A short circuit between the SIM_1V8 pin and GND in nRF9160
I ordered my second prototype board with the nRF9160, which includes small changes compared to the previous version. I encountered an issue with LTE connectivity. After some checks and hardware verification, I noticed that the SIM card is not being supplied with power. During system startup and while attempting to connect to the network, a few microvolts appear briefly on the SIM_1V8 pin for a few milliseconds. It seems like the microcontroller is trying to power the SIM card.
After further investigation, I found that the nRF9160 chip has a short circuit between the SIM_1V8 pin and GND. I desoldered the microcontroller and confirmed that the short circuit is within the nRF9160 chip itself; the PCB is unaffected. In comparison, the short circuit does not occur in the previous prototype version, which worked well and connected to the network without issue.
I received two assembled prototypes, and both exhibit the same problem. However, the previous prototypes worked correctly, and the chip was able to connect to the network properly.
I’m wondering if there’s an option in the microcontroller that needs to be enabled to supply 1.8V to the SIM card?
The difference between the chips used in the prototypes is as follows:
  • Current prototypes: nRF9160 SICA B1 2230JF (with short circuit)
  • Previous prototypes: nRF9160 SICA B1 2231JU (working properly)
I am using:
  • SDK v2.5.1
  • nRF Toolchains v2.5.1
  • Modem MFW v1.3.6
  • Hello gkrusi,
    Didn't catch your comment and question until now. I don't know if you are working on the same HW or have a diifferent setup? I'd encourage you to create your own ticket here to track your issue.
    Best regards
    Asbjørn
  • Hello ,
    I'm not sure if this case is still open from your end. It seems to be added on by others now that are not necessarrily related to your case. If you still have further questions, may I suggest we put this case as "Private" to prevent others from cluttering your HW specific issues? We can return it to "public" after we've resolved your issue if that it what you'd like to.
    Best regards
    Asbjørn
  • Please do not have this thread moved to private.
    Yes we are 'hijacking' this specific case becuase others are experiencing the same issue with the same behaviour. We all want to know what a possible solution can be (that maybe can differ between design, but it is a start). By having this thread changed to private, it will be a sign of "bury your head in the sand".
    We are still investigating with or production partner if there is something that can be improved on their end (currently a new batch going into production).
    I'll leave this thread open and try to reply the best I can. Unfortunately soldering issues in prototype runs can be quite challenging as they may involved more manual steps that could change the behaviour of solder and equipement. The footprint of the nRF9160 is complex compared to regular QFN packages or WLCSP.
    My intention was not to bury it, just challenging to make sure the replies go to the right person.
    With shorts like you've seen here some of the items to check would be:
    1. Amount of solder applied, is it evenly applied? By machine or by hand?
    2. Visual inspection:
      1. Is the SIP mounted level? Can you confirm that the SIP is flat on the PCB?
      2. Compare the before solder situation across boards (ref point 1)
    3. Size of GND plane on the PCB and number of internal layers. If the GND plane is large it might radiate more heat and not warm up evenly on all PCBs. Some boards might be fine and then some located towards edge or of center from the heating source might not get the same temperature profile. It could be close, but distort the outcome. Again, this process is not unusual to be influence by human operators, but don't know the situation for each specific customer, but it's worth seeing if temperature is the same on all boards after the same time and also if a round of reheating/rework will clear up the issuess.
    4. Solder stencil used, thickness of it. Is the manufacturer familiar with such stencils, is it possible to change resolution or thickness to try to have more control of the solder applied. Does the stencil match up as it should or exptected?
    5. X-ray as to debug if possible, can you see shorts on the xray, are they in the same location on all boards or randomly located?
    I'm sure there are more steps as well, but the amount of solder, distribution of it and heating often comes up with variations in prototype builds.
    Best regards
    Asbjørn
