Mqtt over wifi lesson 4 exercise 1 not able to build with nrf7002dk_nrf5340_cpuapp
I am unable to build the MQTT over Wi-Fi lesson 4, exercise 1 using the nrf7002dk_nrf5340_cpuapp board configuration, but the same code builds successfully with nrf7002dk_nrf5340_cpuapp_ns.
How can I build it with nrf7002dk_nrf5340_cpuapp?
i got the below error,Also in wifi_credentials.c file all ready  wifi_credentials_internal.h available,
/home/chiragbhavsar/NRF_VS_CODE/v2.6.1/nrf/subsys/net/lib/wifi_credentials/wifi_credentials.c:331: undefined reference to `wifi_credentials_delete_entry'
    The lesson only supports building with TF-M, that is, building for the _ns board variant.
    To get it to work without TF-M, you can add support for storing the network credentials in settings storage and use the wifi connect shell command to connect to the network instead.
    # For storing Wi-Fi credentials
    CONFIG_WIFI_CREDENTIALS_BACKEND_SETTINGS=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_NVS=y
    # Enable Wi-Fi shell
    CONFIG_NET_L2_WIFI_SHELL=y
    After the device has started up and you see the "Waiting to connect to Wi-Fi" log, use the following command to connect to the network:
    wifi connect -s <ssid> -k 1 -p <password>
    Make sure to replace <ssid> and <password> with the SSID and password of the network you want to connect to.
    Marte
  • I use a static Wi-Fi SSID and password for the initial connection.
    After establishing the MQTT connection, the wifi custom mobile app provides a new SSID and password on mqtt. How can I change the SSID and password at runtime?
    Is the method below correct?
    uint8_t _CusSsid[] = "xxxxx";
    uint8_t _CusPasswod[] = "xxxxx";
    cnx_params.ssid = _CusSsid;
    cnx_params.ssid_length = strlen(cnx_params.ssid);
    cnx_params.psk = _CusPasswod;
    cnx_params.psk_length = strlen(cnx_params.psk);
    You can set it in runtime using wifi_credentials_set_personal or wifi_credentials_set_personal_struct(), for example like this:
    static struct wifi_credentials_personal wifi_cred;
    void set_wifi_credentials_struct()
    	char *wifi_ssid = "Myssid";
    	char *wifi_password = "Mypassword";
    	wifi_cred.header.type = WIFI_SECURITY_TYPE_PSK;
    	memset(wifi_cred.header.bssid, 0, sizeof(wifi_cred.header.bssid));
    	wifi_cred.header.flags = 0;
    	wifi_cred.header.channel = WIFI_CHANNEL_ANY;
    	wifi_cred.header.timeout = 10;
    	wifi_cred.header.ssid_len = strlen(wifi_ssid);
    	memcpy(wifi_cred.header.ssid, wifi_ssid, wifi_cred.header.ssid_len);
    	wifi_cred.password_len = strlen(wifi_password);
    	memcpy(wifi_cred.password, wifi_password, wifi_cred.password_len);
    	int ret = wifi_credentials_set_personal_struct(&wifi_cred);
    	if (ret != 0) {
    		LOG_ERR("Failed to set credentials, err: %d", ret);
    Marte
    The following two parameters are not available in wifi_credentials_personal. Could this cause any issues?
    Also, I added the security configuration below. Could this cause any issues?
    wifi_cred.header.type = CONFIG_STA_KEY_MGMT_WPA2;
    No, this should not cause any issues. My code was based on v2.7.1, where these parameters are included, but in v2.6.1, you do not need them.
    The security type is a variable of type wifi_security_type, so you need to use one of the elements in that enum.
    /** @brief IEEE 802.11 security types. */
    enum wifi_security_type {
    	/** No security. */
    	WIFI_SECURITY_TYPE_NONE = 0,
    	/** WPA2-PSK security. */
    	WIFI_SECURITY_TYPE_PSK,
    	/** WPA2-PSK-SHA256 security. */
    	WIFI_SECURITY_TYPE_PSK_SHA256,
    	/** WPA3-SAE security. */
    	WIFI_SECURITY_TYPE_SAE,
    	/** GB 15629.11-2003 WAPI security. */
    	WIFI_SECURITY_TYPE_WAPI,
    	/** EAP security - Enterprise. */
    	WIFI_SECURITY_TYPE_EAP,
    	/** WEP security. */
    	WIFI_SECURITY_TYPE_WEP,
    	/** WPA-PSK security. */
    	WIFI_SECURITY_TYPE_WPA_PSK,
    	/** WPA/WPA2/WPA3 PSK security. */
    	WIFI_SECURITY_TYPE_WPA_AUTO_PERSONAL,
    /** @cond INTERNAL_HIDDEN */
    	__WIFI_SECURITY_TYPE_AFTER_LAST,
    	WIFI_SECURITY_TYPE_MAX = __WIFI_SECURITY_TYPE_AFTER_LAST - 1,
    	WIFI_SECURITY_TYPE_UNKNOWN
    /** @endcond */
    For WPA2-PSK (CONFIG_STA_KEY_MGMT_WPA2), the correct value is WIFI_SECURITY_TYPE_PSK.
    Marte
