Advertising doesn't change name after code update
Greetings,
I've been developing a DFU firmware that should update the device through Android. The thing is, the device works, but I changed the advertising name, and it still shows the old name when I try to update the device. I use the following function to update the name:
static void make_dev_name(void)
    ble_gap_addr_t device_address;
    uint8_t companyName[] = {"M"};
    uint8_t modelName[] = {"1"};
    uint8_t *macAddressName;
    uint8_t macTmp[12];
    sd_ble_gap_addr_get(&device_address);
    macAddressName = Convert_Hex_To_Ascii(&device_address.addr[0], 4);
    memcpy(&DEVICE_NAME[0], companyName, 1);
    memcpy(&DEVICE_NAME[1], modelName, 1);
    memcpy(&DEVICE_NAME[2], macAddressName, 12);
Any idea why this issue occurs?
I used reference from here;
https://novelbits.io/ota-device-firmware-update-part-3/
    When is make_dev_name() called, is it only on startup, or are you sending a command over BLE to update the name?
    Vidar
  • Only on start-up.
        bool erase_bonds;
        ret_code_t err_code;
        // Comment this for new modules
        sd_power_dcdc_mode_set(1);
        // Initialize.
        uart_init();
        log_init();
        // Initialize the async SVCI interface to bootloader before any interrupts are enabled.
        err_code = ble_dfu_buttonless_async_svci_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        make_dev_name();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        //if(nrf_gpio_pin_read(WAKEUP_IN_PIN))
        //    while(1);   // wait here
        nrf_delay_ms(5);
        while(!nrf_gpio_pin_read(WAKEUP_IN_PIN))
            //nrf_gpio_pin_clear(UART_TX_NOTIFY);
            //nrf_delay_ms(250);
            //nrf_gpio_pin_set(UART_TX_NOTIFY);
            for(int i=0; i<6; i++)
                do
                    err_code = app_uart_put(device_address.addr[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            //nrf_delay_ms(500);
            nrf_delay_ms(50);
        // Start execution.
        //printf("\r\nApplication started.\r\n");
        while(app_uart_tx_done());
        app_uart_close();
        advertising_start();
        wdt_init();
        // Enter main loop.
        for (;;)
            // Feed the watchdog
            feed_dog();
            // Power management
            idle_state_handle();
  • Thanks for confirming. But I can't tell from the snippet you posted where DEVICE_NAME is referenced. Could you post your main.c file here?
  • Device name is referenced as uint8_t array
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "main.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "nrf_drv_wdt.h"
    #include "nrf_drv_clock.h"
    // BEGIN Block Added for DFU
    #include "nrf_power.h"
    #include "nrf_dfu_ble_svci_bond_sharing.h"
    #include "nrf_svci_async_function.h"
    #include "nrf_svci_async_handler.h"
    #include "ble_dfu.h"
    #include "nrf_bootloader_info.h"
    // END Block Added for DFU
    #define WAKEUP_IN_PIN   NRF_GPIO_PIN_MAP(0,4)               // Check this pin if need to send MAC
    static void uart_init(void);
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    uint8_t DEVICE_NAME[29];
    //#define DEVICE_NAME                     "M1"                                   /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                MSEC_TO_UNITS(500, UNIT_0_625_MS)            /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    APP_TIMER_DEF(m_inactivity_timer_id);                                               // Define the timer instance
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    //*************** DFU START     *********************************************
    /**@brief Handler for shutdown preparation.
     * @details During shutdown procedures, this function will be called at a 1 second interval
     *          untill the function returns true. When the function returns true, it means that the
     *          app is ready to reset to DFU mode.
     * @param[in]   event   Power manager event.
     * @retval  True if shutdown is allowed by this power manager handler, otherwise false.
    static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_DFU:
                NRF_LOG_INFO("Power management wants to reset to DFU mode.");
                // YOUR_JOB: Get ready to reset into DFU mode
                // If you aren't finished with any ongoing tasks, return "false" to
                // signal to the system that reset is impossible at this stage.
                // Here is an example using a variable to delay resetting the device.
                // if (!m_ready_for_reset)
                //      return false;
                // else
                //    // Device ready to enter
                //    uint32_t err_code;
                //    err_code = sd_softdevice_disable();
                //    APP_ERROR_CHECK(err_code);
                //    err_code = app_timer_stop_all();
                // YOUR_JOB: Implement any of the other events available from the power management module:
                //      -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
                //      -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
                //      -NRF_PWR_MGMT_EVT_PREPARE_RESET
                return true;
        NRF_LOG_INFO("Power management allowed to reset to DFU mode.");
        return true;
    //lint -esym(528, m_app_shutdown_handler)
    /**@brief Register application shutdown handler with priority 0.
    NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
    static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
        if (state == NRF_SDH_EVT_STATE_DISABLED)
            // Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
            nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
            //Go to system off.
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
    /* nrf_sdh state observer. */
    NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) =
        .handler = buttonless_dfu_sdh_state_observer,
    static void advertising_config_get(ble_adv_modes_config_t * p_config)
        memset(p_config, 0, sizeof(ble_adv_modes_config_t));
        p_config->ble_adv_fast_enabled  = true;
        p_config->ble_adv_fast_interval = APP_ADV_INTERVAL;
        p_config->ble_adv_fast_timeout  = APP_ADV_DURATION;
    static void disconnect(uint16_t conn_handle, void * p_context)
        UNUSED_PARAMETER(p_context);
        ret_code_t err_code = sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_WARNING("Failed to disconnect connection. Connection handle: %d Error: %d", conn_handle, err_code);
            NRF_LOG_DEBUG("Disconnected connection handle %d", conn_handle);
    // YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
    /**@brief Function for handling dfu events from the Buttonless Secure DFU service
     * @param[in]   event   Event from the Buttonless Secure DFU service.
    static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
        switch (event)
            case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
                NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
                // Prevent device from advertising on disconnect.
                ble_adv_modes_config_t config;
                advertising_config_get(&config);
                config.ble_adv_on_disconnect_disabled = true;
                ble_advertising_modes_config_set(&m_advertising, &config);
                // Disconnect all other bonded devices that currently are connected.
                // This is required to receive a service changed indication
                // on bootup after a successful (or aborted) Device Firmware Update.
                uint32_t conn_count = ble_conn_state_for_each_connected(disconnect, NULL);
                NRF_LOG_INFO("Disconnected %d links.", conn_count);
            case BLE_DFU_EVT_BOOTLOADER_ENTER:
                // YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
                //           by delaying reset by reporting false in app_shutdown_handler
                NRF_LOG_INFO("Device will enter bootloader mode.");
            case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
                NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
                // YOUR_JOB: Take corrective measures to resolve the issue
                //           like calling APP_ERROR_CHECK to reset the device.
            case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
                NRF_LOG_ERROR("Request to send a response to client failed.");
                APP_ERROR_CHECK(false);
                NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
    //*************** DFU END       **********************************************
    // Watch Dog enable
    nrfx_wdt_channel_id m_channel_id;
    void wdt_event_handler(void)
        NRF_LOG_INFO("%s", __func__);
        while (NRF_LOG_PROCESS());
        NRF_LOG_FINAL_FLUSH();
    void feed_dog(void)
         nrf_drv_wdt_channel_feed(m_channel_id);
    void wdt_init(void)
        //2 sec timeout
        uint32_t err_code = NRF_SUCCESS;
        nrfx_wdt_config_t wdt_config = NRFX_WDT_DEAFULT_CONFIG;
        err_code = nrfx_wdt_init(&wdt_config, wdt_event_handler);
        err_code = nrfx_wdt_channel_alloc(&m_channel_id);
        nrfx_wdt_enable();
    // Inactivity timeout handler
    static void inactivity_timeout_handler(void * p_context)
        if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
            // Disconnect from the peer.
            ret_code_t err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
        // Create timer
        err_code = app_timer_create(&m_inactivity_timer_id,
                                    APP_TIMER_MODE_SINGLE_SHOT,
                                    inactivity_timeout_handler);
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_UNKNOWN);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            // Notify the MCU that you will send data on UART
            nrf_delay_ms(5);
            nrf_delay_ms(10);
            // Restart the inactivity timer
            err_code = app_timer_start(m_inactivity_timer_id, APP_TIMER_TICKS(13000), NULL);    // 13 sec timeout
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        ble_dfu_buttonless_init_t dfus_init = {0};
        // Initialize NUS.
        // Initialize DFU buttonless.
        dfus_init.evt_handler = ble_dfu_evt_handler;
        err_code = ble_dfu_buttonless_init(&dfus_init);
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        //err_code = bsp_btn_ble_sleep_mode_prepare();
        //APP_ERROR_CHECK(err_code);
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                uart_init();
                NRF_LOG_INFO("Connected");
                //err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
                // Start the inactivity timer
                // Stop the inactivity timer
                err_code = app_timer_stop(m_inactivity_timer_id);
                // Wait for UART to finish
                app_uart_close();
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        static uint8_t bytesToSend = 0;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                if(index == 1)
                    bytesToSend = (char)data_array[index];
                    bytesToSend+=2;
                    //printf("%c", bytesToSend);
                index++;
                if ((index >= bytesToSend)&&(index > 1))
                    //NRF_LOG_DEBUG("Ready to send data over BLE NUS");
                    //NRF_LOG_HEXDUMP_DEBUG(data_array, index);
                    do
                        uint16_t length = (uint16_t)bytesToSend;
                    } while (err_code == NRF_ERROR_RESOURCES);
                    // Disconnect from phone
                    if(data_array[2] != 0x01)
                        ret_code_t err_code = app_timer_stop(m_inactivity_timer_id);
                    index = 0;
                    bytesToSend = 0;
            //**************    ORG      ********************************************
                //UNUSED_VARIABLE(app_uart_get(&data_array[index]));
                //index++;
                //if (((data_array[index - 2] == '\n') &&
                //    (data_array[index - 1] == '\r')) ||
                //    (index >= m_ble_nus_max_data_len))
                //    if (index > 1)
                //        NRF_LOG_DEBUG("Ready to send data over BLE NUS");
                //        NRF_LOG_HEXDUMP_DEBUG(data_array, index);
                //        do
                //            uint16_t length = (uint16_t)index;
                //            err_code = ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle);
                //            if ((err_code != NRF_ERROR_INVALID_STATE) &&
                //                (err_code != NRF_ERROR_RESOURCES) &&
                //                (err_code != NRF_ERROR_NOT_FOUND))
                //        } while (err_code == NRF_ERROR_RESOURCES);
                //    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOW,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        //uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
        //uint32_t err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
        //err_code = bsp_btn_ble_init(NULL, &startup_event);
        //*p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);
        // Initialize output pin to notify the MCU
        nrf_gpio_cfg_output(UART_TX_NOTIFY);
        // Initialize pin to send MAC address
        nrf_gpio_cfg_input(WAKEUP_IN_PIN, NRF_GPIO_PIN_PULLUP);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    static uint8_t *Convert_Hex_To_Ascii(uint8_t *hex_data, uint16_t data_len)
        int i = 0;
        uint16_t j = 0;
        static uint8_t ascii_data[8];
        uint8_t pom_low, pom_high;
        for (i=0; i<data_len; i++)
            pom_low = (hex_data[i] & 0x0F);
            pom_high = ((hex_data[i]>>4) & 0x0F);
            if((pom_low >= 0) && (pom_low <= 9))
                pom_low += 0x30;
                pom_low += 0x37;
            if((pom_high >= 0) && (pom_high <= 9))
                pom_high += 0x30;
                pom_high += 0x37;
            ascii_data[j++] = pom_high;
            ascii_data[j++] = pom_low;
        return ascii_data; // return the address of the first element
        uint8_t macTmp[12];
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        ble_stack_init();
        make_dev_name();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        nrf_delay_ms(5);
                do
            nrf_delay_ms(50);
        // Start execution.
        app_uart_close();
        wdt_init();
        // Enter main loop.
        for (;;)
            feed_dog();
            // Power management
  • Thanks for sharing the code. But I'm not seeing any obvious errors in this implementation. Does the device advertise with the expected name if you load the application FW with your debugger? Also, are you sure the previous device name has not been cached by your phone?
