Advertising doesn't change name after code update
Greetings,
I've been developing a DFU firmware that should update the device through Android. The thing is, the device works, but I changed the advertising name, and it still shows the old name when I try to update the device. I use the following function to update the name:
static void make_dev_name(void)
    ble_gap_addr_t device_address;
    uint8_t companyName[] = {"M"};
    uint8_t modelName[] = {"1"};
    uint8_t *macAddressName;
    uint8_t macTmp[12];
    sd_ble_gap_addr_get(&device_address);
    macAddressName = Convert_Hex_To_Ascii(&device_address.addr[0], 4);
    memcpy(&DEVICE_NAME[0], companyName, 1);
    memcpy(&DEVICE_NAME[1], modelName, 1);
    memcpy(&DEVICE_NAME[2], macAddressName, 12);
Any idea why this issue occurs?
I used reference from here;
https://novelbits.io/ota-device-firmware-update-part-3/
  • Ok, update on the project. I had some issues with the OS, now I am able to debug the DFU part of the project in Segger. So I get NRF_BREAKPOINT_COND whenever a APP_ERROR_CHECK(err_code); is called in the code. This happens during debugging. I also put comments on err_code = ble_dfu_buttonless_async_svci_init();, so it doesn't initialize a bootloader check (seems that was the issue that didn't let me debug.)
    Update: When I comment error check function in the timers_init() function, I get the following:
  • I have not seen your code, so I can't tell why it is failing. Please check what the error code was. You can check this by enabling debug logs and build with the DEBUG flag set, or by inspecting the variables passed to the erorr handler after NRF_BREAKPOINT_COND is reached.
  • This is the error I get in the debug output.
    <error> app: ERROR 12 [NRF_ERROR_DATA_SIZE] at C:\Proj\nRF5_SDK_17.1.0_ddde560\PROJECT\MyProj\003p\main.c:832
    PC at: 0x000272D5
    <error> app: End of error report
    So there are 2 outcomes:
    1. When I go with step during debugging, the program goes into infinite loop (HardFault_Handler()) on the log_init() part.
    2. When I go with Continue execution, the error above appears when the debugger continues to execute from line 1045 (timers_init()).
  • This error is raised by the UARTE peripheral if it received invalid data. This can happen if the UART RX input is left floating or if you have an external device sending invalid data packets. You can comment the APP_ERROR_HANDLER line if you want to ignore com. errors.
  • Ok, I did this and now I get the same error but with different address: 0x0002726D. I also tried with commented timers_init(), but now it does the same with the next line (buttons_leds_init) and debugging stops at NRF_BREAKPOINT_COND.
    I tried to build the project in the Nordic examples (the uart specifically), the advertising worked as it should.
    I assume the possible issue is with the bootloader, because in the Nordic example I only used the App and the Softdevice. There was no Bootloader there.
    It leaves me confused to see the same code in both projects at the main part, but in this one, it throws errors during the initialization parts.
