I'm reading temperature and humidity from 2 sensors in my system
At some point in time during a quick and dirt check the system has been proven working fine and I could read temp and humidity values (so no error in hw)
Then I cleanup the code and nothing works anymore
Reading first sensor (temperature) is fine but 2nd read from humidity sensor return ERR 17 (should be NRF_ERROR_BUSY = driver not ready for new transfer)
In my main code I have TWI TX calls to start transmission and then I'm waiting for TWI HANDLER to complete transfer
// Enter main loop.
for (;;)
switch (twi_case_main) {
case TWI_WAIT_MCP9808:
if (m_xfer_done == true) {
twi_case_main = TWI_MCP9808;
case TWI_MCP9808:
twi_case_var = TWI_MCP9808; // set case for twi_handler
reg[0] = MCP9808_RA_TEMP;
twi_err_code = nrf_drv_twi_tx(&m_twi_sensors, MCP9808_ADDR, reg, sizeof(reg), false);
APP_ERROR_CHECK(twi_err_code);
twi_case_main = TWI_WAIT_HTDU21D_RH;
case TWI_WAIT_HTDU21D_RH:
twi_case_main = TWI_HTDU21D_RH;
case TWI_HTDU21D_RH:
twi_case_var = TWI_HTDU21D_RH; // set case for twi_handler
reg[0] = TRIGGER_HUMD_MEASURE_NOHOLD;
twi_err_code = nrf_drv_twi_tx(&m_twi_sensors, HTDU21D_ADDRESS, reg, sizeof(reg), false);
twi_case_main = TWI_IDLE;
case TWI_IDLE:
twi_case_var = TWI_WAIT_MCP9808;
In my twi handler
@brief TWI events handler. */ void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context) {
// some variables hereswitch (twi_case_var) { // TWI events sequence is initiated by main task with a nrf_drv_twi_tx() call and complete with the following sequence case TWI_MCP9808: switch(p_event->type) { case NRF_DRV_TWI_TX_DONE: /* Read 2 bytes from the specified address. */ err_code = nrf_drv_twi_rx(&m_twi_sensors, MCP9808_ADDR, data, sizeof(uint8_t) * 2, false); APP_ERROR_CHECK(err_code); break;
case NRF_DRV_TWI_RX_DONE: // Mask out flags and clean up sign bit temp = data[0] << 8 | data[1]; temperature = temp * some_k; // temperature m_xfer_done = true; // tell main app sensor read has been complete break; default: break; }break;
case TWI_HTDU21D_RH: switch(p_event->type) { case NRF_DRV_TWI_TX_DONE: /* Read 3 bytes from the specified address. */ err_code = nrf_drv_twi_rx(&m_twi_sensors, HTDU21D_ADDRESS, data, sizeof(uint8_t) * 3, false); APP_ERROR_CHECK(err_code); break;
case NRF_DRV_TWI_RX_DONE: // Mask out flags and clean up sign bit temp = data[0] << 8 | data[1]; humidity1 = temp * some_k; // humidity m_xfer_done = true; // tell main app sensor read has been complete break; default: break; }break; } }
I'm getting err 17 when I try to read from humidity sensor What am I doing wrong?
Thanks
