LTE-M & GNSS together not works in my project
I have integrated HTTP client & GNSS example project as per my requirement.
After initialization  I get GNSS Tracking:  6 Using:  0 Unhealthy: 1
& Insufficient GNSS time windows. message & GNSS not get fixed most of the time.
Can you guide me for integrating the project.
    are you testing this outside where there GPS receiver signal is sufficient? Have you enabled PSM in your application?
  • GNSS example works fine , I have connected external antenna.
    Configuration I have:
    # Copyright (c) 2023 Nordic Semiconductor ASA
    # General
    # 1024
    CONFIG_HEAP_MEM_POOL_SIZE=8192
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1536
    # Logging
    CONFIG_LOG=y
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_IPV6=y
    CONFIG_NET_CONNECTION_MANAGER=y
    CONFIG_NET_CONNECTION_MANAGER_MONITOR_STACK_SIZE=1024
    CONFIG_CJSON_LIB=y
    CONFIG_NEWLIB_LIBC=y
    CONFIG_HTTP_CLIENT=y //added 23/8/24
    # CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LTE_LINK_CONTROL=y
    ## Commented for testing
    # CONFIG_PDN=y
    # CONFIG_PDN_DEFAULTS_OVERRIDE=y
    # CONFIG_PDN_DEFAULT_APN="\"lpwa.vodafone.iot\""
    ## Enable NB-IoT network mode
    # CONFIG_LTE_NETWORK_MODE_NBIOT=y
    ## Enable GNSS support
    # CONFIG_LTE_NETWORK_MODE_NBIOT_GPS=y
    # CONFIG_LTE_NETWORK_MODE_LTE_M =y
    CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
    # Enable modem functionalities if not already enabled
    CONFIG_MODEM_KEY_MGMT=y
    CONFIG_REBOOT=y
    CONFIG_NRF_MODEM_LIB=y
    CONFIG_GNSS=y
    # CONFIG_GNSS_PRIORITY=10
    # CONFIG_GNSS_SAMPLE_MODE=y
    CONFIG_GNSS_SATELLITES=y
    CONFIG_LOG_BUFFER_SIZE=8192
    CONFIG_GNSS_DUMP_TO_LOG=y
    CONFIG_GNSS_LOG_LEVEL_DBG=y
    CONFIG_MODEM_ANTENNA_GNSS_ONBOARD=y
    CONFIG_MODEM_ANTENNA_GNSS_EXTERNAL=n
    # General
    CONFIG_FPU=y
    # CONFIG_NRF_MODEM_LIB=y
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_PICOLIBC_IO_FLOAT=y
    # CONFIG_LOG=y
    CONFIG_LOG_MODE_IMMEDIATE=y
    # GNSS sample
    # Enable to use nRF Cloud A-GNSS
    # CONFIG_GNSS_SAMPLE_ASSISTANCE_NRF_CLOUD=n
    # Request eDRX from the network
    CONFIG_LTE_EDRX_REQ=y
    # PSM requested periodic TAU 8 hours
    CONFIG_LTE_PSM_REQ_RPTAU="00101000"
    # PSM requested active time 6 seconds
    # CONFIG_LTE_PSM_REQ_RAT="00000011"
    CONFIG_LTE_PSM_REQ_RAT="00100001"
    # AT Host library - Used to send AT commands directy from an UART terminal and to allow
    # integration with nRF Connect for Desktop LTE Link monitor application.
    CONFIG_AT_HOST_LIBRARY=y
    # Networking
    CONFIG_NET_SOCKETS_OFFLOAD=y
  • Have you ensured that PSM is granted in the network you are connected to?
  • Not sure , How to check PSM is enabled or not?
    How to disable PSM mode?
    Why would you disable PSM if you intend to use the GPS?
    Can be read using the XMONITOR at cmd.
