x00d6, pending: 2
    rtt:~$ [05:11:45.292,846] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 4, cur state: 2
    rtt:~$ rtt:~$ [05:11:45.292,877] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x01a0 receiving transfer
    rtt:~$ [05:11:45.292,877] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x01a0, pending: 1
    rtt:~$ [05:11:45.292,907] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
    rtt:~$ [05:11:45.292,938] <dbg> bt_mesh_dfu_cli: dfu_complete:
    rtt:~$ [05:11:45.292,938] <dbg> bt_mesh_dfd_srv: dfu_ended: reason: 0, phase: 1, apply: 0
    rtt:~$ Distribution phase changed to Transfer Success
    rtt:~$ rtt:~$ mesh models dfd apply
    { "status": 0, "phase": 3, "group": 0, "app_idx": 0, "ttl": 7, "timeout_base": 20, "xfer_mode": 1, "apply": 0, "slot_idx": 0 }
    rtt:~$ [05:44:02.960,601] <dbg> bt_mesh_dfu_cli: apply:
    rtt:~$ [05:44:02.960,632] <dbg> bt_mesh_blob_cli: blob_cli_broadcast: 8 targets
    rtt:~$ [05:44:03.086,822] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 6, cur state: 4
    rtt:~$ [05:44:03.086,822] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x0197 receiving transfer
    rtt:~$ [05:44:03.149,230] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 6, cur state: 4
    rtt:~$ [05:44:03.149,261] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x0196 receiving transfer
    rtt:~$ [05:44:03.241,210] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 6, cur state: 4
    rtt:~$ [05:44:03.241,241] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x03e5 receiving transfer
    rtt:~$ [05:44:03.322,570] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 6, cur state: 4
    rtt:~$ [05:44:03.322,601] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x0199 receiving transfer
    rtt:~$ rtt:~$ [05:44:03.558,776] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 6, cur state: 4
    rtt:~$ [05:44:03.558,776] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x01a2 receiving transfer
    rtt:~$ [05:44:03.630,737] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 6, cur state: 4
    rtt:~$ [05:44:03.630,737] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x03e3 receiving transfer
    rtt:~$ [05:44:03.715,850] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 6, cur state: 4
    rtt:~$ [05:44:03.715,850] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x00d6 receiving transfer
    rtt:~$ [05:44:03.818,969] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 6, cur state: 4
    rtt:~$ [05:44:03.819,000] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x01a0 receiving transfer
    rtt:~$ rtt:~$ [05:44:47.864,501] <dbg> bt_mesh_blob_cli: retry_timeout: 5
    rtt:~$ [05:44:47.931,579] <dbg> bt_mesh_dfu_cli: handle_status: 2 phase: 0, cur state: 4
    rtt:~$ [05:44:47.931,579] <dbg> bt_mesh_dfu_cli: handle_status: Response received with Idle phase
    rtt:~$ [05:44:47.931,610] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0197, pending: 8
    rtt:~$ [05:44:47.977,020] <dbg> bt_mesh_dfu_cli: handle_status: 2 phase: 0, cur state: 4
    rtt:~$ [05:44:47.977,050] <dbg> bt_mesh_dfu_cli: handle_status: Response received with Idle phase
    rtt:~$ [05:44:47.977,050] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0196, pending: 7
    rtt:~$ [05:44:48.038,604] <dbg> bt_mesh_dfu_cli: handle_status: 2 phase: 0, cur state: 4
    rtt:~$ [05:44:48.038,604] <dbg> bt_mesh_dfu_cli: handle_status: Response received with Idle phase
    rtt:~$ [05:44:48.038,635] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x03e5, pending: 6
    rtt:~$ [05:44:48.120,971] <dbg> bt_mesh_dfu_cli: handle_status: 2 phase: 0, cur state: 4
    rtt:~$ [05:44:48.120,971] <dbg> bt_mesh_dfu_cli: handle_status: Response received with Idle phase
    rtt:~$ [05:44:48.121,002] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0199, pending: 5
    rtt:~$ rtt:~$ [05:44:48.143,829] <dbg> bt_mesh_dfu_cli: handle_status: 2 phase: 0, cur state: 4
    rtt:~$ [05:44:48.143,829] <dbg> bt_mesh_dfu_cli: handle_status: Response received with Idle phase
    rtt:~$ [05:44:48.143,859] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x01a2, pending: 4
    rtt:~$ rtt:~$ [05:44:48.211,273] <dbg> bt_mesh_dfu_cli: handle_status: 2 phase: 0, cur state: 4
    rtt:~$ [05:44:48.211,303] <dbg> bt_mesh_dfu_cli: handle_status: Response received with Idle phase
    rtt:~$ [05:44:48.211,303] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x03e3, pending: 3
    rtt:~$ [05:44:48.278,472] <dbg> bt_mesh_dfu_cli: handle_status: 2 phase: 0, cur state: 4
    rtt:~$ [05:44:48.278,503] <dbg> bt_mesh_dfu_cli: handle_status: Response received with Idle phase
    rtt:~$ [05:44:48.278,503] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x00d6, pending: 2
    rtt:~$ [05:44:48.312,652] <dbg> bt_mesh_dfu_cli: handle_status: 2 phase: 0, cur state: 4
    rtt:~$ [05:44:48.312,683] <dbg> bt_mesh_dfu_cli: handle_status: Response received with Idle phase
    rtt:~$ [05:44:48.312,683] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x01a0, pending: 1
    rtt:~$ [05:44:48.321,777] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
    rtt:~$ [05:44:48.321,807] <dbg> bt_mesh_dfu_cli: dfu_applied:
    rtt:~$ [05:44:48.321,807] <dbg> bt_mesh_dfu_cli: confirm:
    rtt:~$ [05:44:48.321,899] <dbg> bt_mesh_blob_cli: blob_cli_broadcast: 8 targets
    rtt:~$ rtt:~$ [05:44:48.453,460] <dbg> bt_mesh_dfu_cli: handle_info_status: Image list from 0x0197 from index 0
    rtt:~$ [05:44:48.453,521] <dbg> bt_mesh_dfu_cli: handle_info_status: Image 0
    fwid: 020100000a000000
    rtt:~$ [05:44:48.453,582] <wrn> bt_mesh_dfu_cli: Target 0x0197 failed to apply image: 020100000000000a
    rtt:~$ [05:44:48.453,582] <err> bt_mesh_dfu_cli: Target 0x0197 failed: 3
    rtt:~$ [05:44:48.453,613] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0197, pending: 8
    rtt:~$ [05:44:48.502,838] <dbg> bt_mesh_dfu_cli: handle_info_status: Image list from 0x0196 from index 0
    rtt:~$ [05:44:48.502,868] <dbg> bt_mesh_dfu_cli: handle_info_status: Image 0
    rtt:~$ [05:44:48.502,929] <wrn> bt_mesh_dfu_cli: Target 0x0196 failed to apply image: 020100000000000a
    rtt:~$ [05:44:48.502,929] <err> bt_mesh_dfu_cli: Target 0x0196 failed: 3
    rtt:~$ [05:44:48.502,960] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0196, pending: 7
    rtt:~$ [05:44:48.576,080] <dbg> bt_mesh_dfu_cli: handle_info_status: Image list from 0x03e5 from index 0
    rtt:~$ rtt:~$ [05:44:48.576,171] <dbg> bt_mesh_dfu_cli: handle_info_status: Image 0
    rtt:~$ [05:44:48.576,232] <wrn> bt_mesh_dfu_cli: Target 0x03e5 failed to apply image: 020100000000000a
    rtt:~$ [05:44:48.576,232] <err> bt_mesh_dfu_cli: Target 0x03e5 failed: 3
    rtt:~$ [05:44:48.576,263] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x03e5, pending: 6
    rtt:~$ rtt:~$ [05:44:48.685,485] <dbg> bt_mesh_dfu_cli: handle_info_status: Image list from 0x0199 from index 0
    rtt:~$ [05:44:48.685,516] <dbg> bt_mesh_dfu_cli: handle_info_status: Image 0
    rtt:~$ [05:44:48.685,577] <wrn> bt_mesh_dfu_cli: Target 0x0199 failed to apply image: 020100000000000a
    rtt:~$ [05:44:48.685,607] <err> bt_mesh_dfu_cli: Target 0x0199 failed: 3
    rtt:~$ [05:44:48.685,607] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x0199, pending: 5
    rtt:~$ [05:44:48.860,198] <dbg> bt_mesh_dfu_cli: handle_info_status: Image list from 0x01a2 from index 0
    rtt:~$ [05:44:48.860,260] <dbg> bt_mesh_dfu_cli: handle_info_status: Image 0
    rtt:~$ [05:44:48.860,290] <wrn> bt_mesh_dfu_cli: Target 0x01a2 failed to apply image: 020100000000000a
    rtt:~$ [05:44:48.860,321] <err> bt_mesh_dfu_cli: Target 0x01a2 failed: 3
    rtt:~$ [05:44:48.860,321] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x01a2, pending: 4
    rtt:~$ rtt:~$ [05:44:48.992,858] <dbg> bt_mesh_dfu_cli: handle_info_status: Image list from 0x03e3 from index 0
    rtt:~$ [05:44:48.992,889] <dbg> bt_mesh_dfu_cli: handle_info_status: Image 0
    rtt:~$ [05:44:48.992,950] <wrn> bt_mesh_dfu_cli: Target 0x03e3 failed to apply image: 020100000000000a
    rtt:~$ [05:44:48.992,980] <err> bt_mesh_dfu_cli: Target 0x03e3 failed: 3
    rtt:~$ [05:44:48.992,980] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x03e3, pending: 3
    rtt:~$ [05:44:49.118,438] <dbg> bt_mesh_dfu_cli: handle_info_status: Image list from 0x00d6 from index 0
    rtt:~$ [05:44:49.118,499] <dbg> bt_mesh_dfu_cli: handle_info_status: Image 0
    rtt:~$ [05:44:49.118,560] <wrn> bt_mesh_dfu_cli: Target 0x00d6 failed to apply image: 020100000000000a
    rtt:~$ [05:44:49.118,560] <err> bt_mesh_dfu_cli: Target 0x00d6 failed: 3
    rtt:~$ [05:44:49.118,591] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x00d6, pending: 2
    rtt:~$ rtt:~$ [05:44:49.213,592] <dbg> bt_mesh_dfu_cli: handle_info_status: Image list from 0x01a0 from index 0
    rtt:~$ [05:44:49.213,653] <dbg> bt_mesh_dfu_cli: handle_info_status: Image 0
    rtt:~$ [05:44:49.213,714] <wrn> bt_mesh_dfu_cli: Target 0x01a0 failed to apply image: 020100000000000a
    rtt:~$ [05:44:49.213,714] <err> bt_mesh_dfu_cli: Target 0x01a0 failed: 3
    rtt:~$ [05:44:49.213,745] <dbg> bt_mesh_blob_cli: blob_cli_broadcast_rsp: 0x01a0, pending: 1
    rtt:~$ [05:44:49.213,775] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
    rtt:~$ [05:44:49.213,775] <dbg> bt_mesh_dfu_cli: dfu_failed: 3
    rtt:~$ [05:44:49.213,806] <dbg> bt_mesh_dfd_srv: dfu_ended: reason: 3, phase: 3, apply: 0
    You should increase the value of CONFIG_BT_MESH_SEG_BUFS to 80 or 100.
    Thoughts?
    All targets replied with fwid 020100000a000000:
    But fwid on the distributor is 020100000000000a:
    This value should be used when adding a new slot on the distributor. Please check what fwid you set through mesh models dfu slot add. It should be equal to mcuboot image version encoded into struct mcuboot_img_sem_ver:
    -Amanda H.
  • Great, thank you. I'll implement your suggestions and let you know
    Really appreciate your help
