Advertising Manufacturer data while together while Mesh is enabled doesn't seem to work
Hello, I have a BLE Mesh application which is advertising the Mesh Beacon. If after mesh is enabled, I configure and advertisement for showing manufacturer data, the Mesh beacon doesn't show up. Is there a way to have both being advertised at the same time? or are both uses incompatible?
Thanks!
  • Hi
    What exactly is it that's not working here? From what I know, this should be perfectly fine to do, so what do you mean by the Mesh beacon not showing up. How do you enable Mesh and set up its advertising? Please show me some info on how you've set p the manufacturer data as well. Does it work as expected if you remove the manufacturer data?
    Simon
