Why do I use this function bt_conn_le_param_update( ), only after the power on the first time to work, then do not work
Thank you for your reply. LLPM was not enabled, and the connection interval was set at 30ms. I feel that the two calls to update connection parameters were too short, resulting in the failure of the first call
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS is not enabled because I need to manually update the connection parameters
That is odd, because it is the only condition that SDC_HCI_OPCODE_CMD_LE_CONN_UPDATE would return error code 0x0C. Could you confirm you are using Softdevice Controller? You could check if CONFIG_BT_LL_SOFTDEVICE is set to y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS is enabled by default, so unless you have disabled it it it used (you should see it in the generated .config). That is not a problem though, but as you cannot have parallell procedures, this is just an example that you need to handle that it could happen (check the return value and handle it appropriately).
Both calls checked the return value, no error was returned, but only the second call can normally print the connection parameter change information, the first call does not seem to have been executed, but I am sure it has been executed, probably was rejected by the central, so I want to know whether the interval between the two calls is required
