How to Configure TX power and read BT address for nRF54L15 ?
I want to know how to Configure TX power and read the BT address for nRF54L15.
PG
    You can configure the CONFIG_BT_CTLR_TX_PWR_ANTENNA in your project configuration file (prj.conf). For example, if you want +8dBm (is 0 dBm by default), you can add CONFIG_BT_CTLR_TX_PWR_ANTENNA=8.
    To read the local identity address, you can call bt_id_get() after settings_load() (or bt_enable(NULL) if BT_SETTINGS==n).
    E.g.,
    	bt_addr_le_t bt_addr[CONFIG_BT_ID_MAX];
    	size_t count = CONFIG_BT_ID_MAX;
    	char addr_str[BT_ADDR_LE_STR_LEN];
    	bt_id_get(bt_addr, &count);
    	for (int i=0; i < count; i++) {
    		bt_addr_le_to_str(&bt_addr[i], addr_str, sizeof(addr_str));
    		printk("BT address %d: %s\n", i, addr_str);
    Vidar
  • Hi Vidar,
    Thanks.
    1. Could you please let me know in which file, you have the functions "settings_load()" or the line (bt_enable(NULL) if BT_SETTINGS==n) ?
    2. Also, could you let me know how to set the DTM example to set it to DCDC mode OR to LDO mode ?
    Jameel Basha
     I am using the sample appln "direct_test_mode".
    With Regards,
    Jameel Basha
  • Hi Jameel,
    I assumed you were using a Bluetooth application. Instructions for changing the TX power in DTM are provided here: https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/samples/bluetooth/direct_test_mode/README.html#tx_output_power. DTM is for testing of the physical layer, and as far as I know, does not use a BT address. Can you provide a bit more info about what you are going to use the address for? DTM does not specify a command for reading address info from the chip as far as I can tell.
    The DCDC regulator is enabled by default if you build for the nRF54L PDK or DK. You can disable it by adding CONFIG_BOARD_ENABLE_DCDC=n to your project configuration (prj.conf).
    Vidar
  • Hi Vidar,
    1. Please point to us exactly where to modify the TX Power for the sample (direct_test_mode) using nRF54L15-PDK. I could not find a valid place to set various Tx Power.
    2. I added,
    CONFIG_DTM_POWER_CONTROL_AUTOMATIC=y, in prj.conf, but it depends on "FEM"
    in direct_test_mode@nRF54L15?
    config DTM_POWER_CONTROL_AUTOMATIC
        bool "Automatic power control"
        depends on FEM
        default y
        help
          Set the SoC output power and the front-end module gain to achieve the TX output power
          requested by user. If the exact value cannot be achieved, power is set to the closest
          possible value. If this option is disabled, user can set the SoC output power and the
          front-end module gain with the separate vendor specific commands.
    May I know, where is FEM, defined ? is it even a Macro. Please provide detailed steps, as this is new for us.
    Jameel Basha
