TWI Slave Sample
I'm thinking of incorporating a TWI slave with nRF52832.
I'm using SDK 17.0.2.
I want to set up a register and read/write multiple bytes with TWI, but I don't know how to write the twis_event_handler process.
Are there any good samples?
  • Thank you for the information.
    Currently, I can read from the master, but write operations don't work properly because an NRFX_TWIS_EVT_GENERAL_ERROR occurs.
    When I look with a protocol analyzer, I can see that ACKs are returned up to the slave address and register address, but no ACK is returned for data, and in the slave event, I can read the register address but not the data.
    What do you think is the cause?
    I've attached the source code for the current event handler.
    void twis_event_handler(nrf_drv_twis_evt_t const * p_event)
         static bool address_received = false;
        switch (p_event->type)
            case NRFX_TWIS_EVT_READ_REQ:
                nrf_drv_twis_tx_prepare(&m_twis, &m_twi_register[m_register_address], TWI_BUFFER_SIZE - m_register_address);
                NRF_LOG_INFO("Read request: register address = 0x%02X", m_register_address);
            case NRFX_TWIS_EVT_WRITE_REQ:
                if (!address_received) {
                    NRF_LOG_INFO("Preparing to receive register address...");
                    nrf_drv_twis_rx_prepare(&m_twis, &m_register_address, 1);
                } else {
                    NRF_LOG_INFO("Register address received: 0x%02X", m_register_address);
                    if (m_register_address < TWI_BUFFER_SIZE) {
                        NRF_LOG_INFO("Preparing to write data to register 0x%02X", m_register_address);
                        nrf_drv_twis_rx_prepare(&m_twis, &m_twi_register[m_register_address], TWI_BUFFER_SIZE - m_register_address);
                    } else {
                        NRF_LOG_ERROR("Invalid register address: 0x%02X", m_register_address);
            case NRFX_TWIS_EVT_WRITE_DONE:
                    address_received = true;
                    NRF_LOG_INFO("Register address 0x%02X received", m_register_address);
                } else {
                    NRF_LOG_INFO("Data written to register 0x%02X: 0x%02X", m_register_address, m_twi_register[m_register_address]);
            case NRFX_TWIS_EVT_READ_DONE:
                NRF_LOG_INFO("Read completed");
            case NRFX_TWIS_EVT_READ_ERROR:
                NRF_LOG_ERROR("TWIS EVT READ ERROR");
            case NRFX_TWIS_EVT_WRITE_ERROR:
                NRF_LOG_ERROR("TWIS EVT WRITE ERROR");
            case NRFX_TWIS_EVT_GENERAL_ERROR:
                NRF_LOG_ERROR("TWIS EVT GENERAL ERROR");
    Could you try to prepare the data buffer earlier, in the NRFX_TWIS_EVT_WRITE_REQ phase, irrespective of whether the register address has been received?
    You could also make sure that the nrf_drv_twis_rx_prepare() is called quickly enough for the data phase.
    Because right now, if there’s a timing issue or race condition, the slave may not have the data buffer ready in time, causing the master to not receive an ACK for the data phase.
    Priyanka
