Hello!
Any and all guidance on the issue described below would be greatly appreciated! I am happy to provide any additional information.
Thank you for your time,
Josh
The System
- A Raspberry Pi 4 running the
otbr-agent
andchip-tool
commands. - nRF52840 USB dongle programmed with thread RCP firmware plugged into the Pi.
- An nRF5340-dk running the matter
light_bulb
sample using the nRF Connect SDK v2.5.1
The Problem
Attempting to add an endpoint to a third group results in Unable to listen to group
on the light_bulb
, but the command appears successful from chip-tool's perspective.
D: 54772 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9109 PSID:55899!
I: 54781 [IN]CASE Session established to peer: <000000000001B669, 1>
I: 54788 [IN]CASE Server enabling CASE session setups
D: 54796 [IN]SecureSession[0x200046f8]: Allocated Type:2 LSID:9110
I: 54806 [EM]>>> [E:293r S:9109 M:13683323] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 54829 [IN]Joining Multicast Group with address UDP:[ff35:40:fd00::100:5]:5540
E: 54836 [SVR]Unable to listen to group
I: 54844 [EM]<<< [E:293r S:9109 M:224548323 (Ack:13683323)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse)
The expected output is shown below, after adding the second group.
D: 53461 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9108 PSID:42909!
I: 53470 [IN]CASE Session established to peer: <000000000001B669, 1>
I: 53479 [IN]CASE Server enabling CASE session setups
D: 53487 [IN]SecureSession[0x20004640]: Allocated Type:2 LSID:9109
I: 53494 [EM]>>> [E:31925r S:9108 M:159503087] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 53516 [IN]Joining Multicast Group with address UDP:[ff35:40:fd00::100:4]:5540
I: 53530 [EM]<<< [E:31925r S:9108 M:251420196 (Ack:159503087)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 53545 [IN](S) Sending msg 251420196 on secure session with LSID: 9108
D: 53553 [DL]OpenThread State Changed (Flags: 0x00001000)
The full logs for both the Pi and the light_bulb
are attached.
2671.pi.log
I: Factory Reset Triggered. Release button within 3000ms to cancel.
I: 97162 [TS]Pending Last Known Good Time: 2024-10-25T11:19:57
I: 97169 [TS]Previous Last Known Good Time: 2024-10-25T11:19:57
I: 97175 [TS]Reverted Last Known Good Time to previous value
I: 97185 [FP]Fabric (0x1) deleted.
I: 97189 [ZCL]OpCreds: Fabric index 0x1 was removed
I: 97193 [DIS]Updating services using commissioning mode 0
I: 97198 [DL]removing srp service: A105A369AB1A8E13-0000000000000002._matter._tcp
E: 97231 [SVR]Group added to nonexistent fabric?
E: 97240 [SVR]Group added to nonexistent fabric?
E: 97248 [SVR]Group added to nonexistent fabric?
E: 97274 [DL]Long dispatch time: 112 ms, for event type 2
I: 97279 [DL]Performing factory reset
E: 97970 [DL]SRP update error: domain name or RRset is duplicated
uart:~$ *** Booting nRF Connect SDK v2.5.1 ***
I: Init CHIP stack
I: 157 [DL]BLE address: F4:FB:DB:E1:94:A7
I: 178 [DL]OpenThread started: OK
I: 181 [DL]Setting OpenThread device type to ROUTER
Configuring button #0: gpio@842500, 23, 17
Configuring button #1: gpio@842500, 24, 17
Configuring button #2: gpio@842500, 8, 17
Configuring button #3: gpio@842500, 9, 17
I: 201 [SVR]Subscription persistence not supported
I: 205 [SVR]Server initializing...
I: 209 [TS]Last Known Good Time: [unknown]
I: 212 [TS]Setting Last Known Good Time to firmware build time 2024-10-25T11:19:57
I: 221 [DMG]AccessControl: initializing
I: 224 [DMG]Examples::AccessControlDelegate::Init
I: 229 [DMG]AccessControl: setting
I: 232 [DMG]DefaultAclStorage: initializing
I: 235 [DMG]DefaultAclStorage: 0 entries loaded
D: 240 [IN]UDP::Init bind&listen port=5540
E: 244 [IN]SO_REUSEPORT failed: 109
D: 247 [IN]UDP::Init bound to port=5540
D: 250 [IN]BLEBase::Init - setting/overriding transport
D: 255 [IN]TransportMgr initialized
D: 261 [DL]Using Thread extended MAC for hostname.
I: 266 [ZCL]Using ZAP configuration...
I: 272 [DMG]AccessControlCluster: initializing
D: 276 [DL]Boot reason: 6
I: 279 [ZCL]Initiating Admin Commissioning cluster.
I: 283 [ZCL]Endpoint 1 On/off already set to new value
I: 289 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1
D: 296 [IN]SecureSession[0x200041f0]: Allocated Type:1 LSID:9102
D: 301 [DL]CHIPoBLE advertising set to on
I: 305 [DIS]Updating services using commissioning mode 1
E: 310 [DIS]Failed to remove advertised services: 3
D: 315 [DL]Using Thread extended MAC for hostname.
I: 319 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
E: 328 [DIS]Failed to advertise commissionable node: 3
E: 333 [DIS]Failed to finalize service update: 3
I: 337 [DIS]Updating services using commissioning mode 1
E: 342 [DIS]Failed to remove advertised services: 3
D: 347 [DL]Using Thread extended MAC for hostname.
I: 351 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
E: 360 [DIS]Failed to advertise commissionable node: 3
E: 365 [DIS]Failed to finalize service update: 3
I: 369 [DIS]Delaying proxy of operational discovery: missing delegate
I: 375 [IN]CASE Server enabling CASE session setups
D: 380 [IN]SecureSession[0x200042a8]: Allocated Type:2 LSID:9103
I: 386 [SVR]Joining Multicast groups
I: 389 [SVR]Server Listening...
I: 392 [DL]Device Configuration:
I: 395 [DL] Serial Number: 11223344556677889900
I: 399 [DL] Vendor Id: 65521 (0xFFF1)
I: 403 [DL] Product Id: 32773 (0x8005)
I: 406 [DL] Product Name: not-specified
I: 410 [DL] Hardware Version: 0
I: 413 [DL] Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 418 [DL] Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 425 [DL] Manufacturing Date: 2022-01-01
I: 428 [DL] Device Type: 65535 (0xFFFF)
I: 432 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00]
I: 436 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 443 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00
I: 451 [SVR]Manual pairing code: [34970112332]
I: 456 [DL]CHIP task running
I: 462 [DL]CHIPoBLE advertising started
I: 466 [ZCL]Cluster OnOff: attribute OnOff set to 0
I: 471 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
I: 477 [DL]NFC Tag emulation started
I: 15894 [DL]BLE connection established (ConnId: 0x00)
I: 15899 [DL]Current number of connections: 1/1
I: 15903 [DL]CHIPoBLE advertising stopped
I: 15907 [DL]NFC Tag emulation stopped
D: 17357 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 17364 [BLE]local and remote recv window sizes = 5
I: 17368 [BLE]selected BTP version 4
I: 17372 [BLE]using BTP fragment sizes rx 244 / tx 244.
D: 17447 [DL]ConnId: 0x00, New CCCD value: 0x0002
D: 17451 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
D: 17459 [IN]BLE EndPoint 0x20012208 Connection Complete
I: 17464 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247)
D: 17536 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 17545 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 17552 [EM]>>> [E:7513r S:0 M:186942528] (U) Msg RX from 0:38290223567E860A [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
I: 17565 [EM]<<< [E:7513r S:0 M:104315748] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
I: 17577 [IN](U) Sending msg 104315748 to IP address 'BLE'
D: 17582 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 140)
D: 17671 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 17680 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 17687 [EM]>>> [E:7513r S:0 M:186942529] (U) Msg RX from 0:38290223567E860A [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
I: 19036 [EM]<<< [E:7513r S:0 M:104315749] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
I: 19048 [IN](U) Sending msg 104315749 to IP address 'BLE'
D: 19053 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132)
E: 19060 [DL]Long dispatch time: 1381 ms, for event type 16388
D: 19111 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 19120 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 19127 [EM]>>> [E:7513r S:0 M:186942530] (U) Msg RX from 0:38290223567E860A [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
I: 19139 [EM]<<< [E:7513r S:0 M:104315750] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 19150 [IN](U) Sending msg 104315750 to IP address 'BLE'
D: 19155 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35)
I: 19164 [SC]SecureSession[0x200041f0]: Moving from state 'kEstablishing' --> 'kActive'
D: 19171 [IN]SecureSession[0x200041f0]: Activated - Type:1 LSID:9102
D: 19177 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:9102 PSID:53633!
I: 19186 [SVR]Commissioning completed session establishment step
I: 19192 [DIS]Updating services using commissioning mode 0
E: 19197 [DIS]Failed to remove advertised services: 3
E: 19202 [DIS]Failed to finalize service update: 3
D: 19207 [DL]CHIPoBLE advertising set to off
I: 19210 [SVR]Device completed Rendezvous process
D: 19247 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 19255 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 19263 [EM]>>> [E:7514r S:9102 M:112946105] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 19273 [IM]Received Read request
I: 19283 [EM]<<< [E:7514r S:9102 M:75546762] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 19293 [IN](S) Sending msg 75546762 on secure session with LSID: 9102
D: 19299 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 19427 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 19434 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 21)
D: 19517 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 19525 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 19533 [EM]>>> [E:7515r S:9102 M:112946106] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 19543 [IM]Received Read request
I: 19550 [EM]<<< [E:7515r S:9102 M:75546763] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 19561 [IN](S) Sending msg 75546763 on secure session with LSID: 9102
D: 19567 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 185)
D: 19652 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 19660 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 19667 [EM]>>> [E:7516r S:9102 M:112946107] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 19679 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
I: 19686 [EM]<<< [E:7516r S:9102 M:75546764] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 19697 [IN](S) Sending msg 75546764 on secure session with LSID: 9102
D: 19703 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 19787 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 19795 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 19803 [EM]>>> [E:7517r S:9102 M:112946108] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 19816 [EM]<<< [E:7517r S:9102 M:75546765] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 19828 [IN](S) Sending msg 75546765 on secure session with LSID: 9102
D: 19834 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 19967 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20012 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 20020 [EM]>>> [E:7518r S:9102 M:112946109] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 20032 [ZCL]OpCreds: Certificate Chain request received for PAI
I: 20041 [EM]<<< [E:7518r S:9102 M:75546766] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 20052 [IN](S) Sending msg 75546766 on secure session with LSID: 9102
D: 20058 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 20147 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20154 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 20237 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20244 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 48)
D: 20327 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20335 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 20343 [EM]>>> [E:7519r S:9102 M:112946110] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 20354 [ZCL]OpCreds: Certificate Chain request received for DAC
I: 20364 [EM]<<< [E:7519r S:9102 M:75546767] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 20375 [IN](S) Sending msg 75546767 on secure session with LSID: 9102
D: 20381 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 20462 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20469 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 20552 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20559 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 77)
D: 20642 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20650 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 20658 [EM]>>> [E:7520r S:9102 M:112946111] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 20669 [ZCL]OpCreds: Received an AttestationRequest command
I: 20704 [ZCL]OpCreds: AttestationRequest successful.
I: 20713 [EM]<<< [E:7520r S:9102 M:75546768] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 20724 [IN](S) Sending msg 75546768 on secure session with LSID: 9102
D: 20731 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 20822 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20829 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 20912 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 20919 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 237)
D: 21002 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 21047 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 21055 [EM]>>> [E:7521r S:9102 M:112946112] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 21067 [ZCL]OpCreds: Received a CSRRequest command
I: 21212 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 21246 [ZCL]OpCreds: CSRRequest successful.
I: 21253 [EM]<<< [E:7521r S:9102 M:75546769] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 21264 [IN](S) Sending msg 75546769 on secure session with LSID: 9102
D: 21270 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
E: 21278 [DL]Long dispatch time: 231 ms, for event type 16388
D: 21362 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 21369 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 138)
D: 21452 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 21460 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 21542 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 21551 [EM]>>> [E:7522r S:9102 M:112946113] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 21563 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
I: 21622 [ZCL]OpCreds: AddTrustedRootCertificate successful.
I: 21628 [EM]<<< [E:7522r S:9102 M:75546770] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 21640 [IN](S) Sending msg 75546770 on secure session with LSID: 9102
D: 21646 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68)
E: 21654 [DL]Long dispatch time: 111 ms, for event type 16388
D: 21812 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 21820 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 21904 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 21993 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 22003 [EM]>>> [E:7523r S:9102 M:112946114] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 22015 [ZCL]OpCreds: Received an AddNOC command
I: 22021 [FP]Validating NOC chain
I: 22130 [FP]NOC chain validation successful
I: 22134 [FP]Added new fabric at index: 0x1
I: 22138 [FP]Assigned compressed fabric ID: 0x33E88E3B87C86DF1, node ID: 0x0000000000000002
I: 22146 [TS]Last Known Good Time: 2024-10-25T11:19:57
I: 22151 [TS]New proposed Last Known Good Time: 2021-01-01T00:00:00
I: 22157 [TS]Retaining current Last Known Good Time
I: 22170 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x000000000001B669
D: 22178 [DL]Using Thread extended MAC for hostname.
I: 22183 [DIS]Advertise operational node 33E88E3B87C86DF1-0000000000000002
I: 22190 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC
I: 22197 [EM]<<< [E:7523r S:9102 M:75546771] (S) Msg TX to 1:FFFFFFFB00000000 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 22208 [IN](S) Sending msg 75546771 on secure session with LSID: 9102
D: 22214 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
E: 22222 [DL]Long dispatch time: 230 ms, for event type 16388
D: 22307 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 22315 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 22323 [EM]>>> [E:7524r S:9102 M:112946115] (S) Msg RX from 1:FFFFFFFB00000000 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 22337 [EM]<<< [E:7524r S:9102 M:75546772] (S) Msg TX to 1:FFFFFFFB00000000 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 22348 [IN](S) Sending msg 75546772 on secure session with LSID: 9102
D: 22355 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 22442 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 22450 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 22458 [EM]>>> [E:7525r S:9102 M:112946116] (S) Msg RX from 1:FFFFFFFB00000000 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 22469 [FS]GeneralCommissioning: Received ArmFailSafe (65s)
I: 22476 [EM]<<< [E:7525r S:9102 M:75546773] (S) Msg TX to 1:FFFFFFFB00000000 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 22487 [IN](S) Sending msg 75546773 on secure session with LSID: 9102
D: 22493 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 22622 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 22630 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 22638 [EM]>>> [E:7526r S:9102 M:112946117] (S) Msg RX from 1:FFFFFFFB00000000 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 22659 [DL]OpenThread State Changed (Flags: 0x101fc100)
D: 22664 [DL] Network Name: TestNet
D: 22668 [DL] PAN Id: 0x976E
D: 22671 [DL] Extended PAN Id: 0xF581065E27EB4A59
D: 22675 [DL] Channel: 11
D: 22678 [DL] Mesh Prefix: fd00:c0ce:7ac8:4a81::/64
D: 22683 [DL]OpenThread State Changed (Flags: 0x1100101d)
D: 22688 [DL] Device Role: DETACHED
D: 22691 [DL] Thread Unicast Addresses:
D: 22695 [DL] fd00:c0ce:7ac8:4a81:43e3:1ee4:7ab8:f51f/64 valid
D: 22701 [DL] fe80::3856:f144:bcc3:6af7/64 valid preferred
D: 23547 [DL]OpenThread State Changed (Flags: 0x200012a4)
D: 23552 [DL] Device Role: CHILD
D: 23555 [DL] Partition Id: 0xBD3375C
D: 23559 [DL]OpenThread State Changed (Flags: 0x00000001)
D: 23565 [DL] Thread Unicast Addresses:
D: 23568 [DL] fd08:b89:78:f372:e6b7:a3aa:434e:8787/64 valid preferred
D: 23575 [DL] fd00:c0ce:7ac8:4a81:0:ff:fe00:5001/64 valid rloc
D: 23581 [DL] fd00:c0ce:7ac8:4a81:43e3:1ee4:7ab8:f51f/64 valid
D: 23587 [DL] fe80::3856:f144:bcc3:6af7/64 valid preferred
I: 23595 [EM]<<< [E:7526r S:9102 M:75546774] (S) Msg TX to 1:FFFFFFFB00000000 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 23606 [IN](S) Sending msg 75546774 on secure session with LSID: 9102
D: 23612 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70)
D: 23620 [DL]Using Thread extended MAC for hostname.
I: 23625 [DIS]Advertise operational node 33E88E3B87C86DF1-0000000000000002
I: 23631 [SVR]Operational advertising enabled
D: 23747 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 26222 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 28729 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 28787 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 29653 [DL]OpenThread State Changed (Flags: 0x00000200)
D: 31262 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 33769 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 33827 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
I: 35533 [DL]SRP Client was started, detected server: fd00:c0ce:7ac8:4a81:ca34:3c9c:4f64:2a2b
D: 35541 [DL]OpenThread State Changed (Flags: 0x00000200)
D: 36227 [DL]SRP update succeeded
I: 36230 [DIS]Setting operational delegate post init
I: 36238 [SWU]Stopping the watchdog timer
I: 36241 [SWU]Starting the periodic query timer, timeout: 86400 seconds
E: 36248 [SVR]Server initialization complete
I: 36252 [DIS]Updating services using commissioning mode 0
D: 36257 [DL]Using Thread extended MAC for hostname.
I: 36261 [DIS]Advertise operational node 33E88E3B87C86DF1-0000000000000002
I: 36268 [DL]advertising srp service: 33E88E3B87C86DF1-0000000000000002._matter._tcp
D: 36302 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 37537 [DL]SRP update succeeded
I: 37818 [EM]>>> [E:7527r S:0 M:186942531] (U) Msg RX from 0:91BDC9466F783843 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 37830 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0
I: 37837 [IN]CASE Server disabling CASE session setups
I: 37842 [EM]<<< [E:7527r S:0 M:104315751 (Ack:186942531)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 37855 [IN](U) Sending msg 104315751 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:37745'
I: 37865 [SC]Received Sigma1 msg
I: 37871 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002
I: 38046 [EM]<<< [E:7527r S:0 M:104315752 (Ack:186942531)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
I: 38059 [IN](U) Sending msg 104315752 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:37745'
I: 38070 [SC]Sent Sigma2 msg
I: 38266 [EM]>>> [E:7527r S:0 M:186942532 (Ack:104315752)] (U) Msg RX from 0:91BDC9466F783843 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
I: 38279 [EM]<<< [E:7527r S:0 M:104315753 (Ack:186942532)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 38292 [IN](U) Sending msg 104315753 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:37745'
I: 38302 [SC]Received Sigma3 msg
E: 38310 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time
E: 38480 [DL]Long dispatch time: 158 ms, for event type 2
I: 38490 [EM]<<< [E:7527r S:0 M:104315754 (Ack:186942532)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 38503 [IN](U) Sending msg 104315754 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:37745'
I: 38514 [SC]SecureSession[0x200042a8]: Moving from state 'kEstablishing' --> 'kActive'
D: 38522 [IN]SecureSession[0x200042a8]: Activated - Type:2 LSID:9103
D: 38529 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9103 PSID:53634!
I: 38540 [IN]CASE Session established to peer: <000000000001B669, 1>
I: 38549 [IN]CASE Server enabling CASE session setups
D: 38554 [IN]SecureSession[0x20004360]: Allocated Type:2 LSID:9104
I: 38561 [EM]>>> [E:7528r S:9103 M:201472173] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 38573 [FS]GeneralCommissioning: Received CommissioningComplete
I: 38581 [FP]Metadata for Fabric 0x1 persisted to storage.
I: 38599 [TS]Committing Last Known Good Time to storage: 2024-10-25T11:19:57
I: 38607 [ZCL]OpCreds: Fabric index 0x1 was committed to storage. Compressed Fabric Id 0x33E88E3B87C86DF1, FabricId 0000000000000001, NodeId 0000000000000002, VendorId 0xFFF1
I: 38623 [FS]GeneralCommissioning: Successfully commited pending fabric data
I: 38629 [FS]Fail-safe cleanly disarmed
I: 38634 [EM]<<< [E:7528r S:9103 M:144370371 (Ack:201472173)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 38647 [IN](S) Sending msg 144370371 on secure session with LSID: 9103
I: 38655 [SWU]Device commissioned, schedule a default provider query
I: 38661 [SVR]Commissioning completed successfully
I: 38666 [DIS]Updating services using commissioning mode 0
D: 38672 [DL]Using Thread extended MAC for hostname.
I: 38677 [DIS]Advertise operational node 33E88E3B87C86DF1-0000000000000002
D: 38685 [IN]Expiring all PASE sessions
D: 38689 [IN]SecureSession[0x200041f0]: MarkForEviction Type:1 LSID:9102
I: 38696 [SC]SecureSession[0x200041f0]: Moving from state 'kActive' --> 'kPendingEviction'
D: 38705 [IN]SecureSession[0x200041f0]: Released - Type:1 LSID:9102
D: 38711 [IN]Clearing BLE pending packets.
I: 38714 [BLE]Releasing end point's BLE connection back to application.
I: 38721 [DL]Closing BLE GATT connection (ConnId 00)
I: 38727 [EM]>>> [E:7527r S:0 M:186942533 (Ack:104315754)] (U) Msg RX from 0:91BDC9466F783843 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
E: not connected!
D: 38742 [DL]ConnId: 0x00, New CCCD value: 0x0000
E: 38746 [BLE]no endpoint for unsub recvd
I: 38777 [DL]BLE GAP connection terminated (reason 0x16)
I: 38782 [DL]Current number of connections: 0/1
I: 38969 [EM]>>> [E:7528r S:9103 M:201472174 (Ack:144370371)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 44744 [EM]>>> [E:24806r S:0 M:96832576] (U) Msg RX from 0:874CD040C22C4025 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 44756 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0
I: 44763 [IN]CASE Server disabling CASE session setups
I: 44768 [EM]<<< [E:24806r S:0 M:104315755 (Ack:96832576)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 44781 [IN](U) Sending msg 104315755 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:45405'
I: 44791 [SC]Received Sigma1 msg
I: 44798 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002
I: 44977 [EM]<<< [E:24806r S:0 M:104315756 (Ack:96832576)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
I: 44990 [IN](U) Sending msg 104315756 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:45405'
I: 45001 [SC]Sent Sigma2 msg
I: 45553 [EM]>>> [E:24806r S:0 M:96832577 (Ack:104315756)] (U) Msg RX from 0:874CD040C22C4025 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
I: 45566 [EM]<<< [E:24806r S:0 M:104315757 (Ack:96832577)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 45579 [IN](U) Sending msg 104315757 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:45405'
I: 45588 [SC]Received Sigma3 msg
E: 45598 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time
E: 45766 [DL]Long dispatch time: 158 ms, for event type 2
I: 45776 [EM]<<< [E:24806r S:0 M:104315758 (Ack:96832577)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 45788 [IN](U) Sending msg 104315758 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:45405'
I: 45800 [SC]SecureSession[0x20004360]: Moving from state 'kEstablishing' --> 'kActive'
D: 45808 [IN]SecureSession[0x20004360]: Activated - Type:2 LSID:9104
D: 45815 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9104 PSID:17040!
I: 45823 [IN]CASE Session established to peer: <000000000001B669, 1>
I: 45831 [IN]CASE Server enabling CASE session setups
D: 45839 [IN]SecureSession[0x200041f0]: Allocated Type:2 LSID:9105
I: 45849 [EM]>>> [E:24807r S:9104 M:144708553] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 45874 [EM]<<< [E:24807r S:9104 M:22522419 (Ack:144708553)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 45887 [IN](S) Sending msg 22522419 on secure session with LSID: 9104
I: 45895 [EM]>>> [E:24806r S:0 M:96832578 (Ack:104315758)] (U) Msg RX from 0:874CD040C22C4025 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 45912 [EM]>>> [E:24807r S:9104 M:144708554 (Ack:22522419)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 47882 [EM]>>> [E:43737r S:0 M:131468757] (U) Msg RX from 0:D45EA1C0ED911ADA [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 47894 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0
I: 47901 [IN]CASE Server disabling CASE session setups
I: 47906 [EM]<<< [E:43737r S:0 M:104315759 (Ack:131468757)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 47919 [IN](U) Sending msg 104315759 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:40931'
I: 47929 [SC]Received Sigma1 msg
I: 47939 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002
I: 48113 [EM]<<< [E:43737r S:0 M:104315760 (Ack:131468757)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
I: 48126 [IN](U) Sending msg 104315760 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:40931'
I: 48137 [SC]Sent Sigma2 msg
I: 48320 [EM]>>> [E:43737r S:0 M:131468758 (Ack:104315760)] (U) Msg RX from 0:D45EA1C0ED911ADA [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
I: 48333 [EM]<<< [E:43737r S:0 M:104315761 (Ack:131468758)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 48346 [IN](U) Sending msg 104315761 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:40931'
I: 48356 [SC]Received Sigma3 msg
E: 48365 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time
E: 48534 [DL]Long dispatch time: 159 ms, for event type 2
I: 48543 [EM]<<< [E:43737r S:0 M:104315762 (Ack:131468758)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 48556 [IN](U) Sending msg 104315762 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:40931'
I: 48568 [SC]SecureSession[0x200041f0]: Moving from state 'kEstablishing' --> 'kActive'
D: 48576 [IN]SecureSession[0x200041f0]: Activated - Type:2 LSID:9105
D: 48583 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9105 PSID:21875!
I: 48593 [IN]CASE Session established to peer: <000000000001B669, 1>
I: 48600 [IN]CASE Server enabling CASE session setups
D: 48609 [IN]SecureSession[0x20004418]: Allocated Type:2 LSID:9106
I: 48617 [EM]>>> [E:43738r S:9105 M:18085730] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:06 (IM:WriteRequest)
D: 48628 [IM]Received Write request
I: 48651 [EM]<<< [E:43738r S:9105 M:94780723 (Ack:18085730)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:07 (IM:WriteResponse)
I: 48662 [IN](S) Sending msg 94780723 on secure session with LSID: 9105
I: 48671 [EM]>>> [E:43737r S:0 M:131468759 (Ack:104315762)] (U) Msg RX from 0:D45EA1C0ED911ADA [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 48717 [EM]>>> [E:43738r S:9105 M:18085731 (Ack:94780723)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 49183 [EM]>>> [E:13694r S:0 M:10934429] (U) Msg RX from 0:ADE94DC61A2855C1 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 49195 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0
I: 49202 [IN]CASE Server disabling CASE session setups
I: 49207 [EM]<<< [E:13694r S:0 M:104315763 (Ack:10934429)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 49220 [IN](U) Sending msg 104315763 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:41559'
I: 49230 [SC]Received Sigma1 msg
I: 49241 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002
I: 49416 [EM]<<< [E:13694r S:0 M:104315764 (Ack:10934429)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
I: 49428 [IN](U) Sending msg 104315764 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:41559'
I: 49439 [SC]Sent Sigma2 msg
I: 50348 [IN](U) Sending msg 104315764 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:41559'
I: 50546 [EM]>>> [E:13694r S:0 M:10934430 (Ack:104315764)] (U) Msg RX from 0:ADE94DC61A2855C1 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
I: 50559 [EM]<<< [E:13694r S:0 M:104315765 (Ack:10934430)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 50572 [IN](U) Sending msg 104315765 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:41559'
I: 50581 [SC]Received Sigma3 msg
E: 50590 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time
E: 50759 [DL]Long dispatch time: 159 ms, for event type 2
I: 50769 [EM]<<< [E:13694r S:0 M:104315766 (Ack:10934430)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 50782 [IN](U) Sending msg 104315766 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:41559'
I: 50793 [SC]SecureSession[0x20004418]: Moving from state 'kEstablishing' --> 'kActive'
D: 50802 [IN]SecureSession[0x20004418]: Activated - Type:2 LSID:9106
D: 50808 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9106 PSID:43125!
I: 50817 [IN]CASE Session established to peer: <000000000001B669, 1>
I: 50825 [IN]CASE Server enabling CASE session setups
D: 50833 [IN]SecureSession[0x200044d0]: Allocated Type:2 LSID:9107
I: 50843 [EM]>>> [E:13695r S:9106 M:144439525] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:06 (IM:WriteRequest)
D: 50854 [IM]Received Write request
I: 50866 [EM]<<< [E:13695r S:9106 M:168675876 (Ack:144439525)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:07 (IM:WriteResponse)
I: 50878 [IN](S) Sending msg 168675876 on secure session with LSID: 9106
I: 50887 [EM]>>> [E:13694r S:0 M:10934431 (Ack:104315766)] (U) Msg RX from 0:ADE94DC61A2855C1 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 50920 [EM]>>> [E:13695r S:9106 M:144439526 (Ack:168675876)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 51457 [EM]>>> [E:35018r S:0 M:25195827] (U) Msg RX from 0:E94EDC7C067D0417 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 51468 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0
I: 51475 [IN]CASE Server disabling CASE session setups
I: 51481 [EM]<<< [E:35018r S:0 M:104315767 (Ack:25195827)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 51493 [IN](U) Sending msg 104315767 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:50328'
I: 51503 [SC]Received Sigma1 msg
I: 51514 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002
I: 51689 [EM]<<< [E:35018r S:0 M:104315768 (Ack:25195827)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
I: 51702 [IN](U) Sending msg 104315768 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:50328'
I: 51713 [SC]Sent Sigma2 msg
I: 51858 [EM]>>> [E:35018r S:0 M:25195828 (Ack:104315768)] (U) Msg RX from 0:E94EDC7C067D0417 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
I: 51871 [EM]<<< [E:35018r S:0 M:104315769 (Ack:25195828)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 51884 [IN](U) Sending msg 104315769 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:50328'
I: 51894 [SC]Received Sigma3 msg
E: 51903 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time
E: 52071 [DL]Long dispatch time: 158 ms, for event type 2
I: 52081 [EM]<<< [E:35018r S:0 M:104315770 (Ack:25195828)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 52094 [IN](U) Sending msg 104315770 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:50328'
I: 52106 [SC]SecureSession[0x200044d0]: Moving from state 'kEstablishing' --> 'kActive'
D: 52114 [IN]SecureSession[0x200044d0]: Activated - Type:2 LSID:9107
D: 52120 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9107 PSID:45636!
I: 52129 [IN]CASE Session established to peer: <000000000001B669, 1>
I: 52136 [IN]CASE Server enabling CASE session setups
D: 52145 [IN]SecureSession[0x20004588]: Allocated Type:2 LSID:9108
I: 52152 [EM]>>> [E:35019r S:9107 M:131641130] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 52260 [IN]Joining Multicast Group with address UDP:[ff35:40:fd00::100:3]:5540
I: 52273 [EM]<<< [E:35019r S:9107 M:61795445 (Ack:131641130)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 52287 [IN](S) Sending msg 61795445 on secure session with LSID: 9107
D: 52296 [DL]OpenThread State Changed (Flags: 0x00001000)
I: 52305 [EM]>>> [E:35018r S:0 M:25195829 (Ack:104315770)] (U) Msg RX from 0:E94EDC7C067D0417 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 52322 [EM]>>> [E:35019r S:9107 M:131641131 (Ack:61795445)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 52801 [EM]>>> [E:31924r S:0 M:90630522] (U) Msg RX from 0:B13ABCE9099778FA [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 52813 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0
I: 52820 [IN]CASE Server disabling CASE session setups
I: 52825 [EM]<<< [E:31924r S:0 M:104315771 (Ack:90630522)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 52838 [IN](U) Sending msg 104315771 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:43307'
I: 52848 [SC]Received Sigma1 msg
I: 52859 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002
I: 53036 [EM]<<< [E:31924r S:0 M:104315772 (Ack:90630522)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
I: 53048 [IN](U) Sending msg 104315772 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:43307'
I: 53059 [SC]Sent Sigma2 msg
I: 53198 [EM]>>> [E:31924r S:0 M:90630523 (Ack:104315772)] (U) Msg RX from 0:B13ABCE9099778FA [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
I: 53212 [EM]<<< [E:31924r S:0 M:104315773 (Ack:90630523)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 53224 [IN](U) Sending msg 104315773 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:43307'
I: 53234 [SC]Received Sigma3 msg
E: 53242 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time
E: 53412 [DL]Long dispatch time: 159 ms, for event type 2
I: 53422 [EM]<<< [E:31924r S:0 M:104315774 (Ack:90630523)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 53435 [IN](U) Sending msg 104315774 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:43307'
I: 53447 [SC]SecureSession[0x20004588]: Moving from state 'kEstablishing' --> 'kActive'
D: 53455 [IN]SecureSession[0x20004588]: Activated - Type:2 LSID:9108
I: 53562 [EM]>>> [E:31924r S:0 M:90630524 (Ack:104315774)] (U) Msg RX from 0:B13ABCE9099778FA [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 53579 [EM]>>> [E:31925r S:9108 M:159503088 (Ack:251420196)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 54055 [EM]>>> [E:292r S:0 M:197602012] (U) Msg RX from 0:6CB14E2CCDE22560 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 54066 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0
I: 54074 [IN]CASE Server disabling CASE session setups
I: 54079 [EM]<<< [E:292r S:0 M:104315775 (Ack:197602012)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 54091 [IN](U) Sending msg 104315775 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:55917'
I: 54101 [SC]Received Sigma1 msg
I: 54113 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002
I: 54301 [EM]<<< [E:292r S:0 M:104315776 (Ack:197602012)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
I: 54313 [IN](U) Sending msg 104315776 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:55917'
I: 54324 [SC]Sent Sigma2 msg
D: 54327 [DL]OpenThread State Changed (Flags: 0x00000064)
D: 54332 [DL] Device Role: ROUTER
I: 54509 [EM]>>> [E:292r S:0 M:197602013 (Ack:104315776)] (U) Msg RX from 0:6CB14E2CCDE22560 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
I: 54522 [EM]<<< [E:292r S:0 M:104315777 (Ack:197602013)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 54534 [IN](U) Sending msg 104315777 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:55917'
I: 54544 [SC]Received Sigma3 msg
E: 54553 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time
E: 54722 [DL]Long dispatch time: 159 ms, for event type 2
I: 54733 [EM]<<< [E:292r S:0 M:104315778 (Ack:197602013)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 54745 [IN](U) Sending msg 104315778 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:55917'
I: 54757 [SC]SecureSession[0x20004640]: Moving from state 'kEstablishing' --> 'kActive'
D: 54765 [IN]SecureSession[0x20004640]: Activated - Type:2 LSID:9109
I: 54856 [IN](S) Sending msg 224548323 on secure session with LSID: 9109
I: 54865 [EM]>>> [E:292r S:0 M:197602014 (Ack:104315778)] (U) Msg RX from 0:6CB14E2CCDE22560 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 54902 [EM]>>> [E:293r S:9109 M:13683324 (Ack:224548323)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 55164 [EM]>>> [E:28831r S:3 M:220765547] (G) Msg RX from 1:000000000001B669 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 55179 [EM]Received Groupcast Message with GroupId 0x0003 (3)
I: 55187 [ZCL]Toggle ep1 on/off from state 0 to 1
I: 55192 [ZCL]On Command - OffWaitTime : 0
I: 55196 [ZCL]On/Toggle Command - Stop Timer
I: 55202 [ZCL]Cluster OnOff: attribute OnOff set to 1
I: Turn On Action has been initiated
I: Turn On Action has been completed
I: 55214 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1
I: Level Action has been initiated
I: Setting brightness level to 1
I: Level Action has been completed
I: 55231 [ZCL]Event: move from 1
I: 55234 [ZCL] to 254
I: 55236 [ZCL](diff +1)
I: 55238 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
I: Setting brightness level to 254
I: 57480 [EM]>>> [E:25461r S:3 M:220766547] (G) Msg RX from 1:000000000001B669 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 57491 [EM]Received Groupcast Message with GroupId 0x0003 (3)
I: 57500 [ZCL]Toggle ep1 on/off from state 1 to 0
I: 57508 [ZCL]Event: move from 254
I: 57511 [ZCL] to 1
I: 57514 [ZCL](diff -1)
I: 57516 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1
I: 57531 [ZCL]Setting on/off to OFF due to level change
I: 57536 [ZCL]Toggle ep1 on/off from state 1 to 0
I: 57541 [ZCL]Cluster OnOff: attribute OnOff set to 0
I: Turn Off Action has been initiated
I: Turn Off Action has been completed
I: 57553 [ZCL]Off completed. reset OnTime to 0
I: 57557 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
I: 59780 [EM]>>> [E:9389r S:4 M:220767547] (G) Msg RX from 1:000000000001B669 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 59792 [EM]Received Groupcast Message with GroupId 0x0004 (4)
I: 59801 [ZCL]Toggle ep1 on/off from state 0 to 1
I: 59806 [ZCL]On Command - OffWaitTime : 0
I: 59810 [ZCL]On/Toggle Command - Stop Timer
I: 59816 [ZCL]Cluster OnOff: attribute OnOff set to 1
I: 59828 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1
I: 59835 [ZCL]Event: move from 1
I: 59838 [ZCL] to 254
I: 59840 [ZCL](diff +1)
I: 59842 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
I: 61988 [EM]>>> [E:18369r S:4 M:220768547] (G) Msg RX from 1:000000000001B669 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 62001 [EM]Received Groupcast Message with GroupId 0x0004 (4)
I: 62011 [ZCL]Toggle ep1 on/off from state 1 to 0
I: 62017 [ZCL]Event: move from 254
I: 62020 [ZCL] to 1
I: 62022 [ZCL](diff -1)
I: 62025 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1
I: 62040 [ZCL]Setting on/off to OFF due to level change
I: 62045 [ZCL]Toggle ep1 on/off from state 1 to 0
I: 62050 [ZCL]Cluster OnOff: attribute OnOff set to 0
I: 62061 [ZCL]Off completed. reset OnTime to 0
I: 62065 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
E: 68661 [SWU]No suitable OTA Provider candidate found
I: 68666 [SWU]No provider available
I: Factory Reset Triggered. Release button within 3000ms to cancel. I: 97162 [TS]Pending Last Known Good Time: 2024-10-25T11:19:57 I: 97169 [TS]Previous Last Known Good Time: 2024-10-25T11:19:57 I: 97175 [TS]Reverted Last Known Good Time to previous value I: 97185 [FP]Fabric (0x1) deleted. I: 97189 [ZCL]OpCreds: Fabric index 0x1 was removed I: 97193 [DIS]Updating services using commissioning mode 0 I: 97198 [DL]removing srp service: A105A369AB1A8E13-0000000000000002._matter._tcp E: 97231 [SVR]Group added to nonexistent fabric? E: 97240 [SVR]Group added to nonexistent fabric? E: 97248 [SVR]Group added to nonexistent fabric? E: 97274 [DL]Long dispatch time: 112 ms, for event type 2 I: 97279 [DL]Performing factory reset E: 97970 [DL]SRP update error: domain name or RRset is duplicated uart:~$ *** Booting nRF Connect SDK v2.5.1 *** I: Init CHIP stack I: 157 [DL]BLE address: F4:FB:DB:E1:94:A7 I: 178 [DL]OpenThread started: OK I: 181 [DL]Setting OpenThread device type to ROUTER Configuring button #0: gpio@842500, 23, 17 Configuring button #1: gpio@842500, 24, 17 Configuring button #2: gpio@842500, 8, 17 Configuring button #3: gpio@842500, 9, 17 I: 201 [SVR]Subscription persistence not supported I: 205 [SVR]Server initializing... I: 209 [TS]Last Known Good Time: [unknown] I: 212 [TS]Setting Last Known Good Time to firmware build time 2024-10-25T11:19:57 I: 221 [DMG]AccessControl: initializing I: 224 [DMG]Examples::AccessControlDelegate::Init I: 229 [DMG]AccessControl: setting I: 232 [DMG]DefaultAclStorage: initializing I: 235 [DMG]DefaultAclStorage: 0 entries loaded D: 240 [IN]UDP::Init bind&listen port=5540 E: 244 [IN]SO_REUSEPORT failed: 109 D: 247 [IN]UDP::Init bound to port=5540 D: 250 [IN]BLEBase::Init - setting/overriding transport D: 255 [IN]TransportMgr initialized D: 261 [DL]Using Thread extended MAC for hostname. I: 266 [ZCL]Using ZAP configuration... I: 272 [DMG]AccessControlCluster: initializing D: 276 [DL]Boot reason: 6 I: 279 [ZCL]Initiating Admin Commissioning cluster. I: 283 [ZCL]Endpoint 1 On/off already set to new value I: 289 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1 D: 296 [IN]SecureSession[0x200041f0]: Allocated Type:1 LSID:9102 D: 301 [DL]CHIPoBLE advertising set to on I: 305 [DIS]Updating services using commissioning mode 1 E: 310 [DIS]Failed to remove advertised services: 3 D: 315 [DL]Using Thread extended MAC for hostname. I: 319 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 E: 328 [DIS]Failed to advertise commissionable node: 3 E: 333 [DIS]Failed to finalize service update: 3 I: 337 [DIS]Updating services using commissioning mode 1 E: 342 [DIS]Failed to remove advertised services: 3 D: 347 [DL]Using Thread extended MAC for hostname. I: 351 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 E: 360 [DIS]Failed to advertise commissionable node: 3 E: 365 [DIS]Failed to finalize service update: 3 I: 369 [DIS]Delaying proxy of operational discovery: missing delegate I: 375 [IN]CASE Server enabling CASE session setups D: 380 [IN]SecureSession[0x200042a8]: Allocated Type:2 LSID:9103 I: 386 [SVR]Joining Multicast groups I: 389 [SVR]Server Listening... I: 392 [DL]Device Configuration: I: 395 [DL] Serial Number: 11223344556677889900 I: 399 [DL] Vendor Id: 65521 (0xFFF1) I: 403 [DL] Product Id: 32773 (0x8005) I: 406 [DL] Product Name: not-specified I: 410 [DL] Hardware Version: 0 I: 413 [DL] Setup Pin Code (0 for UNKNOWN/ERROR): 20202021 I: 418 [DL] Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00) I: 425 [DL] Manufacturing Date: 2022-01-01 I: 428 [DL] Device Type: 65535 (0xFFFF) I: 432 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00] I: 436 [SVR]Copy/paste the below URL in a browser to see the QR Code: I: 443 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00 I: 451 [SVR]Manual pairing code: [34970112332] I: 456 [DL]CHIP task running I: 462 [DL]CHIPoBLE advertising started I: 466 [ZCL]Cluster OnOff: attribute OnOff set to 0 I: 471 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254 I: 477 [DL]NFC Tag emulation started I: 15894 [DL]BLE connection established (ConnId: 0x00) I: 15899 [DL]Current number of connections: 1/1 I: 15903 [DL]CHIPoBLE advertising stopped I: 15907 [DL]NFC Tag emulation stopped D: 17357 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 17364 [BLE]local and remote recv window sizes = 5 I: 17368 [BLE]selected BTP version 4 I: 17372 [BLE]using BTP fragment sizes rx 244 / tx 244. D: 17447 [DL]ConnId: 0x00, New CCCD value: 0x0002 D: 17451 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6) D: 17459 [IN]BLE EndPoint 0x20012208 Connection Complete I: 17464 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247) D: 17536 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 17545 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 17552 [EM]>>> [E:7513r S:0 M:186942528] (U) Msg RX from 0:38290223567E860A [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) I: 17565 [EM]<<< [E:7513r S:0 M:104315748] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) I: 17577 [IN](U) Sending msg 104315748 to IP address 'BLE' D: 17582 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 140) D: 17671 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 17680 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 17687 [EM]>>> [E:7513r S:0 M:186942529] (U) Msg RX from 0:38290223567E860A [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1) I: 19036 [EM]<<< [E:7513r S:0 M:104315749] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2) I: 19048 [IN](U) Sending msg 104315749 to IP address 'BLE' D: 19053 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132) E: 19060 [DL]Long dispatch time: 1381 ms, for event type 16388 D: 19111 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 19120 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 19127 [EM]>>> [E:7513r S:0 M:186942530] (U) Msg RX from 0:38290223567E860A [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3) I: 19139 [EM]<<< [E:7513r S:0 M:104315750] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport) I: 19150 [IN](U) Sending msg 104315750 to IP address 'BLE' D: 19155 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35) I: 19164 [SC]SecureSession[0x200041f0]: Moving from state 'kEstablishing' --> 'kActive' D: 19171 [IN]SecureSession[0x200041f0]: Activated - Type:1 LSID:9102 D: 19177 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:9102 PSID:53633! I: 19186 [SVR]Commissioning completed session establishment step I: 19192 [DIS]Updating services using commissioning mode 0 E: 19197 [DIS]Failed to remove advertised services: 3 E: 19202 [DIS]Failed to finalize service update: 3 D: 19207 [DL]CHIPoBLE advertising set to off I: 19210 [SVR]Device completed Rendezvous process D: 19247 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 19255 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 19263 [EM]>>> [E:7514r S:9102 M:112946105] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 19273 [IM]Received Read request I: 19283 [EM]<<< [E:7514r S:9102 M:75546762] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 19293 [IN](S) Sending msg 75546762 on secure session with LSID: 9102 D: 19299 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 19427 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 19434 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 21) D: 19517 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 19525 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 19533 [EM]>>> [E:7515r S:9102 M:112946106] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 19543 [IM]Received Read request I: 19550 [EM]<<< [E:7515r S:9102 M:75546763] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 19561 [IN](S) Sending msg 75546763 on secure session with LSID: 9102 D: 19567 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 185) D: 19652 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 19660 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 19667 [EM]>>> [E:7516r S:9102 M:112946107] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 19679 [FS]GeneralCommissioning: Received ArmFailSafe (60s) I: 19686 [EM]<<< [E:7516r S:9102 M:75546764] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 19697 [IN](S) Sending msg 75546764 on secure session with LSID: 9102 D: 19703 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 19787 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 19795 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 19803 [EM]>>> [E:7517r S:9102 M:112946108] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 19816 [EM]<<< [E:7517r S:9102 M:75546765] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 19828 [IN](S) Sending msg 75546765 on secure session with LSID: 9102 D: 19834 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 19967 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 20012 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 20020 [EM]>>> [E:7518r S:9102 M:112946109] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 20032 [ZCL]OpCreds: Certificate Chain request received for PAI I: 20041 [EM]<<< [E:7518r S:9102 M:75546766] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 20052 [IN](S) Sending msg 75546766 on secure session with LSID: 9102 D: 20058 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 20147 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 20154 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 20237 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 20244 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 48) D: 20327 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 20335 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 20343 [EM]>>> [E:7519r S:9102 M:112946110] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 20354 [ZCL]OpCreds: Certificate Chain request received for DAC I: 20364 [EM]<<< [E:7519r S:9102 M:75546767] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 20375 [IN](S) Sending msg 75546767 on secure session with LSID: 9102 D: 20381 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 20462 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 20469 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 20552 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 20559 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 77) D: 20642 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 20650 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 20658 [EM]>>> [E:7520r S:9102 M:112946111] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 20669 [ZCL]OpCreds: Received an AttestationRequest command I: 20704 [ZCL]OpCreds: AttestationRequest successful. I: 20713 [EM]<<< [E:7520r S:9102 M:75546768] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 20724 [IN](S) Sending msg 75546768 on secure session with LSID: 9102 D: 20731 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 20822 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 20829 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 20912 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 20919 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 237) D: 21002 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 21047 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 21055 [EM]>>> [E:7521r S:9102 M:112946112] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 21067 [ZCL]OpCreds: Received a CSRRequest command I: 21212 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded I: 21246 [ZCL]OpCreds: CSRRequest successful. I: 21253 [EM]<<< [E:7521r S:9102 M:75546769] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 21264 [IN](S) Sending msg 75546769 on secure session with LSID: 9102 D: 21270 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) E: 21278 [DL]Long dispatch time: 231 ms, for event type 16388 D: 21362 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 21369 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 138) D: 21452 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 21460 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 21542 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 21551 [EM]>>> [E:7522r S:9102 M:112946113] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 21563 [ZCL]OpCreds: Received an AddTrustedRootCertificate command I: 21622 [ZCL]OpCreds: AddTrustedRootCertificate successful. I: 21628 [EM]<<< [E:7522r S:9102 M:75546770] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 21640 [IN](S) Sending msg 75546770 on secure session with LSID: 9102 D: 21646 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68) E: 21654 [DL]Long dispatch time: 111 ms, for event type 16388 D: 21812 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 21820 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 21904 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 21993 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 22003 [EM]>>> [E:7523r S:9102 M:112946114] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 22015 [ZCL]OpCreds: Received an AddNOC command I: 22021 [FP]Validating NOC chain I: 22130 [FP]NOC chain validation successful I: 22134 [FP]Added new fabric at index: 0x1 I: 22138 [FP]Assigned compressed fabric ID: 0x33E88E3B87C86DF1, node ID: 0x0000000000000002 I: 22146 [TS]Last Known Good Time: 2024-10-25T11:19:57 I: 22151 [TS]New proposed Last Known Good Time: 2021-01-01T00:00:00 I: 22157 [TS]Retaining current Last Known Good Time I: 22170 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x000000000001B669 D: 22178 [DL]Using Thread extended MAC for hostname. I: 22183 [DIS]Advertise operational node 33E88E3B87C86DF1-0000000000000002 I: 22190 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC I: 22197 [EM]<<< [E:7523r S:9102 M:75546771] (S) Msg TX to 1:FFFFFFFB00000000 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse) I: 22208 [IN](S) Sending msg 75546771 on secure session with LSID: 9102 D: 22214 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) E: 22222 [DL]Long dispatch time: 230 ms, for event type 16388 D: 22307 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 22315 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 22323 [EM]>>> [E:7524r S:9102 M:112946115] (S) Msg RX from 1:FFFFFFFB00000000 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest) I: 22337 [EM]<<< [E:7524r S:9102 M:75546772] (S) Msg TX to 1:FFFFFFFB00000000 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse) I: 22348 [IN](S) Sending msg 75546772 on secure session with LSID: 9102 D: 22355 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 22442 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 22450 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 22458 [EM]>>> [E:7525r S:9102 M:112946116] (S) Msg RX from 1:FFFFFFFB00000000 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest) I: 22469 [FS]GeneralCommissioning: Received ArmFailSafe (65s) I: 22476 [EM]<<< [E:7525r S:9102 M:75546773] (S) Msg TX to 1:FFFFFFFB00000000 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse) I: 22487 [IN](S) Sending msg 75546773 on secure session with LSID: 9102 D: 22493 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 22622 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 22630 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 22638 [EM]>>> [E:7526r S:9102 M:112946117] (S) Msg RX from 1:FFFFFFFB00000000 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest) D: 22659 [DL]OpenThread State Changed (Flags: 0x101fc100) D: 22664 [DL] Network Name: TestNet D: 22668 [DL] PAN Id: 0x976E D: 22671 [DL] Extended PAN Id: 0xF581065E27EB4A59 D: 22675 [DL] Channel: 11 D: 22678 [DL] Mesh Prefix: fd00:c0ce:7ac8:4a81::/64 D: 22683 [DL]OpenThread State Changed (Flags: 0x1100101d) D: 22688 [DL] Device Role: DETACHED D: 22691 [DL] Thread Unicast Addresses: D: 22695 [DL] fd00:c0ce:7ac8:4a81:43e3:1ee4:7ab8:f51f/64 valid D: 22701 [DL] fe80::3856:f144:bcc3:6af7/64 valid preferred D: 23547 [DL]OpenThread State Changed (Flags: 0x200012a4) D: 23552 [DL] Device Role: CHILD D: 23555 [DL] Partition Id: 0xBD3375C D: 23559 [DL]OpenThread State Changed (Flags: 0x00000001) D: 23565 [DL] Thread Unicast Addresses: D: 23568 [DL] fd08:b89:78:f372:e6b7:a3aa:434e:8787/64 valid preferred D: 23575 [DL] fd00:c0ce:7ac8:4a81:0:ff:fe00:5001/64 valid rloc D: 23581 [DL] fd00:c0ce:7ac8:4a81:43e3:1ee4:7ab8:f51f/64 valid D: 23587 [DL] fe80::3856:f144:bcc3:6af7/64 valid preferred I: 23595 [EM]<<< [E:7526r S:9102 M:75546774] (S) Msg TX to 1:FFFFFFFB00000000 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse) I: 23606 [IN](S) Sending msg 75546774 on secure session with LSID: 9102 D: 23612 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70) D: 23620 [DL]Using Thread extended MAC for hostname. I: 23625 [DIS]Advertise operational node 33E88E3B87C86DF1-0000000000000002 I: 23631 [SVR]Operational advertising enabled D: 23747 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 26222 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 28729 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 28787 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 29653 [DL]OpenThread State Changed (Flags: 0x00000200) D: 31262 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 33769 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 33827 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) I: 35533 [DL]SRP Client was started, detected server: fd00:c0ce:7ac8:4a81:ca34:3c9c:4f64:2a2b D: 35541 [DL]OpenThread State Changed (Flags: 0x00000200) D: 36227 [DL]SRP update succeeded I: 36230 [DIS]Setting operational delegate post init I: 36238 [SWU]Stopping the watchdog timer I: 36241 [SWU]Starting the periodic query timer, timeout: 86400 seconds E: 36248 [SVR]Server initialization complete I: 36252 [DIS]Updating services using commissioning mode 0 D: 36257 [DL]Using Thread extended MAC for hostname. I: 36261 [DIS]Advertise operational node 33E88E3B87C86DF1-0000000000000002 I: 36268 [DL]advertising srp service: 33E88E3B87C86DF1-0000000000000002._matter._tcp D: 36302 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 37537 [DL]SRP update succeeded I: 37818 [EM]>>> [E:7527r S:0 M:186942531] (U) Msg RX from 0:91BDC9466F783843 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1) I: 37830 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0 I: 37837 [IN]CASE Server disabling CASE session setups I: 37842 [EM]<<< [E:7527r S:0 M:104315751 (Ack:186942531)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 37855 [IN](U) Sending msg 104315751 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:37745' I: 37865 [SC]Received Sigma1 msg I: 37871 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002 I: 38046 [EM]<<< [E:7527r S:0 M:104315752 (Ack:186942531)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2) I: 38059 [IN](U) Sending msg 104315752 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:37745' I: 38070 [SC]Sent Sigma2 msg I: 38266 [EM]>>> [E:7527r S:0 M:186942532 (Ack:104315752)] (U) Msg RX from 0:91BDC9466F783843 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3) I: 38279 [EM]<<< [E:7527r S:0 M:104315753 (Ack:186942532)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 38292 [IN](U) Sending msg 104315753 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:37745' I: 38302 [SC]Received Sigma3 msg E: 38310 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time E: 38480 [DL]Long dispatch time: 158 ms, for event type 2 I: 38490 [EM]<<< [E:7527r S:0 M:104315754 (Ack:186942532)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport) I: 38503 [IN](U) Sending msg 104315754 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:37745' I: 38514 [SC]SecureSession[0x200042a8]: Moving from state 'kEstablishing' --> 'kActive' D: 38522 [IN]SecureSession[0x200042a8]: Activated - Type:2 LSID:9103 D: 38529 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9103 PSID:53634! I: 38540 [IN]CASE Session established to peer: <000000000001B669, 1> I: 38549 [IN]CASE Server enabling CASE session setups D: 38554 [IN]SecureSession[0x20004360]: Allocated Type:2 LSID:9104 I: 38561 [EM]>>> [E:7528r S:9103 M:201472173] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest) I: 38573 [FS]GeneralCommissioning: Received CommissioningComplete I: 38581 [FP]Metadata for Fabric 0x1 persisted to storage. I: 38599 [TS]Committing Last Known Good Time to storage: 2024-10-25T11:19:57 I: 38607 [ZCL]OpCreds: Fabric index 0x1 was committed to storage. Compressed Fabric Id 0x33E88E3B87C86DF1, FabricId 0000000000000001, NodeId 0000000000000002, VendorId 0xFFF1 I: 38623 [FS]GeneralCommissioning: Successfully commited pending fabric data I: 38629 [FS]Fail-safe cleanly disarmed I: 38634 [EM]<<< [E:7528r S:9103 M:144370371 (Ack:201472173)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse) I: 38647 [IN](S) Sending msg 144370371 on secure session with LSID: 9103 I: 38655 [SWU]Device commissioned, schedule a default provider query I: 38661 [SVR]Commissioning completed successfully I: 38666 [DIS]Updating services using commissioning mode 0 D: 38672 [DL]Using Thread extended MAC for hostname. I: 38677 [DIS]Advertise operational node 33E88E3B87C86DF1-0000000000000002 D: 38685 [IN]Expiring all PASE sessions D: 38689 [IN]SecureSession[0x200041f0]: MarkForEviction Type:1 LSID:9102 I: 38696 [SC]SecureSession[0x200041f0]: Moving from state 'kActive' --> 'kPendingEviction' D: 38705 [IN]SecureSession[0x200041f0]: Released - Type:1 LSID:9102 D: 38711 [IN]Clearing BLE pending packets. I: 38714 [BLE]Releasing end point's BLE connection back to application. I: 38721 [DL]Closing BLE GATT connection (ConnId 00) I: 38727 [EM]>>> [E:7527r S:0 M:186942533 (Ack:104315754)] (U) Msg RX from 0:91BDC9466F783843 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) E: not connected! D: 38742 [DL]ConnId: 0x00, New CCCD value: 0x0000 E: 38746 [BLE]no endpoint for unsub recvd I: 38777 [DL]BLE GAP connection terminated (reason 0x16) I: 38782 [DL]Current number of connections: 0/1 I: 38969 [EM]>>> [E:7528r S:9103 M:201472174 (Ack:144370371)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 44744 [EM]>>> [E:24806r S:0 M:96832576] (U) Msg RX from 0:874CD040C22C4025 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1) I: 44756 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0 I: 44763 [IN]CASE Server disabling CASE session setups I: 44768 [EM]<<< [E:24806r S:0 M:104315755 (Ack:96832576)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 44781 [IN](U) Sending msg 104315755 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:45405' I: 44791 [SC]Received Sigma1 msg I: 44798 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002 I: 44977 [EM]<<< [E:24806r S:0 M:104315756 (Ack:96832576)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2) I: 44990 [IN](U) Sending msg 104315756 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:45405' I: 45001 [SC]Sent Sigma2 msg I: 45553 [EM]>>> [E:24806r S:0 M:96832577 (Ack:104315756)] (U) Msg RX from 0:874CD040C22C4025 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3) I: 45566 [EM]<<< [E:24806r S:0 M:104315757 (Ack:96832577)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 45579 [IN](U) Sending msg 104315757 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:45405' I: 45588 [SC]Received Sigma3 msg E: 45598 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time E: 45766 [DL]Long dispatch time: 158 ms, for event type 2 I: 45776 [EM]<<< [E:24806r S:0 M:104315758 (Ack:96832577)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport) I: 45788 [IN](U) Sending msg 104315758 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:45405' I: 45800 [SC]SecureSession[0x20004360]: Moving from state 'kEstablishing' --> 'kActive' D: 45808 [IN]SecureSession[0x20004360]: Activated - Type:2 LSID:9104 D: 45815 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9104 PSID:17040! I: 45823 [IN]CASE Session established to peer: <000000000001B669, 1> I: 45831 [IN]CASE Server enabling CASE session setups D: 45839 [IN]SecureSession[0x200041f0]: Allocated Type:2 LSID:9105 I: 45849 [EM]>>> [E:24807r S:9104 M:144708553] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest) I: 45874 [EM]<<< [E:24807r S:9104 M:22522419 (Ack:144708553)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse) I: 45887 [IN](S) Sending msg 22522419 on secure session with LSID: 9104 I: 45895 [EM]>>> [E:24806r S:0 M:96832578 (Ack:104315758)] (U) Msg RX from 0:874CD040C22C4025 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 45912 [EM]>>> [E:24807r S:9104 M:144708554 (Ack:22522419)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 47882 [EM]>>> [E:43737r S:0 M:131468757] (U) Msg RX from 0:D45EA1C0ED911ADA [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1) I: 47894 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0 I: 47901 [IN]CASE Server disabling CASE session setups I: 47906 [EM]<<< [E:43737r S:0 M:104315759 (Ack:131468757)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 47919 [IN](U) Sending msg 104315759 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:40931' I: 47929 [SC]Received Sigma1 msg I: 47939 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002 I: 48113 [EM]<<< [E:43737r S:0 M:104315760 (Ack:131468757)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2) I: 48126 [IN](U) Sending msg 104315760 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:40931' I: 48137 [SC]Sent Sigma2 msg I: 48320 [EM]>>> [E:43737r S:0 M:131468758 (Ack:104315760)] (U) Msg RX from 0:D45EA1C0ED911ADA [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3) I: 48333 [EM]<<< [E:43737r S:0 M:104315761 (Ack:131468758)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 48346 [IN](U) Sending msg 104315761 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:40931' I: 48356 [SC]Received Sigma3 msg E: 48365 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time E: 48534 [DL]Long dispatch time: 159 ms, for event type 2 I: 48543 [EM]<<< [E:43737r S:0 M:104315762 (Ack:131468758)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport) I: 48556 [IN](U) Sending msg 104315762 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:40931' I: 48568 [SC]SecureSession[0x200041f0]: Moving from state 'kEstablishing' --> 'kActive' D: 48576 [IN]SecureSession[0x200041f0]: Activated - Type:2 LSID:9105 D: 48583 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9105 PSID:21875! I: 48593 [IN]CASE Session established to peer: <000000000001B669, 1> I: 48600 [IN]CASE Server enabling CASE session setups D: 48609 [IN]SecureSession[0x20004418]: Allocated Type:2 LSID:9106 I: 48617 [EM]>>> [E:43738r S:9105 M:18085730] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:06 (IM:WriteRequest) D: 48628 [IM]Received Write request I: 48651 [EM]<<< [E:43738r S:9105 M:94780723 (Ack:18085730)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:07 (IM:WriteResponse) I: 48662 [IN](S) Sending msg 94780723 on secure session with LSID: 9105 I: 48671 [EM]>>> [E:43737r S:0 M:131468759 (Ack:104315762)] (U) Msg RX from 0:D45EA1C0ED911ADA [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 48717 [EM]>>> [E:43738r S:9105 M:18085731 (Ack:94780723)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 49183 [EM]>>> [E:13694r S:0 M:10934429] (U) Msg RX from 0:ADE94DC61A2855C1 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1) I: 49195 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0 I: 49202 [IN]CASE Server disabling CASE session setups I: 49207 [EM]<<< [E:13694r S:0 M:104315763 (Ack:10934429)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 49220 [IN](U) Sending msg 104315763 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:41559' I: 49230 [SC]Received Sigma1 msg I: 49241 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002 I: 49416 [EM]<<< [E:13694r S:0 M:104315764 (Ack:10934429)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2) I: 49428 [IN](U) Sending msg 104315764 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:41559' I: 49439 [SC]Sent Sigma2 msg I: 50348 [IN](U) Sending msg 104315764 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:41559' I: 50546 [EM]>>> [E:13694r S:0 M:10934430 (Ack:104315764)] (U) Msg RX from 0:ADE94DC61A2855C1 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3) I: 50559 [EM]<<< [E:13694r S:0 M:104315765 (Ack:10934430)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 50572 [IN](U) Sending msg 104315765 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:41559' I: 50581 [SC]Received Sigma3 msg E: 50590 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time E: 50759 [DL]Long dispatch time: 159 ms, for event type 2 I: 50769 [EM]<<< [E:13694r S:0 M:104315766 (Ack:10934430)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport) I: 50782 [IN](U) Sending msg 104315766 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:41559' I: 50793 [SC]SecureSession[0x20004418]: Moving from state 'kEstablishing' --> 'kActive' D: 50802 [IN]SecureSession[0x20004418]: Activated - Type:2 LSID:9106 D: 50808 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9106 PSID:43125! I: 50817 [IN]CASE Session established to peer: <000000000001B669, 1> I: 50825 [IN]CASE Server enabling CASE session setups D: 50833 [IN]SecureSession[0x200044d0]: Allocated Type:2 LSID:9107 I: 50843 [EM]>>> [E:13695r S:9106 M:144439525] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:06 (IM:WriteRequest) D: 50854 [IM]Received Write request I: 50866 [EM]<<< [E:13695r S:9106 M:168675876 (Ack:144439525)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:07 (IM:WriteResponse) I: 50878 [IN](S) Sending msg 168675876 on secure session with LSID: 9106 I: 50887 [EM]>>> [E:13694r S:0 M:10934431 (Ack:104315766)] (U) Msg RX from 0:ADE94DC61A2855C1 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 50920 [EM]>>> [E:13695r S:9106 M:144439526 (Ack:168675876)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 51457 [EM]>>> [E:35018r S:0 M:25195827] (U) Msg RX from 0:E94EDC7C067D0417 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1) I: 51468 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0 I: 51475 [IN]CASE Server disabling CASE session setups I: 51481 [EM]<<< [E:35018r S:0 M:104315767 (Ack:25195827)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 51493 [IN](U) Sending msg 104315767 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:50328' I: 51503 [SC]Received Sigma1 msg I: 51514 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002 I: 51689 [EM]<<< [E:35018r S:0 M:104315768 (Ack:25195827)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2) I: 51702 [IN](U) Sending msg 104315768 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:50328' I: 51713 [SC]Sent Sigma2 msg I: 51858 [EM]>>> [E:35018r S:0 M:25195828 (Ack:104315768)] (U) Msg RX from 0:E94EDC7C067D0417 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3) I: 51871 [EM]<<< [E:35018r S:0 M:104315769 (Ack:25195828)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 51884 [IN](U) Sending msg 104315769 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:50328' I: 51894 [SC]Received Sigma3 msg E: 51903 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time E: 52071 [DL]Long dispatch time: 158 ms, for event type 2 I: 52081 [EM]<<< [E:35018r S:0 M:104315770 (Ack:25195828)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport) I: 52094 [IN](U) Sending msg 104315770 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:50328' I: 52106 [SC]SecureSession[0x200044d0]: Moving from state 'kEstablishing' --> 'kActive' D: 52114 [IN]SecureSession[0x200044d0]: Activated - Type:2 LSID:9107 D: 52120 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9107 PSID:45636! I: 52129 [IN]CASE Session established to peer: <000000000001B669, 1> I: 52136 [IN]CASE Server enabling CASE session setups D: 52145 [IN]SecureSession[0x20004588]: Allocated Type:2 LSID:9108 I: 52152 [EM]>>> [E:35019r S:9107 M:131641130] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest) I: 52260 [IN]Joining Multicast Group with address UDP:[ff35:40:fd00::100:3]:5540 I: 52273 [EM]<<< [E:35019r S:9107 M:61795445 (Ack:131641130)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse) I: 52287 [IN](S) Sending msg 61795445 on secure session with LSID: 9107 D: 52296 [DL]OpenThread State Changed (Flags: 0x00001000) I: 52305 [EM]>>> [E:35018r S:0 M:25195829 (Ack:104315770)] (U) Msg RX from 0:E94EDC7C067D0417 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 52322 [EM]>>> [E:35019r S:9107 M:131641131 (Ack:61795445)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 52801 [EM]>>> [E:31924r S:0 M:90630522] (U) Msg RX from 0:B13ABCE9099778FA [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1) I: 52813 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0 I: 52820 [IN]CASE Server disabling CASE session setups I: 52825 [EM]<<< [E:31924r S:0 M:104315771 (Ack:90630522)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 52838 [IN](U) Sending msg 104315771 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:43307' I: 52848 [SC]Received Sigma1 msg I: 52859 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002 I: 53036 [EM]<<< [E:31924r S:0 M:104315772 (Ack:90630522)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2) I: 53048 [IN](U) Sending msg 104315772 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:43307' I: 53059 [SC]Sent Sigma2 msg I: 53198 [EM]>>> [E:31924r S:0 M:90630523 (Ack:104315772)] (U) Msg RX from 0:B13ABCE9099778FA [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3) I: 53212 [EM]<<< [E:31924r S:0 M:104315773 (Ack:90630523)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 53224 [IN](U) Sending msg 104315773 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:43307' I: 53234 [SC]Received Sigma3 msg E: 53242 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time E: 53412 [DL]Long dispatch time: 159 ms, for event type 2 I: 53422 [EM]<<< [E:31924r S:0 M:104315774 (Ack:90630523)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport) I: 53435 [IN](U) Sending msg 104315774 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:43307' I: 53447 [SC]SecureSession[0x20004588]: Moving from state 'kEstablishing' --> 'kActive' D: 53455 [IN]SecureSession[0x20004588]: Activated - Type:2 LSID:9108 D: 53461 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9108 PSID:42909! I: 53470 [IN]CASE Session established to peer: <000000000001B669, 1> I: 53479 [IN]CASE Server enabling CASE session setups D: 53487 [IN]SecureSession[0x20004640]: Allocated Type:2 LSID:9109 I: 53494 [EM]>>> [E:31925r S:9108 M:159503087] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest) I: 53516 [IN]Joining Multicast Group with address UDP:[ff35:40:fd00::100:4]:5540 I: 53530 [EM]<<< [E:31925r S:9108 M:251420196 (Ack:159503087)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse) I: 53545 [IN](S) Sending msg 251420196 on secure session with LSID: 9108 D: 53553 [DL]OpenThread State Changed (Flags: 0x00001000) I: 53562 [EM]>>> [E:31924r S:0 M:90630524 (Ack:104315774)] (U) Msg RX from 0:B13ABCE9099778FA [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 53579 [EM]>>> [E:31925r S:9108 M:159503088 (Ack:251420196)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 54055 [EM]>>> [E:292r S:0 M:197602012] (U) Msg RX from 0:6CB14E2CCDE22560 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1) I: 54066 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005bb0 I: 54074 [IN]CASE Server disabling CASE session setups I: 54079 [EM]<<< [E:292r S:0 M:104315775 (Ack:197602012)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 54091 [IN](U) Sending msg 104315775 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:55917' I: 54101 [SC]Received Sigma1 msg I: 54113 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002 I: 54301 [EM]<<< [E:292r S:0 M:104315776 (Ack:197602012)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2) I: 54313 [IN](U) Sending msg 104315776 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:55917' I: 54324 [SC]Sent Sigma2 msg D: 54327 [DL]OpenThread State Changed (Flags: 0x00000064) D: 54332 [DL] Device Role: ROUTER I: 54509 [EM]>>> [E:292r S:0 M:197602013 (Ack:104315776)] (U) Msg RX from 0:6CB14E2CCDE22560 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3) I: 54522 [EM]<<< [E:292r S:0 M:104315777 (Ack:197602013)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 54534 [IN](U) Sending msg 104315777 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:55917' I: 54544 [SC]Received Sigma3 msg E: 54553 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time E: 54722 [DL]Long dispatch time: 159 ms, for event type 2 I: 54733 [EM]<<< [E:292r S:0 M:104315778 (Ack:197602013)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport) I: 54745 [IN](U) Sending msg 104315778 to IP address 'UDP:[fd08:b89:78:f372:c9ac:a3c:a537:f497]:55917' I: 54757 [SC]SecureSession[0x20004640]: Moving from state 'kEstablishing' --> 'kActive' D: 54765 [IN]SecureSession[0x20004640]: Activated - Type:2 LSID:9109 D: 54772 [IN]New secure session activated for device <000000000001B669, 1>, LSID:9109 PSID:55899! I: 54781 [IN]CASE Session established to peer: <000000000001B669, 1> I: 54788 [IN]CASE Server enabling CASE session setups D: 54796 [IN]SecureSession[0x200046f8]: Allocated Type:2 LSID:9110 I: 54806 [EM]>>> [E:293r S:9109 M:13683323] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0001:08 (IM:InvokeCommandRequest) I: 54829 [IN]Joining Multicast Group with address UDP:[ff35:40:fd00::100:5]:5540 E: 54836 [SVR]Unable to listen to group I: 54844 [EM]<<< [E:293r S:9109 M:224548323 (Ack:13683323)] (S) Msg TX to 1:000000000001B669 [6DF1] --- Type 0001:09 (IM:InvokeCommandResponse) I: 54856 [IN](S) Sending msg 224548323 on secure session with LSID: 9109 I: 54865 [EM]>>> [E:292r S:0 M:197602014 (Ack:104315778)] (U) Msg RX from 0:6CB14E2CCDE22560 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 54902 [EM]>>> [E:293r S:9109 M:13683324 (Ack:224548323)] (S) Msg RX from 1:000000000001B669 [6DF1] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 55164 [EM]>>> [E:28831r S:3 M:220765547] (G) Msg RX from 1:000000000001B669 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 55179 [EM]Received Groupcast Message with GroupId 0x0003 (3) I: 55187 [ZCL]Toggle ep1 on/off from state 0 to 1 I: 55192 [ZCL]On Command - OffWaitTime : 0 I: 55196 [ZCL]On/Toggle Command - Stop Timer I: 55202 [ZCL]Cluster OnOff: attribute OnOff set to 1 I: Turn On Action has been initiated I: Turn On Action has been completed I: 55214 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1 I: Level Action has been initiated I: Setting brightness level to 1 I: Level Action has been completed I: 55231 [ZCL]Event: move from 1 I: 55234 [ZCL] to 254 I: 55236 [ZCL](diff +1) I: 55238 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254 I: Level Action has been initiated I: Setting brightness level to 254 I: Level Action has been completed I: 57480 [EM]>>> [E:25461r S:3 M:220766547] (G) Msg RX from 1:000000000001B669 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 57491 [EM]Received Groupcast Message with GroupId 0x0003 (3) I: 57500 [ZCL]Toggle ep1 on/off from state 1 to 0 I: 57508 [ZCL]Event: move from 254 I: 57511 [ZCL] to 1 I: 57514 [ZCL](diff -1) I: 57516 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1 I: Level Action has been initiated I: Setting brightness level to 1 I: Level Action has been completed I: 57531 [ZCL]Setting on/off to OFF due to level change I: 57536 [ZCL]Toggle ep1 on/off from state 1 to 0 I: 57541 [ZCL]Cluster OnOff: attribute OnOff set to 0 I: Turn Off Action has been initiated I: Turn Off Action has been completed I: 57553 [ZCL]Off completed. reset OnTime to 0 I: 57557 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254 I: 59780 [EM]>>> [E:9389r S:4 M:220767547] (G) Msg RX from 1:000000000001B669 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 59792 [EM]Received Groupcast Message with GroupId 0x0004 (4) I: 59801 [ZCL]Toggle ep1 on/off from state 0 to 1 I: 59806 [ZCL]On Command - OffWaitTime : 0 I: 59810 [ZCL]On/Toggle Command - Stop Timer I: 59816 [ZCL]Cluster OnOff: attribute OnOff set to 1 I: Turn On Action has been initiated I: Turn On Action has been completed I: 59828 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1 I: 59835 [ZCL]Event: move from 1 I: 59838 [ZCL] to 254 I: 59840 [ZCL](diff +1) I: 59842 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254 I: Level Action has been initiated I: Setting brightness level to 254 I: Level Action has been completed I: 61988 [EM]>>> [E:18369r S:4 M:220768547] (G) Msg RX from 1:000000000001B669 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 62001 [EM]Received Groupcast Message with GroupId 0x0004 (4) I: 62011 [ZCL]Toggle ep1 on/off from state 1 to 0 I: 62017 [ZCL]Event: move from 254 I: 62020 [ZCL] to 1 I: 62022 [ZCL](diff -1) I: 62025 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1 I: Level Action has been initiated I: Setting brightness level to 1 I: Level Action has been completed I: 62040 [ZCL]Setting on/off to OFF due to level change I: 62045 [ZCL]Toggle ep1 on/off from state 1 to 0 I: 62050 [ZCL]Cluster OnOff: attribute OnOff set to 0 I: Turn Off Action has been initiated I: Turn Off Action has been completed I: 62061 [ZCL]Off completed. reset OnTime to 0 I: 62065 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254 E: 68661 [SWU]No suitable OTA Provider candidate found I: 68666 [SWU]No provider available
Bash script for testing
The following script:
- Wipes any existing fabric info and sets up a new fabric
- Commissions the
light_bulb
- Creates three groups and adds the
light_bulb
to each one. - Toggles the LED using each of the three created groups.
The output of me running this script is found in the attached pi.log
for the Pi's perspective, and light_bulb.log
for the nRF5340's perspective.
#!/bin/bash -x
# Thread network setup
## Create a clean slate
ot-ctl thread stop
ot-ctl ifconfig down
ot-ctl factoryreset
rm /var/lib/thread/*
rm /var/chip-tool/*
sleep 5
## Setup a new thread network
ot-ctl dataset init new
ot-ctl dataset channel 11
ot-ctl dataset panid 0x976e
ot-ctl dataset extpanid f581065e27eb4a59
ot-ctl dataset networkname TestNet
ot-ctl dataset networkkey d645efebea99fd80fc10addc20bcdd93
ot-ctl dataset pskc f254a33b452bf277b1329750f2922e3a
ot-ctl dataset commit active
ot-ctl prefix add fd08:b89:78:f372::/64 paos med
ot-ctl ifconfig up
ot-ctl thread start
ot-ctl dataset active -x
# Commissioning
## Save the active datset to be used in commissioning
DATASET=$(ot-ctl dataset active -x | head -n1 | tr -d '\r')
## Commission the light bulb
chip-tool pairing code-thread 2 hex:$DATASET MT:6FCJ142C00KA0648G00 --bypass-attestation-verifier true
sleep 5
# Configure 3 groups
chip-tool groupsettings add-keysets 0xaaaa 0 0x21dfe0 hex:281b29592d521ea8a8d57a4a7639511b
chip-tool groupkeymanagement key-set-write '{"groupKeySetID":42,"groupKeySecurityPolicy":0,"epochKey0":"281b29592d521ea8a8d57a4a7639511b","epochStartTime0":2220000,"epochKey1":"c7cb12d00355e03c942a0b7447d05c1b","epochStartTime1":2220001,"epochKey2":"ba5aaef06db2a60920fd54166e734018","epochStartTime2":2220002}' 2 0
chip-tool groupsettings add-group grp3 3
chip-tool groupsettings bind-keyset 3 43690
chip-tool groupsettings add-group grp4 4
chip-tool groupsettings bind-keyset 4 43690
chip-tool groupsettings add-group grp5 5
chip-tool groupsettings bind-keyset 5 43690
chip-tool groupkeymanagement write group-key-map '[{"groupId":3,"groupKeySetID":42},{"groupId":4,"groupKeySetID":42},{"groupId":5,"groupKeySetID":42}]' 2 0
chip-tool accesscontrol write acl '[{"fabricIndex":1,"privilege":5,"authMode":2,"subjects":[112233],"targets":null},{"fabricIndex":1,"privilege":3,"authMode":3,"subjects":[3,4,5],"targets":[{"cluster":null,"endpoint":1,"deviceType":null},{"cluster":null,"endpoint":1,"deviceType":null},{"cluster":null,"endpoint":1,"deviceType":null}]}]' 2 0
chip-tool groups add-group 3 grp3 2 1 # Success
chip-tool groups add-group 4 grp4 2 1 # Success
chip-tool groups add-group 5 grp5 2 1 # Fail: "Unable to listen to group" on edge device, even though it appears successful from chip-tool's perspective
# Control the light bulb using each group
## First group works
chip-tool onoff on 0xFFFFFFFFFFFF0003 0
sleep 2
chip-tool onoff off 0xFFFFFFFFFFFF0003 0
sleep 2
## Second group works
chip-tool onoff on 0xFFFFFFFFFFFF0004 0
sleep 2
chip-tool onoff off 0xFFFFFFFFFFFF0004 0
sleep 2
## Third group fails, no traffic comes through on the light bulb
chip-tool onoff on 0xFFFFFFFFFFFF0005 0
sleep 2
chip-tool onoff off 0xFFFFFFFFFFFF0005 0
Attempts to fix the issue
I made the following changes to the light_bulb
, which seems to have no affect. Just for kicks I tried setting CONFIG_OPENTHREAD_IP6_MAX_EXT_MCAST_ADDRS
to 1, but I was still able to add 2 groups. I do a pristine build between attempts.
# prj.conf
CONFIG_OPENTHREAD_IP6_MAX_EXT_MCAST_ADDRS=10
CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=10
// src/chip_project_config.h
#define CHIP_CONFIG_MAX_GROUP_CONCURRENT_ITERATORS 10
Note that there is also a MaxGroupsPerFabric
field in src/light_bulb.zap
that may be relevant, but I was unable to make it have any affect. Maybe I need some guidance here.
Efforts to isolate the issue
I tried commissioning a second light_bulb
running on another nRF5340-dk and was able to add it to two groups, but the third gives Unable to listen to group
just like the before.
I tried running connectedhomeip/examples/lighting-app
for Linux on the Pi to test a non-Nordic device and interestingly I was able to add three groups, and receive the group cast messages for those three groups (one more than the light_bulb
), but then adding a fourth group gave a new failure: CHIP:EVL: Dropped 1 event from buffer with priority 1 and event number 0x0000000000000002 due to overflow: event priority_level: 1
. So this leads me to believe the group limit of 2 is not an issue with the Pi’s setup, but rather the light_bulb
I made a small patch to the SDK to print the error resulting in Unable to listen to group
and it was 4000003
which I can’t seem to find where this is defined.
diff --git a/src/app/server/Server.h b/src/app/server/Server.h index eee11b0bc6..82731cc2e4 100644 --- a/src/app/server/Server.h +++ b/src/app/server/Server.h @@ -385,10 +385,11 @@ private: return; } - if (mServer->GetTransportManager().MulticastGroupJoinLeave( - Transport::PeerAddress::Multicast(fabric->GetFabricId(), new_group.group_id), true) != CHIP_NO_ERROR) + CHIP_ERROR ret = mServer->GetTransportManager().MulticastGroupJoinLeave( + Transport::PeerAddress::Multicast(fabric->GetFabricId(), new_group.group_id), true); + if (ret != CHIP_NO_ERROR) { - ChipLogError(AppServer, "Unable to listen to group"); + ChipLogError(AppServer, "Unable to listen to group. Err = %" CHIP_ERROR_FORMAT, ret.Format()); } };
I found this potentially related issue in the connectedhomeip GitHub.
