nRF5340 OTA fails with Mcu Mgr Error: 10 Group: 1 after interrupted upload
I get a Mcu Mgr Error: 10 Group: 1, when I
  1. start OTA on Android smart phone
  2. interrupt during upload by disabling BLE on the phone
  3. enable BLE again
  4. retry OTA upload
This is the corresponding error message:
<err> mcumgr_img_grp: Image upload inspect failed: 10
Do I need to wait longer until the error will go away
or
do I need to do anything other then retrying directly?
I found out that if I run `kernel reboot cold` on the Zephyr shell, then there is no more Error 10 and the upload will start as expected.
Thanks, Alex
  • Funny thing: I found out that when I interrupt the upload in the first seconds (about less than 10% upload) I will get this mcu mgr error 10.
    If I wait longer (interrupted about 30-40%) the upload will be resumed on the next try.
    Could you tell me which version of the SDK you are using here, and which Nordic chip or DK you are trying with? Could you share the entire log (including the error message) here?
    Abhijith
  • Yes, sure. I am using NCS SDK v2.6.1 and I am using a custom PCB based on the nRF5340 DK
    I am not sure if I am allowed to share the entire log but I can share the part that contains the messages that come up when I start OTA.
    [00:00:18.663,269] <inf> mcuboot_util: Secondary image of image pair (0.) is unreachable. Treat it as empty
    [00:00:18.690,490] <inf> mcuboot_util: Image index: 0, Swap type: none
    [00:00:18.714,721] <err> mcumgr_img_grp: Failed to open flash area ID 2: -19
    [00:00:18.739,624] <inf> mcuboot_util: Secondary image of image pair (1.) is unreachable. Treat it as empty
    [00:00:18.766,906] <inf> mcuboot_util: Image index: 1, Swap type: none
    [00:00:18.790,863] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
    [00:00:18.815,643] <err> mcumgr_img_grp: Failed to open flash area ID 8: -19
    [00:00:19.017,608] <inf> mcuboot_util: Secondary image of image pair (1.) is unreachable. Treat it as empty
    [00:00:19.045,043] <inf> mcuboot_util: Image index: 1, Swap type: none
    [00:00:19.069,000] <err> mcumgr_img_grp: Failed to open flash area ID 8: -19
    [00:00:19.093,750] <err> mcumgr_img_grp: Image upload inspect failed: 10
    [00:00:19.118,286] <err> mcumgr_img_grp: Failed to open flash area ID 2: -19
    And the following messages show up for a successful OTA:
    (the errors should be okay because the network core update is not in flash)
    [00:03:20.543,823] <inf> mcuboot_util: Image index: 0, Swap type: none
    [00:03:20.568,267] <inf> mcuboot_util: Image index: 1, Swap type: none
    [00:03:20.592,315] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
    [00:03:32.743,469] <inf> mcuboot_util: Image index: 1, Swap type: none
    [00:03:44.001,068] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
    [00:03:44.026,275] <inf> mcuboot_util: Image index: 1, Swap type: none
    [00:03:44.051,361] <inf> mcuboot_util: Image index: 0, Swap type: none
    [00:03:44.076,080] <inf> mcuboot_util: Image index: 1, Swap type: perm
    [00:03:44.100,158] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
    [00:03:44.192,321] <inf> mcuboot_util: Image index: 0, Swap type: none
    [00:03:44.217,254] <inf> mcuboot_util: Image index: 0, Swap type: perm
    [00:03:44.242,065] <inf> mcuboot_util: Image index: 1, Swap type: perm
    [00:03:44.266,143] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
    shell:~$ I: Starting bootloader
    I: Image index: 0, Swap type: perm
    I: Image index: 1, Swap type: perm
    I: Image 0 upgrade secondary slot -> primary slot
    I: Erasing the primary slot
    I: Image 0 copying the secondary slot to the primary slot: 0x4e9c8 bytes
    I: Image 1 upgrade secondary slot -> primary slot
    I: Image 1 copying the secondary slot to the primary slot: 0x2ca0c bytes
    I: Turned on network core
    I: Turned off network core
    I: Bootloader chainload address offset: 0xc000
    �: Jumping to the first image slot
    The error message you are receiving can be found here. Please refer to this DevZone ticket, which discusses a similar issue.
    Kind Regards,
    Abhijith
