I have an application called `main_repo` built using v2.1.1 (the SDK version doesn't really matter). This contains all source code, dts files, Kconfig files, etc. to building a specific product with an nRF5340 chip.
I have a second repo, called `research_repo`, which I would like to inherit everything from `main_repo`, with a few exceptions. Particularly, `main_repo/app` and `research_repo/app` are different, but the boards, drivers, and source code should be able to be referenced from `research_repo`. Essentially, `main_repo` is upstream of `research_repo`.
If I'm using pure Zephyr, then I would just add the following to `west.yml` (see code snippet). After `west update` in `my-workspace` (which contains `research_repo`), this loads `my-workspace/modules/main_repo`, and I can refer to all of the boards, dts, Kconfig, etc. inside `research_repo`.
But under `C:\ncs\v2.1.1`, I need to modify `nrf\west.yml` by hand. This isn't ideal.
Is there a recommended way of doing it?
I can't make changes to `main_repo`, but I can make all sorts of `west.yml`, or custom scripts, under `research_repo` to make this happen.
# Copyright (c) 2021 Nordic Semiconductor ASA
manifest:
self:
west-commands: scripts/west-commands.yml
remotes:
- name: zephyrproject-rtos
url-base: https://github.com/zephyrproject-rtos
- name: main_repo
url-base: https://github.com/mycompany
projects:
- name: zephyr
remote: zephyrproject-rtos
revision: main
import:
# By using name-allowlist we can clone only the modules that are
# strictly needed by the application.
name-allowlist:
- cmsis # required by the ARM port
- hal_nordic # required by the custom_plank board (Nordic based)
- hal_stm32 # required by the nucleo_f302r8 board (STM32 based)
- name: main_repo
remote: main_repo
revision: v1.0.0
