I'm attempting to get our wearable remote to interact with a GoPro using their API and am getting the error in the subject line when attempting to start scanning. I've checked out a couple of resolutions of this error (wrong parameters, increase the size of the scan buffer, etc) but still getting the error. Does anybody have an example for this? Code attached...
/**@brief GoPro service Handler.
static void gopro_svc_evt_handler(ble_gopro_t * p_gopro, ble_gopro_evt_t * p_gopro_evt)
ret_code_t err_code;
switch (p_gopro_evt->evt_type)
case BLE_GOPRO_EVT_DISCOVERY_COMPLETE:
NRF_LOG_DEBUG("Heart rate service discovered.");
err_code = ble_gopro_handles_assign(p_gopro,
p_gopro_evt->conn_handle,
&p_gopro_evt->params.peer_db);
// Heart rate service discovered. Enable notification of Heart Rate Measurement.
err_code = ble_gopro_hrm_notif_enable(p_gopro);
} break;
case BLE_GOPRO_EVT_HRM_NOTIFICATION:
NRF_LOG_INFO("Heart Rate = %d.", p_gopro_evt->params.hrm.hr_value);
if (p_gopro_evt->params.hrm.rr_intervals_cnt != 0)
uint32_t rr_avg = 0;
for (uint32_t i = 0; i < p_gopro_evt->params.hrm.rr_intervals_cnt; i++)
rr_avg += p_gopro_evt->params.hrm.rr_intervals[i];
rr_avg = rr_avg / p_gopro_evt->params.hrm.rr_intervals_cnt;
NRF_LOG_DEBUG("rr_interval (avg) = %d.", rr_avg);
} break;
* @brief gopro service initialization.
static void gopro_svc_init(void)
ble_gopro_init_t gopro_init_obj;
gopro_init_obj.evt_handler = gopro_svc_evt_handler;
gopro_init_obj.error_handler = service_error_handler;
gopro_init_obj.p_gatt_queue = &m_ble_gatt_queue;
ret_code_t err_code = ble_gopro_init(&m_gopro, &gopro_init_obj);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
// Discover peer's services.
err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
if (ble_conn_state_central_conn_count() < NRF_SDH_BLE_CENTRAL_LINK_COUNT)
scan_start();
} break;
NRF_LOG_INFO("Disconnected, reason 0x%x.",
p_gap_evt->params.disconnected.reason);
scan_start();
} break;
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
} break;
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
case BLE_GAP_EVT_AUTH_KEY_REQUEST:
NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
case BLE_GAP_EVT_AUTH_STATUS:
NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
p_ble_evt->evt.gap_evt.params.auth_status.bonded,
p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
*((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
*((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
switch (p_evt->evt_id)
case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED:
NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
p_evt->conn_handle,
p_evt->params.att_mtu_effective);
} break;
case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED:
NRF_LOG_INFO("Data length for connection 0x%x updated to %d.",
p_evt->conn_handle,
p_evt->params.data_length);
} break;
/**@brief Function for handling Scaning events.
* @param[in] p_scan_evt Scanning event.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
switch(p_scan_evt->scan_evt_id)
//case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST:
// on_whitelist_req();
// m_whitelist_disabled = false;
//} break;
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
} break;
case NRF_BLE_SCAN_EVT_CONNECTED:
ble_gap_evt_connected_t const * p_connected =
p_scan_evt->params.connected.p_connected;
// Scan is automatically stopped by the connection.
NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
p_connected->peer_addr.addr[0],
p_connected->peer_addr.addr[1],
p_connected->peer_addr.addr[2],
p_connected->peer_addr.addr[3],
p_connected->peer_addr.addr[4],
p_connected->peer_addr.addr[5]
} break;
case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
NRF_LOG_INFO("Scan timed out.");
scan_start();
} break;
case NRF_BLE_SCAN_EVT_FILTER_MATCH:
case NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT:
/**@brief Function for handling database discovery events.
* @details This function is callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function should forward the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_gopro_on_db_disc_evt(&m_gopro, p_evt);
/**@brief Database discovery initialization.
static void db_discovery_init(void)
ble_db_discovery_init_t db_init;
memset(&db_init, 0, sizeof(db_init));
db_init.p_gatt_queue = &m_ble_gatt_queue;
//apdobaj
db_init.evt_handler = db_disc_handler;
ret_code_t err_code = ble_db_discovery_init(&db_init);
#define SCAN_ACTIVE 0
#define SCAN_INTERVAL 0x0040
#define SCAN_WINDOW 0x0020
#define SCAN_TIMEOUT 0
#define SCAN_FP 0
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning module instance.
void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
//change.scan_interval_multiple_double is global variable and can changed by user action
uint16_t scan_interval = SCAN_INTERVAL*(change.scan_interval_multiple_double);
ble_gap_scan_params_t nrf_ble_scan_params_1M_test =
.active = SCAN_ACTIVE,
.interval = scan_interval,
.window = SCAN_WINDOW,
.timeout = SCAN_TIMEOUT,
.filter_policy = SCAN_FP,
.scan_phys = BLE_GAP_PHY_1MBPS,
init_scan.connect_if_match = false;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
MAIN_DEBUG(("scan_init - SCAN_PHY Normal\r"));
init_scan.p_scan_param = &nrf_ble_scan_params_1M_test;
init_scan.p_conn_param = &nrf_ble_conn_params;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
//init result always return 0x00(NRF_SUCCESS)
MAIN_DEBUG(("scan init result[0x%02X]", err_code));
/**@brief Function for initialization scanning and setting filters.
static void scan_init(void)
init_scan.p_scan_param = &m_scan_param;
init_scan.connect_if_match = true;
ble_uuid128_t uuid =
.uuid128 = TARGET_UUID
//128-bit uuid doesn't have a type
//.type = BLE_UUID_TYPE_BLE,
#if NRF_BLE_SCAN_FILTER_ENABLE
err_code = nrf_ble_scan_filter_set(&m_scan,
SCAN_UUID_FILTER,
&uuid);
if (strlen(m_target_periph_name) != 0)
SCAN_NAME_FILTER,
m_target_periph_name);
if (is_connect_per_addr)
SCAN_ADDR_FILTER,
m_target_periph_addr.addr);
err_code = nrf_ble_scan_filters_enable(&m_scan,
NRF_BLE_SCAN_ALL_FILTER,
false);
* Copyright (c) 2012 - 2021, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/**@cond To Make Doxygen skip documentation generation for this file.
#include "sdk_common.h"
#if NRF_MODULE_ENABLED(BLE_GOPRO_SVC)
#include "ble_gopro.h"
#include "ble_db_discovery.h"
#include "ble_types.h"
#include "ble_gattc.h"
#define NRF_LOG_MODULE_NAME ble_gopro_svc
#include "nrf_log.h"
NRF_LOG_MODULE_REGISTER();
#define HRM_FLAG_MASK_HR_16BIT (0x01 << 0) /**< Bit mask used to extract the type of heart rate value. This is used to find if the received heart rate is a 16 bit value or an 8 bit value. */
#define HRM_FLAG_MASK_HR_RR_INT (0x01 << 4) /**< Bit mask used to extract the presence of RR_INTERVALS. This is used to find if the received measurement includes RR_INTERVALS. */
/**@brief Function for interception of the errors of GATTC and the BLE GATT Queue.
* @param[in] nrf_error Error code.
* @param[in] p_ctx Parameter from the event handler.
* @param[in] conn_handle Connection handle.
static void gatt_error_handler(uint32_t nrf_error,
void * p_ctx,
uint16_t conn_handle)
ble_gopro_t * p_ble_gopro = (ble_gopro_t *)p_ctx;
NRF_LOG_DEBUG("A GATT Client error has occurred on conn_handle: 0X%X", conn_handle);
if (p_ble_gopro->error_handler != NULL)
p_ble_gopro->error_handler(nrf_error);
/**@brief Function for handling Handle Value Notification received from the SoftDevice.
* @details This function uses the Handle Value Notification received from the SoftDevice
* and checks whether it is a notification of the heart rate measurement from the peer. If
* it is, this function decodes the heart rate measurement and sends it to the
* application.
* @param[in] p_ble_gopro Pointer to the Heart Rate Client structure.
* @param[in] p_ble_evt Pointer to the BLE event received.
static void on_hvx(ble_gopro_t * p_ble_gopro, const ble_evt_t * p_ble_evt)
// Check if the event is on the link for this instance.
if (p_ble_gopro->conn_handle != p_ble_evt->evt.gattc_evt.conn_handle)
NRF_LOG_DEBUG("Received HVX on link 0x%x, not associated to this instance. Ignore.",
p_ble_evt->evt.gattc_evt.conn_handle);
return;
NRF_LOG_DEBUG("Received HVX on link 0x%x, hrm_handle 0x%x",
p_ble_evt->evt.gattc_evt.params.hvx.handle,
p_ble_gopro->peer_hrs_db.hrm_handle);
// Check if this is a heart rate notification.
if (p_ble_evt->evt.gattc_evt.params.hvx.handle == p_ble_gopro->peer_hrs_db.hrm_handle)
ble_gopro_evt_t ble_gopro_evt;
uint32_t index = 0;
ble_gopro_evt.evt_type = BLE_GOPRO_EVT_HRM_NOTIFICATION;
ble_gopro_evt.conn_handle = p_ble_gopro->conn_handle;
ble_gopro_evt.params.hrm.rr_intervals_cnt = 0;
if (!(p_ble_evt->evt.gattc_evt.params.hvx.data[index++] & HRM_FLAG_MASK_HR_16BIT))
// 8-bit heart rate value received.
ble_gopro_evt.params.hrm.hr_value = p_ble_evt->evt.gattc_evt.params.hvx.data[index++]; //lint !e415 suppress Lint Warning 415: Likely access out of bond
// 16-bit heart rate value received.
uint16_decode(&(p_ble_evt->evt.gattc_evt.params.hvx.data[index]));
index += sizeof(uint16_t);
if ((p_ble_evt->evt.gattc_evt.params.hvx.data[0] & HRM_FLAG_MASK_HR_RR_INT))
uint32_t i;
/*lint --e{415} --e{416} --e{662} --e{661} -save suppress Warning 415: possible access out of bond */
for (i = 0; i < BLE_GOPRO_RR_INTERVALS_MAX_CNT; i ++)
if (index >= p_ble_evt->evt.gattc_evt.params.hvx.len)
ble_gopro_evt.params.hrm.rr_intervals[i] =
/*lint -restore*/
ble_gopro_evt.params.hrm.rr_intervals_cnt = (uint8_t)i;
p_ble_gopro->evt_handler(p_ble_gopro, &ble_gopro_evt);
/**@brief Function for handling Disconnected event received from the SoftDevice.
* @details This function checks whether the disconnect event is happening on the link
* associated with the current instance of the module. If the event is happening, the function sets the instance's
* conn_handle to invalid.
static void on_disconnected(ble_gopro_t * p_ble_gopro, const ble_evt_t * p_ble_evt)
if (p_ble_gopro->conn_handle == p_ble_evt->evt.gap_evt.conn_handle)
p_ble_gopro->conn_handle = BLE_CONN_HANDLE_INVALID;
p_ble_gopro->peer_hrs_db.hrm_cccd_handle = BLE_GATT_HANDLE_INVALID;
p_ble_gopro->peer_hrs_db.hrm_handle = BLE_GATT_HANDLE_INVALID;
void ble_gopro_on_db_disc_evt(ble_gopro_t * p_ble_gopro, const ble_db_discovery_evt_t * p_evt)
// Check if the Heart Rate Service was discovered.
if (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE &&
p_evt->params.discovered_db.srv_uuid.uuid == BLE_UUID_GOPRO_SERVICE &&
p_evt->params.discovered_db.srv_uuid.type == BLE_UUID_TYPE_BLE)
// Find the CCCD Handle of the Heart Rate Measurement characteristic.
uint32_t i;
ble_gopro_evt_t evt;
evt.evt_type = BLE_GOPRO_EVT_DISCOVERY_COMPLETE;
evt.conn_handle = p_evt->conn_handle;
for (i = 0; i < p_evt->params.discovered_db.char_count; i++)
if (p_evt->params.discovered_db.charateristics[i].characteristic.uuid.uuid ==
BLE_UUID_HEART_RATE_MEASUREMENT_CHAR)
// Found Heart Rate characteristic. Store CCCD handle and break.
evt.params.peer_db.hrm_cccd_handle =
p_evt->params.discovered_db.charateristics[i].cccd_handle;
evt.params.peer_db.hrm_handle =
p_evt->params.discovered_db.charateristics[i].characteristic.handle_value;
NRF_LOG_DEBUG("Heart Rate Service discovered at peer.");
//If the instance has been assigned prior to db_discovery, assign the db_handles.
if (p_ble_gopro->conn_handle != BLE_CONN_HANDLE_INVALID)
if ((p_ble_gopro->peer_hrs_db.hrm_cccd_handle == BLE_GATT_HANDLE_INVALID)&&
(p_ble_gopro->peer_hrs_db.hrm_handle == BLE_GATT_HANDLE_INVALID))
p_ble_gopro->peer_hrs_db = evt.params.peer_db;
p_ble_gopro->evt_handler(p_ble_gopro, &evt);
uint32_t ble_gopro_init(ble_gopro_t * p_ble_gopro, ble_gopro_init_t * p_ble_gopro_init)
VERIFY_PARAM_NOT_NULL(p_ble_gopro);
VERIFY_PARAM_NOT_NULL(p_ble_gopro_init);
ble_uuid128_t gopro_uuid = GOPRO_SERVICE_UUID_128;
// Add GoPro Service UUID
//ble_uuid128_t base_uuid = {GOPRO_SERVICE_UUID_BASE};
//err_code = sd_ble_uuid_vs_add(&base_uuid, gopro_uuid.type);
//VERIFY_SUCCESS(err_code);
p_ble_gopro->evt_handler = p_ble_gopro_init->evt_handler;
p_ble_gopro->error_handler = p_ble_gopro_init->error_handler;
p_ble_gopro->p_gatt_queue = p_ble_gopro_init->p_gatt_queue;
return ble_db_discovery_evt_register(&gopro_uuid);
void ble_gopro_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
ble_gopro_t * p_ble_gopro = (ble_gopro_t *)p_context;
if ((p_ble_gopro == NULL) || (p_ble_evt == NULL))
return;
case BLE_GATTC_EVT_HVX:
on_hvx(p_ble_gopro, p_ble_evt);
on_disconnected(p_ble_gopro, p_ble_evt);
/**@brief Function for creating a message for writing to the CCCD.
static uint32_t cccd_configure(ble_gopro_t * p_ble_gopro, bool enable)
NRF_LOG_DEBUG("Configuring CCCD. CCCD Handle = %d, Connection Handle = %d",
p_ble_gopro->peer_hrs_db.hrm_cccd_handle,
p_ble_gopro->conn_handle);
nrf_ble_gq_req_t gopro_req;
uint8_t cccd[BLE_CCCD_VALUE_LEN];
uint16_t cccd_val = enable ? BLE_GATT_HVX_NOTIFICATION : 0;
cccd[0] = LSB_16(cccd_val);
cccd[1] = MSB_16(cccd_val);
memset(&gopro_req, 0, sizeof(gopro_req));
gopro_req.type = NRF_BLE_GQ_REQ_GATTC_WRITE;
gopro_req.error_handler.cb = gatt_error_handler;
gopro_req.error_handler.p_ctx = p_ble_gopro;
gopro_req.params.gattc_write.handle = p_ble_gopro->peer_hrs_db.hrm_cccd_handle;
gopro_req.params.gattc_write.len = BLE_CCCD_VALUE_LEN;
gopro_req.params.gattc_write.p_value = cccd;
gopro_req.params.gattc_write.write_op = BLE_GATT_OP_WRITE_REQ;
return nrf_ble_gq_item_add(p_ble_gopro->p_gatt_queue, &gopro_req, p_ble_gopro->conn_handle);
uint32_t ble_gopro_hrm_notif_enable(ble_gopro_t * p_ble_gopro)
return cccd_configure(p_ble_gopro, true);
uint32_t ble_gopro_handles_assign(ble_gopro_t * p_ble_gopro,
uint16_t conn_handle,
const hrs_db_t * p_peer_hrs_handles)
p_ble_gopro->conn_handle = conn_handle;
if (p_peer_hrs_handles != NULL)
p_ble_gopro->peer_hrs_db = *p_peer_hrs_handles;
return nrf_ble_gq_conn_handle_register(p_ble_gopro->p_gatt_queue, conn_handle);
* @endcond
#endif // NRF_MODULE_ENABLED(BLE_gopro)
/**@brief Function for application main entry.
bool erase_bonds;
//the following line for monitor mode debugging (doesn't work with the mini)
//NVIC_SetPriority(DebugMonitor_IRQn, _PRIO_SD_LOW)
// Initialize.
//bsp_board_init(BSP_INIT_LEDS & BSP_INIT_BUTTONS);
lfclk_config();
gpio_init();
batt_charger_init();
nrf_gpio_pin_write(LED_RED_PIN, 0); //LED on
SEGGER_RTT_Init();
//apdobaj 11Mar2024 try using SystemView
#if defined(USE_SYSVIEW)
SEGGER_SYSVIEW_Conf();
SEGGER_SYSVIEW_Start();
//regout0 set in boards.c
//set_regout0_3v();
log_init();
timers_init();
nrf_mem_init();
//buttons_leds_init(&erase_bonds);
//nrf_gpio_pin_write(LED2_B, 0);
power_management_init();
ble_stack_init();
scheduler_init();
gap_params_init();
gatt_init();
//apdobaj changed order of next two statements per custom service tutorial
services_init();
// initialize services separately so they can both be connected
advertising_init_hid();
//sensor_simulator_init();
//haptic_init();
conn_params_init();
buffer_init();
peer_manager_init();
//clear the bootloader start bit after reset
sd_power_gpregret_clr(0, BOOTLOADER_DFU_GPREGRET_MASK);
//apdobaj add i2c and sensor init routines
twi_init_i2c();
da7280_init();
gesture_sensor_init();
gestureCaptureSequence = linkedListCreate();
gestureSequenceCountList = linkedListCreate();
#if defined(USE_TWR)
//link to qorvo forum from previous design: https://forum.qorvo.com/t/ds-two-way-ranging-example-code-not-communicating/12178/13?page=2
init_spim();
twr_init();
// implement a watchdog timer
//wdt_start();
// Start execution.
NRF_LOG_INFO("HID Keyboard example started.");
timers_start();
erase_bonds = false;
#if defined(OPERATE_AS_CENTRAL)
scan_init();
db_discovery_init();
gopro_svc_init();
scan_start();
#else
advertising_start();
nrf_gpio_pin_write(LED_RED_PIN, 1); //LED off
//SEGGER_SYSVIEW_Stop();
// Enter main loop.
for (;;)
idle_state_handle();
