Why do I use this function bt_conn_le_param_update( ), only after the power on the first time to work, then do not work
There should not be any limitations on how often you can call bt_conn_le_param_update(), and updating the connection parameters several times during a connection is common. In what way does it not work?
After the Bluetooth connection is complete, bt_conn_le_param_update() is executed in the connected callback function. However, bt_conn_le_param_update() is executed in the code for synchronizing historical data but does not work.
This is a change from the CGM example
Is there an example of updating connection parameters multiple times during a connection?
