Hi there:
I want to do BLE FOTA on nRF5340 Audio DK board. I have sdk v2.6.2. I'm trying to make the existing audio application work by taking the source code as it is from "~/ncs/v2.6.2/nrf/applications/nrf5340_audio". I added only one line in prj.conf, which is
CONFIG_AUDIO_DFU=2
The build command is as follows.
west build --build-dir ~/ncs/v2.6.2/nrf/applications/nrf5340_audio/build ~/ncs/v2.6.2/nrf/applications/nrf5340_audio --pristine --board nrf5340_audio_dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONFIG_SIZE_OPTIMIZATIONS=y
I get errors like below.
In file included from /home/someusr/ncs/v2.6.2/bootloader/mcuboot/boot/zephyr/include/sysflash/sysflash.h:10,from /home/someusr/ncs/v2.6.2/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c:32:/home/someusr/ncs/v2.6.2/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h: In function '__flash_area_ids_for_slot':/home/someusr/ncs/v2.6.2/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:47:60: error: 'PM_MCUBOOT_SECONDARY_ID' undeclared (first use in this function); did you mean 'PM_MCUBOOT_PRIMARY_ID'?47 | #define FLASH_AREA_IMAGE_0_SLOTS PM_MCUBOOT_PRIMARY_ID, PM_MCUBOOT_SECONDARY_ID| ^~~~~~~~~~~~~~~~~~~~~~~/home/someusr/ncs/v2.6.2/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:52:29: note: in expansion of macro 'FLASH_AREA_IMAGE_0_SLOTS'52 | #define ALL_AVAILABLE_SLOTS FLASH_AREA_IMAGE_0_SLOTS| ^~~~~~~~~~~~~~~~~~~~~~~~/home/someusr/ncs/v2.6.2/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:67:9: note: in expansion of macro 'ALL_AVAILABLE_SLOTS'67 | ALL_AVAILABLE_SLOTS
I tried with different CONFIG_AUDIO_DFU=1, that gives flash size error.
I have below questions:
1. How to make this application work for BLE FOTA DFU?
2. I have my own application that can run BLE FOTA DFU successfully on nrf5340dk board. I used the following in mcuboot.overlay file and in prj.conf of the app and mcuboot.conf. If I need to make this app run on nrf5340 audio board with BLE FOTA DFU, what do I need to modify in the following?
mcuboot.overlay/ {
chosen {
nordic,pm-ext-flash = &mx25r64;
};app prj.confCONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
CONFIG_UPDATEABLE_IMAGE_NUMBER=2mcuboot.confCONFIG_NORDIC_QSPI_NOR=y
CONFIG_BOOT_MAX_IMG_SECTORS=256
CONFIG_LOG=y
CONFIG_MCUBOOT_LOG_LEVEL_WRN=y
CONFIG_NRF53_MULTI_IMAGE_UPDATE=y
CONFIG_BOOT_UPGRADE_ONLY=y
CONFIG_PCD_APP=y
CONFIG_FLASH=y
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
CONFIG_FLASH_SIMULATOR_STATS=n
CONFIG_BOOT_SIGNATURE_KEY_FILE="/path/somekey.pem"
ncs/v2.6.2/nrf/applications/nrf5340_audio/dfu/conf/overlay-dfu_external_flash.overlay. I think the solution for my requirement (BLE FOTA DFU on nRF5340 Audio board for my app) is to understand this better. Please throw some light on this. Refer me to a place where I can go through resources around this to understand this better. mx25r64: mx25r6435f@2 {
compatible = "jedec,spi-nor";
reg = <2>;
spi-max-frequency = <8000000>;
jedec-id = [c2 28 17];
sfdp-bfp = [
e5 20 f1 ff ff ff ff 03 44 eb 08 6b 08 3b 04 bb
ee ff ff ff ff ff 00 ff ff ff 00 ff 0c 20 0f 52
10 d8 00 ff 23 72 f5 00 82 ed 04 cc 44 83 68 44
30 b0 30 b0 f7 c4 d5 5c 00 be 29 ff f0 d0 ff ff
size = <67108864>;
has-dpd;
t-enter-dpd = <10000>;
t-exit-dpd = <5000>;
dpd-wakeup-sequence = <30000 20 45000>;
