How to debug a stack overflow error in a nRF5340
I am getting this error on the 7th time I perform an action:
[00:02:31.772,277] <err> lvgl: (151.772, +67506)         lv_mem_realloc: couldn't allocate memory       (in lv_mem.c line #211)
[00:02:31.772,521] <err> lvgl: (151.772, +0)     lv_mem_buf_get: Asserted at expression: buf != NULL (Out of memory, can't allocate a new buffer (increase your LV_MEM_SIZE/heap size))   (in lv_mem.c line #312)
I understand it's an lvgl error and could be specific to lvgl but I think, considering it's only happening on the 7th time I perform an action, that it's a memory problem someplace else. I was thinking being able to print the available RAM would help. Is there a way to do that? Is there a way to see what variables are in RAM?
I'm using Zephyr with the VSC connect add-in.
  • Yes, the sample applications typically serve only as a starting point. I just wanted to confirm that you did not experience this issue with the provided sample. I'm not very familiar with the LVGL API myself, but based on what you've described, it seems that the problem is likely due to new LVGL objects being created continuously in your application without deleting old objects that are no longer needed. Similar to the issue described in the linked github issue.
    You can find more LVGL examples in /modules/lib/gui/lvgl/examples and /modules/lib/gui/lvgl/demos. While these won’t build out of the box with Zephyr, they do demonstrate how the API is meant to be used.
    lcj said:
    I could use Nordic debugging tools but don't have the RAM tab for some reason.
    From the screenshot you posted in the other thread, it seems you were able to view it after pausing the debugger? That said, I don’t think inspecting the RAM content will help you troubleshoot this particular issue. I recommend focusing on reviewing the API usage in your application and ensuring that objects are freed (deleted) after use.
    EDIT: I see what you mean now. The Memory Explorer view is not showing the RAM tab as shown in the picture from the devacademy course. Instead, it displays the program sections: .text, .rodata, and .data where .data is equivalent to the previous RAM tab.
  • I've created all the lvgl samples. I tried to make this request discreet to the Nordic/Zephyr to see how I could diagnose issues regardless of the API, but I understand people need to know the context of the problem. I was looking for some roadmap for diagnosing memory allocation/stack overflow problems.
    The function I call is:
    lv_scr_load_anim(screen1, LV_SCR_LOAD_ANIM_NONE, 0, 0, true);
    The last is auto_del and should delete the previous screen. I will check to see if it's called. I'm not calling lv_style_init() as the post referenced, but maybe I can see if the same thing is happening with the screen.
    To be honest, even if the RAM tab was there, I would not know how to use it to diagnose this, but I thought it would be a good start. It would be great to see a video on specifically how to use it with some manufactured problem as a demonstration.
  • I believe we have already determined that this is a memory leak in LVGL. The question is whether it is caused by improper API usage or if there is a bug in the Zephyr integration or the library itself. I don't think there is a generic debugging method for this. We need to determine why the library is not freeing the objects after use.
