51822, config a pin as output , in the param , set disconnect or connect the input pin, when config as output ,what mean disconnct/connect input pin?
I use a pin to light a led, config a pin as output ,and connect the pin to a series resistance and a LED, the other side of the led is VDD(3V), when the GPIO is low,the LED is light, when the GPIO is high ,the LED is not bright. it can work, but a moment ,the chip is down, the current can reach 100mA, the chip is broken. I think the LED GPIO is the cause of this failure. How can I use the GPIO in this case?
GPIO_PIN_CONFIG(PIN_NO,
GPIO_PIN_CNF_DIR_Output,
GPIO_PIN_CNF_INPUT_Disconnect,
GPIO_PIN_CNF_PULL_Disabled,
GPIO_PIN_CNF_DRIVE_S0S1,
GPIO_PIN_CNF_SENSE_Disabled);
#define GPIO_PIN_CNF_INPUT_Connect #define GPIO_PIN_CNF_INPUT_Disconnect
