How can ESL establish periodic sync with the special AP?
Hi,my board is nRF52840,and the demo is periodic_sync_conn within ncs2.7.0,
I want to establish periodic sync with the  AP whose rssi is better,but i am failed。The ESL will sync with another AP automatically Disappointed
Thanks.
struct _AP_info
    int8_t sid;
    int8_t rssi;
    bt_addr_le_t addr;
} __packed;
static struct _AP_info AP_info={.rssi=-80};
static void scan_AP(const struct bt_le_scan_recv_info *info)
    if (info->rssi > AP_info.rssi)
        AP_info.sid = info->sid;
        AP_info.rssi = info->rssi;
        bt_addr_le_copy(&(AP_info.addr), info->addr);
        printk("Get better rssi AP:sid=%d,rssi=%i,addr=0x%X\n", AP_info.sid, AP_info.rssi, AP_info.addr.a.val[0]);
static void scan_recv(const struct bt_le_scan_recv_info *info, struct net_buf_simple *buf)
    char name[NAME_LEN] = {0};
    char le_addr[BT_ADDR_LE_STR_LEN];
    struct _AP_info *p_AP_info = NULL;
    (void)memset(name, 0, sizeof(name));
    bt_data_parse(buf, data_cb, name);
    bt_addr_le_to_str(info->addr, le_addr, sizeof(le_addr));
    if (0 == strstr(name, "PAwR conn sample") || 0 == info->interval){
        return;
    printk("scan_recv:%s,sid:%d,rssi:%i,type:%d,addr:%s\n", name, info->sid, info->rssi, info->addr->type, le_addr);
    scan_AP(info);
    if (!per_adv_found){
        // per_sid = info->sid;
        // bt_addr_le_copy(&per_addr, info->addr);
        per_sid = AP_info.sid;
        bt_addr_le_copy(&per_addr, &(AP_info.addr));
        per_adv_found = true;
        k_sem_give(&sem_per_adv);
static struct bt_le_scan_cb scan_callbacks = {
    .recv = scan_recv,
  • PAwR test code.zip
    Hi,would you please build the code on your board?
    thanks
  • Hi Tan,
    Did you make any modification ?
    Do you have any question regarding my explanation ?
    I don't see the point of trying your code on my board. It will show the same thing what you observed, it will connect to the first AP it scans.
  • Hi Hung,
    I add a timeout,but it don`t work like we want to.
  • Please show the code where you edited it. How you expect it to work ? And what doesn't work ?
  • ok,
    I add a timer like this:
    k_timer_start(&my_timer, K_SECONDS(1), K_SECONDS(1));
    void timer_func(struct k_timer *timer_id)
        secondTick++;
    Init startScan  when scan starts:  startScan = secondTick;
        if (info->rssi > AP_info.rssi){
            printk("Get better rssi ap:sid=%d,rssi=%i,addr=0x%X\n", AP_info.sid, AP_info.rssi, AP_info.addr.a.val[0]);
            return;
        scan_AP(info);
    if ( !per_adv_found && (secondTick-startScan>5) ){
    Next is the log:
    scan_recv:sid=1_PAwR conn sample,sid:1,rssi:-49,type:1,addr:71:8E:E0:39:A6:F6 (random)
    Get better rssi ap:sid=1,rssi=-49,addr=0xF6
    Creating Periodic Advertising Sync
    Waiting for periodic sync
    scan_recv:sid=1_PAwR conn sample,sid:1,rssi:-48,type:1,addr:71:8E:E0:39:A6:F6 (random)
    Get better rssi ap:sid=1,rssi=-48,addr=0xF6
    scan_recv:sid=3_PAwR conn sample,sid:3,rssi:-53,type:1,addr:60:A5:88:64:00:6F (random)
    scan_recv:sid=3_PAwR conn sample,sid:3,rssi:-52,type:1,addr:60:A5:88:64:00:6F (random)
    scan_recv:sid=2_PAwR conn sample,sid:2,rssi:-43,type:1,addr:79:D7:19:CA:C1:9D (random)
    Get better rssi ap:sid=2,rssi=-43,addr=0x9D
    scan_recv:sid=3_PAwR conn sample,sid:3,rssi:-54,type:1,addr:60:A5:88:64:00:6F (random)
    scan_recv:sid=3_PAwR conn sample,sid:3,rssi:-51,type:1,addr:60:A5:88:64:00:6F (random)
    scan_recv:sid=2_PAwR conn sample,sid:2,rssi:-50,type:1,addr:79:D7:19:CA:C1:9D (random)
    scan_recv:sid=2_PAwR conn sample,sid:2,rssi:-45,type:1,addr:79:D7:19:CA:C1:9D (random)
    scan_recv:sid=2_PAwR conn sample,sid:2,rssi:-44,type:1,addr:79:D7:19:CA:C1:9D (random)
    scan_recv:sid=2_PAwR conn sample,sid:2,rssi:-47,type:1,addr:79:D7:19:CA:C1:9D (random)
    scan_recv:sid=1_PAwR conn sample,sid:1,rssi:-52,type:1,addr:71:8E:E0:39:A6:F6 (random)
    scan_recv:sid=2_PAwR conn sample,sid:2,rssi:-48,type:1,addr:79:D7:19:CA:C1:9D (random)
    scan_recv:sid=1_PAwR conn sample,sid:1,rssi:-47,type:1,addr:71:8E:E0:39:A6:F6 (random)
    scan_recv:sid=2_PAwR conn sample,sid:2,rssi:-49,type:1,addr:79:D7:19:CA:C1:9D (random)
    scan_recv:sid=1_PAwR conn sample,sid:1,rssi:-58,type:1,addr:71:8E:E0:39:A6:F6 (random)
    scan_recv:sid=2_PAwR conn sample,sid:2,rssi:-46,type:1,addr:79:D7:19:CA:C1:9D (random)
    Synced to sid=1,addr_info_71:8E:E0:39:A6:F6 (random),service_data_0 has 128 subevents,phy=2,reassembly.len=0:0 0 0.
    Rx_2, sub_0, RSSI=-47, len=0, data: 0xde_92_35
    Periodic sync established.
    Stopped scanning
    Rx_2, sub_1, RSSI=-48, len=0, data: 0xde_92_35
