we are currently in the process of verifying the nRF LwM2M Client, specifically focusing on the Queue Mode functionality. During our testing, we encountered an issue.
We configured the LWM2M_QUEUE_MODE_UPTIME
parameter to 90 seconds. However, we noticed that after only 30 seconds, all GET operations from the server begin to time out.
For testing we used our own code and the official Nordic sample. The results were the same.
Here are the modifications we made to the official Nordic sample:
diff --git a/samples/cellular/lwm2m_client/prj.conf b/samples/cellular/lwm2m_client/prj.conf index 800cf3aa8..a0c1f5a2e 100644 --- a/samples/cellular/lwm2m_client/prj.conf +++ b/samples/cellular/lwm2m_client/prj.conf @@ -88,7 +88,7 @@ CONFIG_FOTA_DOWNLOAD=y CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="1.0.0" # Set LwM2M Server IP address here -CONFIG_LWM2M_CLIENT_UTILS_SERVER="coaps://leshan.eclipseprojects.io:5684" +CONFIG_LWM2M_CLIENT_UTILS_SERVER="coap://51.138.77.106:5687" # Application Event Manager CONFIG_APP_EVENT_MANAGER=y @@ -106,21 +106,21 @@ CONFIG_LWM2M_DTLS_CID=y # When DTLS CID is used, we can keep the socket open. # If the server is not supporting CID, CONFIG_LWM2M_RD_CLIENT_SUSPEND_SOCKET_AT_IDLE should # be used instead. -CONFIG_LWM2M_RD_CLIENT_STOP_POLLING_AT_IDLE=y - +#CONFIG_LWM2M_RD_CLIENT_STOP_POLLING_AT_IDLE=y +CONFIG_LWM2M_RD_CLIENT_LISTEN_AT_IDLE=y # Enable TLS session caching to prevent doing a full TLS handshake when recovering the session CONFIG_LWM2M_TLS_SESSION_CACHING=y # Sets the duration that the lwm2m engine will be polling for data after transmission before # the socket is closed. # Adjust so that we can detach from network in 30 seconds -CONFIG_LWM2M_QUEUE_MODE_UPTIME=30 +CONFIG_LWM2M_QUEUE_MODE_UPTIME=61 # Set lifetime of 12 hours CONFIG_LWM2M_ENGINE_DEFAULT_LIFETIME=43200 # Do registration update after 5400 seconds (90 minutes) -CONFIG_LWM2M_UPDATE_PERIOD=5400 +CONFIG_LWM2M_UPDATE_PERIOD=59 CONFIG_LWM2M_SECONDS_TO_UPDATE_EARLY=60 # Configure PSM mode diff --git a/samples/cellular/lwm2m_client/src/main.c b/samples/cellular/lwm2m_client/src/main.c index fe1c00010..24e936268 100644 --- a/samples/cellular/lwm2m_client/src/main.c +++ b/samples/cellular/lwm2m_client/src/main.c @@ -65,7 +65,7 @@ static enum client_state { NETWORK_ERROR /* Client network error handling. Client stop and modem reset */ } client_state = START; -static uint8_t endpoint_name[ENDPOINT_NAME_LEN + 1]; +static uint8_t endpoint_name[ENDPOINT_NAME_LEN + 1]={"localhost123"}; static uint8_t imei_buf[IMEI_LEN + sizeof("\r\nOK\r\n")]; static struct lwm2m_ctx client = {0}; static bool reconnect; @@ -601,9 +601,9 @@ int main(void) } /* use IMEI as unique endpoint name */ - snprintk(endpoint_name, sizeof(endpoint_name), "%s%.*s", CONFIG_APP_ENDPOINT_PREFIX, - IMEI_LEN, imei_buf); - LOG_INF("endpoint: %s", (char *)endpoint_name); + // snprintk(endpoint_name, sizeof(endpoint_name), "%s%.*s", CONFIG_APP_ENDPOINT_PREFIX, + // IMEI_LEN, imei_buf); + // LOG_INF("endpoint: %s", (char *)endpoint_name); /* Setup LwM2M */ ret = lwm2m_setup();
To investigate this issue further, we used Wireshark to capture traffic on both the server and client sides. Below are our observations:
In the screenshot below, we can see the Wireshark logs from the server side:
- The client successfully registers with the LwM2M server.
- A GET operation is performed 15 seconds after the last activity, which completes successfully.
- A second GET operation is attempted 36 seconds after the last activity, but it times out.
- Subsequent re-registrations with the LwM2M server are successful.
The server appears to be functioning as per the LwM2M protocol specifications.
lwm2m_issue_serverside_v4.pcapng
In the first screenshot below, we can see the client successfully registering with the LwM2M server.
In the second screenshot, the server performs a GET operation 15 seconds after the last activity, which completes successfully.
In the third screenshot, we observe the modem waking up, likely triggered by downlink messaging. However, no UDP packets are received. This event coincides with the server's transmission 36 seconds after the last activity.
For reference, here are the relevant timestamps from the server-side logs:
lwm2m_issue_clientside_v2.pcapng
The root cause of this issue is still unclear.
Initially, I considered that it might be related to CG-NAT timing out the UDP tunnel, as our operator assigns us an IP address from the CG-NAT address space (see details below).
+CGDCONT: 0,"IPV4V6","omnitel","100.85.211.247 2A00:1EB8:C1DF:C63F:0000:0000:490E:94AC",0,0 OK
However, if CG-NAT were the cause, it seems unlikely that the network would still signal to the modem that there is pending downlink traffic.
Thoughts on what it might be related to?
