twt setup: wrong parameter count
I want to use the example of "Wi Fi: Shell" to set TWT parameters by referring to the official documentation:
https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/protocols/wifi/station_mode/powersave.html
and blogs:
 https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/target-wake-time-on-the-nrf7002-dk
i set the command such as :
wifi twt setup 0 0 1 1 0 1 1 1 65000 524000
OR
wifi twt setup 0 0 2 2 0 1 1 1 20 60000
but  it is print "setup: wrong parameter count", as shown in log :
uart:~$ > wifi status
wifi status
Status: successful
State: COMPLETED
Interface Mode: STATION
Link Mode: WIFI 6 (802.11ax/HE)
SSID: OpenWrt_1F05DA_5G
BSSID: 94:83:C4:1F:05:DA
Band: 5GHz
Channel: 36
Security: WPA2-PSK
MFP: Optional
RSSI: -38
Beacon Interval: 100
DTIM: 1
TWT: Supported
uart:~$ > wifi twt setup 0 0 1 1 0 1 1 1 65000 524000
setup - Start a TWT flow:
<negotiation_type, 0: Individual, 1: Broadcast, 2: Wake TBTT>
<setup_cmd: 0: Request, 1: Suggest, 2: Demand>
<dialog_token: 1-255> <flow_id: 0-7> <responder: 0/1> <trigger: 0/1>
<implicit:0/1> <announce: 0/1> <twt_wake_interval: 1-262144us>
<twt_interval: 1us-2^31us>.
<twt_wake_ahead_duration>: 0us-2^31us>
uart:~$ > wifi twt setup 0 0 2 2 0 1 1 1 20 600000
uart:~$ > wifi twt setup 0 0 2 2 0 1 1 1 20 300000
[01:11:20.519,226] <inf> wpa_supp: nordic_wlan0: WPA: Group rekeying completed with 94:83:c4:1f:05:da [GTK=TKIP]
uart:~$
so, can you give me some help, thank you very much!
    I tried both your configurations successfully against a ASUS RT-AX1800U running OpenWrt v23.05:
    *** Using nRF Connect SDK v2.8.0-a2386bfc8401 ***
    *** Using Zephyr OS v3.7.99-0bc3393fb112 ***
    Starting nrf7002dk with CPU frequency: 128 MHz
    [00:00:00.699,462] <inf> wifi_supplicant: wpa_supplicant initialized
    uart:~$
    uart:~$ wifi connect -s OpenWrt -k 1 -p mypassword
    Connection requested
    Connected
    [00:01:49.010,589] <inf> wpa_supp: wlan0: SME: Trying to authenticate with fc:34:97:0b:f6:dc (SSID='OpenWrt' freq=5180)
    [00:01:49.368,438] <inf> wpa_supp: wlan0: Trying to associate with fc:34:97:0b:f6:dc (SSID='OpenWrt' freq=5180 MHz)
    [00:01:49.387,084] <inf> wpa_supp: wlan0: Associated with fc:34:97:0b:f6:dc
    [00:01:49.387,268] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
    [00:01:49.398,681] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with fc:34:97:0b:f6:dc [PTK=CCMP GTK=TKIP]
    [00:01:49.398,895] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to fc:34:97:0b:f6:dc completed [id=0 id_st]
    uart:~$ wifi twt setup 0 0 2 2 0 1 1 1 20000 100000 0
    TWT operation TWT setup with dg: 2, flow_id: 2 requested
    TWT response: TWT accept
    == TWT negotiated parameters ==
    TWT Dialog token: 2
    TWT flow ID: 0
    TWT negotiation type: TWT individual negotiation
    TWT responder: true
    TWT implicit: true
    TWT announce: true
    TWT trigger: true
    TWT wake interval: 19968 us
    TWT interval: 100000 us
    [00:01:52.413,513] <inf> net_dhcpv4: Received: 192.168.32.196
    uart:~$ net ping 8.8.8.8
    PING 8.8.8.8
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=1 ttl=54 time=130 ms
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=2 ttl=54 time=131 ms
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=3 ttl=54 time=133 ms
    PING 8.8.8.8
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=1 ttl=54 time=121 ms
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=2 ttl=54 time=124 ms
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=3 ttl=54 time=125 ms
    uart:~$ wifi twt tear
      teardown      teardown_all
    uart:~$ wifi twt teardown_all
    TWT teardown succeeded for flow ID 0
    TWT operation TWT teardown all flows success
    uart:~$ wifi twt setup 0 0 2 2 0 1 1 1 200000 1000000 0
    TWT response: TWT reject
    TWT Dialog token: 2
    TWT flow ID: 2
    TWT responder: false
    TWT implicit: true
    TWT announce: true
    TWT trigger: true
    TWT wake interval: 199680 us
    TWT interval: 1000000 us
    PING 8.8.8.8
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=1 ttl=54 time=64 ms
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=2 ttl=54 time=54 ms
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=3 ttl=54 time=66 ms
    PING 8.8.8.8
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=1 ttl=54 time=57 ms
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=2 ttl=54 time=59 ms
    28 bytes from 8.8.8.8 to 192.168.32.196: icmp_seq=3 ttl=54 time=141 ms
    I am using NCS v2.8.0, completely unchanged wifi/shell sample. Which access point are you using? It could be that the timing parameters given for TWT is problematic for the AP that you're using?
    Håkon
  • Hi, my ap is GliNet, system is from OpenWrt R22.3.3 (Powered by LuCI Master (git-22.060.11889-fb941f7) / OpenWrt R22.3.3).
    NCS v2.7.0
    under your help, i try to  find the problem
    I change the sixth parameter <trigger:0/1> to 0
    wifi twt setup 0 0 2 2 0 0 1 1 20000 100000 0
    that seems work well, but still some error in the log when i input the "wifi status":
    uart:~$ > wifi twt setup 0 0 2 2 0 0 1 1 20000 100000 0
    TWT Dialog token: 2
    TWT flow ID: 1
    TWT responder: true
    TWT implicit: true
    TWT announce: true
    TWT trigger: false
    wifi status
    Status: successful
    State: COMPLETED
    SSID: OpenWrt
    Band: 5GHz
    Channel: 36
    Security: WPA2-PSK
    MFP: Optional
    RSSI: -9999
    DTIM: 1
    TWT: Supported
    [00:08:29.909,057] <err> wifi_nrf: nrf_wifi_wpa_supp_signal_poll: Failed to get interface info, ret = -11
    [00:08:29.909,088] <err> wpa_supp: wpa_drv_zep_signal_poll: Signal polling failed: -1
    [00:08:29.909,820] <err> wpa_supp: Command failed: FAIL
    [00:08:29.909,851] <wrn> wpa_supp: z_wpa_supplicant_status:Failed to read RSSI
    uart:~$ > net ping 192.168.6.1
    PING 192.168.6.1
    28 bytes from 192.168.6.1 to 192.168.6.192: icmp_seq=1 ttl=64 time=12 ms
    28 bytes from 192.168.6.1 to 192.168.6.192: icmp_seq=2 ttl=64 time=11 ms
    28 bytes from 192.168.6.1 to 192.168.6.192: icmp_seq=3 ttl=64 time=12 ms
    uart:~$
  • Have you tried updating to OpenWrt 23.05 and see if the issue persists?
    Håkon
