nRF52832 Working as a Host
Previously, I used the nRF52840 to work as a host. Similarly now, I hope to use the nRF52832 to work as a host, but it seems that this cannot be achieved simply by changing the pri.conf file.
I am using the Beacon example, and my pri.conf file is as follows:
CONFIG_BT=y
CONFIG_LOG=y
CONFIG_BT_DEVICE_NAME="Test beacon"
CONFIG_BT_HCI=y
CONFIG_BT_CTLR=n
CONFIG_BT_H4=y
There is no overlay file created in my project.
However, the compiler is giving me the following error:
[109/172] Building C object zephyr/drivers/bluetooth/CMakeFiles/drivers__bluetooth.dir/hci/h4.c.obj
FAILED: zephyr/drivers/bluetooth/CMakeFiles/drivers__bluetooth.dir/hci/h4.c.obj
C:\ncs\toolchains\ce3b5ff664\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DNRF52832_XXAA -DPICOLIBC_LONG_LONG_PRINTF_SCANF -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -IC:/ncs/v2.7.0/zephyr/subsys/bluetooth -IC:/ncs/v2.7.0/zephyr/include -IC:/myapps/beacon_host_52832/build/zephyr/include/generated -IC:/ncs/v2.7.0/zephyr/soc/nordic -IC:/ncs/v2.7.0/zephyr/soc/nordic/nrf52/. -IC:/ncs/v2.7.0/zephyr/soc/nordic/common/. -IC:/ncs/v2.7.0/nrf/include -IC:/ncs/v2.7.0/nrf/tests/include -IC:/ncs/v2.7.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.7.0/zephyr/modules/cmsis/. -IC:/ncs/v2.7.0/modules/hal/nordic/nrfx -IC:/ncs/v2.7.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.7.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.7.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.7.0/modules/debug/segger/SEGGER -IC:/ncs/v2.7.0/modules/debug/segger/Config -IC:/ncs/v2.7.0/modules/crypto/tinycrypt/lib/include -IC:/ncs/v2.7.0/nrfxlib/softdevice_controller/include -isystem C:/ncs/v2.7.0/zephyr/lib/libc/common/include -Wshadow -fno-strict-aliasing -Os -imacros C:/myapps/beacon_host_52832/build/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=C:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/myapps/beacon_host_52832=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.7.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.7.0=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT zephyr/drivers/bluetooth/CMakeFiles/drivers__bluetooth.dir/hci/h4.c.obj -MF zephyr\drivers\bluetooth\CMakeFiles\drivers__bluetooth.dir\hci\h4.c.obj.d -o zephyr/drivers/bluetooth/CMakeFiles/drivers__bluetooth.dir/hci/h4.c.obj -c C:/ncs/v2.7.0/zephyr/drivers/bluetooth/hci/h4.c
In file included from C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/gcc.h:98,
                 from C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain.h:50,
                 from C:/ncs/v2.7.0/zephyr/include/zephyr/kernel_includes.h:23,
                 from C:/ncs/v2.7.0/zephyr/include/zephyr/kernel.h:17,
                 from C:/ncs/v2.7.0/zephyr/drivers/bluetooth/hci/h4.c:12:
C:/ncs/v2.7.0/zephyr/include/zephyr/device.h:91:41: error: '__device_dts_ord_DT_CHOSEN_zephyr_bt_uart_ORD' undeclared here (not in a function)
   91 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/common.h:137:26: note: in definition of macro '_DO_CONCAT'
  137 | #define _DO_CONCAT(x, y) x ## y
C:/ncs/v2.7.0/zephyr/include/zephyr/device.h:91:33: note: in expansion of macro '_CONCAT'
C:/ncs/v2.7.0/zephyr/include/zephyr/device.h:228:37: note: in expansion of macro 'DEVICE_NAME_GET'
  228 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
C:/ncs/v2.7.0/zephyr/include/zephyr/device.h:245:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
  245 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
C:/ncs/v2.7.0/zephyr/drivers/bluetooth/hci/h4.c:67:44: note: in expansion of macro 'DEVICE_DT_GET'
   67 | static const struct device *const h4_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_bt_uart));
[118/172] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\ce3b5ff664\opt\bin\cmake.EXE' --build 'c:\myapps\beacon_host_52832\build'
I want to know what the cause of this problem is and how to resolve it.
Additionally, I learned from the user manual that the UART pins of the nRF52832 development board can output at 3.3V. Currently, my development board's UART pins are outputting at 3V. I would like to know how to modify this in Zephyr.
