Partition map migratation from ncs 2.2 -> ncs 2.7 (sysbuild)
I have a firmware running on ncs 2.2 with mcuboot and tfm which I'm in the process of upgrading to ncs 2.7 with sysbuild.
I currently have a problem converting the pm_static.yml file from ncs 2.2 to ncs 2.7.
The first problem that occurred was fixed following this Thread
I'm able to build the application successfully on ncs 2.7 but the application will not start. It seems like the bootloader is placed at 0x8200 and not 0x0 while the application seems to be placed correctly at 0x30200 like the build on ncs 2.2.
If I use the partition manager for dynamic allocation the firmware boots fine and bootloader is placed at 0x0000 but the application is no longer placed at 0x30200 which I assume the bootloader from ncs 2.2 expects.
Looking at partition.yml from the dynamic allocation it looks like b0, b0_container, s0, s0_image, s0_pad , s1, s1_image and s1_pad is no longer used.
I don't have any clue on how to move forward with the migration.
I have attached the following files, which I had to change file type from yml to txt because yml file type seems to be blocked:
pm_static_2.2.txt <-- static file used on ncs 2.2
pm_static_2_7.txt <-- static file used on ncs 2.7 which build but seems to have bootloader placed at wrong address and doesn't boot application
partitions.txt <-- File from partition manager made dynamically on ncs 2.7 which boots the application successfully.
EMPTY_0:
  address: 0x14200
  end_address: 0x18000
  placement:
    before:
    - s1_pad
  region: flash_primary
EMPTY_1:
  address: 0x24200
  end_address: 0x28000
  placement:
    before:
    - mcuboot_pad
EMPTY_2:
  address: 0xfa000
  end_address: 0x100000
  placement:
    after:
    - settings_storage
EMPTY_3:
  address: 0xf6000
  end_address: 0xf8000
  placement:
    after:
    - nvs_storage
EMPTY_4:
  address: 0xe8000
  end_address: 0xf0000
  placement:
    after:
    - mcuboot_secondary
app:
  address: 0x30200
  end_address: 0x88000
app_image:
  address: 0x28200
  orig_span: &id001
  - tfm
  - app
  span: *id001
b0:
  address: 0x0
  end_address: 0x8000
  placement:
    after:
    - start
b0_container:
  address: 0x0
  end_address: 0x8000
  orig_span: &id002
  - b0
  span: *id002
mcuboot:
  address: 0x8200
  end_address: 0x14200
  placement:
    before:
    - mcuboot_primary
  sharers: 0x1
mcuboot_pad:
  address: 0x30000
  end_address: 0x30200
  placement:
    align:
      start: 0x8000
    before:
    - mcuboot_primary_app
  sharers: 0x2
mcuboot_primary:
  address: 0x28000
  orig_span: &id003
  - app
  - mcuboot_pad
  - tfm
  sharers: 0x1
  span: *id003
mcuboot_primary_app:
  address: 0x28200
  orig_span: &id004
  - app
  - tfm
  span: *id004
mcuboot_secondary:
  address: 0x88000
  end_address: 0xe8000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x8000
  share_size:
  - mcuboot_primary
nonsecure_storage:
  address: 0xf0000
  orig_span: &id005
  - settings_storage
  - nvs_storage
  span: *id005
nrf_modem_lib_ctrl:
  address: 0x20008000
  end_address: 0x200084e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - tfm_sram
    - start
  region: sram_primary
nrf_modem_lib_rx:
  address: 0x2000a4e8
  end_address: 0x2000c4e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - nrf_modem_lib_tx
nrf_modem_lib_sram:
  address: 0x20008000
  orig_span: &id006
  - nrf_modem_lib_ctrl
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id006
nrf_modem_lib_tx:
  address: 0x200084e8
  end_address: 0x2000a4e8
  inside:
  - sram_nonsecure
  placement:
    after:
nvs_storage:
  address: 0xf0000
  end_address: 0xf6000
  inside:
  - nonsecure_storage
  placement:
    align:
      start: 0x8000
    before:
    - settings_storage
otp:
  address: 0xff8388
  end_address: 0xff83fc
  region: otp
provision:
  address: 0xff8108
  end_address: 0xff8388
  region: otp
s0:
  address: 0x8000
  orig_span: &id007
  - s0_pad
  - mcuboot
  span: *id007
s0_image:
  address: 0x8200
  orig_span: &id008
  - mcuboot
  span: *id008
s0_pad:
  address: 0x8000
  end_address: 0x8200
  placement:
    after:
    - b0_container
    align:
      start: 0x8000
  share_size:
  - mcuboot_pad
s1:
  address: 0x18000
  end_address: 0x24200
  orig_span: &id009
  - s1_pad
  - s1_image
  span: *id009
s1_image:
  address: 0x18200
  placement:
    after:
    - s1_pad
    - s0
  share_size:
  - mcuboot
s1_pad:
  address: 0x18000
  end_address: 0x18200
  placement:
    after:
    - s0
    align:
      start: 0x8000
  share_size:
  - mcuboot_pad
settings_storage:
  address: 0xf8000
  end_address: 0xfa000
  inside:
  - nonsecure_storage
  placement:
    align:
      start: 0x8000
    before:
    - end
sram_nonsecure:
  address: 0x20008000
  end_address: 0x20040000
  orig_span: &id010
  - sram_primary
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id010
sram_primary:
  address: 0x2000c4e8
sram_secure:
  address: 0x20000000
  end_address: 0x20008000
  orig_span: &id011
  - tfm_sram
  span: *id011
tfm:
  address: 0x28000
  end_address: 0x30000
  inside:
  placement:
    before:
    - app
tfm_nonsecure:
  address: 0x30000
  end_address: 0x87E00
  orig_span: &id012
  - app
  span: *id012
tfm_secure:
  address: 0x28000
  orig_span: &id013
  - mcuboot_pad
  - tfm
  span: *id013
tfm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
EMPTY_0:
  address: 0xc000
  placement:
    before:
    - mcuboot_pad
EMPTY_1:
  address: 0xfa000
  placement:
    after:
    - settings_storage
EMPTY_2:
  address: 0xf6000
  placement:
    after:
    - nvs_storage
app:
  address: 0x18000
  end_address: 0x80000
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x10000
  end_address: 0x10200
  placement:
    align:
      start: 0x8000
    before:
mcuboot_primary:
  address: 0x10000
  orig_span: &id001
  - mcuboot_pad
  - tfm
  - app
  sharers: 0x1
  span: *id001
  address: 0x10200
  orig_span: &id002
  - app
  - tfm
  span: *id002
mcuboot_secondary:
  address: 0x80000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x8000
  share_size:
  - mcuboot_primary
mcuboot_sram:
  address: 0x20000000
  orig_span: &id003
  - tfm_sram
  span: *id003
nonsecure_storage:
  address: 0xf0000
  orig_span: &id004
  - settings_storage
  - nvs_storage
  span: *id004
nrf_modem_lib_ctrl:
  address: 0x20008000
  inside:
  - sram_nonsecure
  placement:
    after:
    - tfm_sram
    - start
nrf_modem_lib_rx:
  address: 0x2000a568
  end_address: 0x2000c568
  inside:
  - sram_nonsecure
  placement:
    after:
    - nrf_modem_lib_tx
nrf_modem_lib_sram:
  address: 0x20008000
  orig_span: &id005
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id005
nrf_modem_lib_tx:
  address: 0x200084e8
  end_address: 0x2000a568
  inside:
  - sram_nonsecure
  placement:
    after:
nvs_storage:
  address: 0xf0000
  inside:
  - nonsecure_storage
  placement:
    align:
      start: 0x8000
    before:
    - settings_storage
otp:
  address: 0xff8108
  region: otp
settings_storage:
  address: 0xf8000
  inside:
  - nonsecure_storage
  placement:
    align:
      start: 0x8000
    before:
    - end
sram_nonsecure:
  address: 0x20008000
  orig_span: &id006
  - sram_primary
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id006
sram_primary:
  address: 0x2000c568
sram_secure:
  address: 0x20000000
  orig_span: &id007
  - tfm_sram
  span: *id007
tfm:
  address: 0x10200
  inside:
  placement:
    before:
    - app
tfm_nonsecure:
  address: 0x18000
  orig_span: &id008
  - app
  span: *id008
tfm_secure:
  address: 0x10000
  orig_span: &id009
  - mcuboot_pad
  - tfm
  span: *id009
tfm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
EMPTY_0:
  address: 0x14200
  placement:
    before:
    - s1_pad
EMPTY_1:
  address: 0x24200
  placement:
    before:
    - mcuboot_pad
EMPTY_2:
  address: 0xfa000
  placement:
    after:
    - settings_storage
EMPTY_3:
  address: 0xf6000
  placement:
    after:
    - nvs_storage
EMPTY_4:
  address: 0xe8000
  placement:
    after:
    - mcuboot_secondary
app:
  address: 0x30200
app_image:
  address: 0x28200
  orig_span: &id001
  - tfm
  - app
  span: *id001
b0:
  address: 0x0
  end_address: 0x8000
  placement:
    after:
    - start
b0_container:
  address: 0x0
  end_address: 0x8000
  orig_span: &id002
  - b0
  span: *id002
mcuboot:
  address: 0x8200
  placement:
    before:
    - mcuboot_primary
  sharers: 0x1
mcuboot_pad:
  address: 0x28000
  end_address: 0x28200
  placement:
    align:
      start: 0x8000
    before:
  sharers: 0x2
mcuboot_primary:
  address: 0x28000
  orig_span: &id003
  - app
  - mcuboot_pad
  - tfm
  sharers: 0x1
  span: *id003
  address: 0x28200
  orig_span: &id004
  - app
  - tfm
  span: *id004
mcuboot_secondary:
  address: 0x88000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x8000
  share_size:
  - mcuboot_primary
nonsecure_storage:
  address: 0xf0000
  orig_span: &id005
  - settings_storage
  - nvs_storage
  span: *id005
nrf_modem_lib_ctrl:
  address: 0x20008000
  inside:
  - sram_nonsecure
  placement:
    after:
    - tfm_sram
    - start
nrf_modem_lib_rx:
  address: 0x2000a4e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - nrf_modem_lib_tx
nrf_modem_lib_sram:
  address: 0x20008000
  orig_span: &id006
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id006
nrf_modem_lib_tx:
  address: 0x200084e8
  inside:
  - sram_nonsecure
  placement:
    after:
nvs_storage:
  address: 0xf0000
  inside:
  - nonsecure_storage
  placement:
    align:
      start: 0x8000
    before:
    - settings_storage
otp:
  address: 0xff8388
  region: otp
provision:
  address: 0xff8108
  region: otp
s0:
  address: 0x8000
  orig_span: &id007
  - s0_pad
  - mcuboot
  span: *id007
s0_image:
  address: 0x8200
  orig_span: &id008
  - mcuboot
  span: *id008
s0_pad:
  address: 0x8000
  end_address: 0x8200
  placement:
    after:
    - b0_container
    align:
      start: 0x8000
  share_size:
  - mcuboot_pad
s1:
  address: 0x18000
  orig_span: &id009
  - s1_pad
  - s1_image
  span: *id009
s1_image:
  address: 0x18200
  placement:
    after:
    - s1_pad
    - s0
  share_size:
  - mcuboot
s1_pad:
  address: 0x18000
  placement:
    after:
    - s0
    align:
      start: 0x8000
  share_size:
  - mcuboot_pad
settings_storage:
  address: 0xf8000
  inside:
  - nonsecure_storage
  placement:
    align:
      start: 0x8000
    before:
    - end
sram_nonsecure:
  address: 0x20008000
  orig_span: &id010
  - sram_primary
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id010
sram_primary:
  address: 0x2000c4e8
sram_secure:
  address: 0x20000000
  orig_span: &id011
  - tfm_sram
  span: *id011
tfm:
  address: 0x28200
  inside:
  placement:
    before:
    - app
tfm_nonsecure:
  address: 0x30200
  orig_span: &id012
  - app
  span: *id012
tfm_secure:
  address: 0x28000
  orig_span: &id013
  - mcuboot_pad
  - tfm
  span: *id013
tfm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
  • Update: Setting SB_CONFIG_SECURE_BOOT_APPCORE=y in sysbuild.conf helped including the nordic secure immutable bootloader however mcuboot still seems to fail at boot
    *** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
    *** Using Zephyr OS v3.6.99-100befc70c74 ***
    Attempting to boot slot 0.
    Attempting to boot from address 0x8200.
    Verifying signature against key 0.
    Hash: 0x77...5f
    Firmware signature verified.
    Firmware version 1
    Setting monotonic counter (version: 1, slot: 0)
    *** Booting MCUboot v2.1.0-dev-daf2946a0f07 ***
    *** Using nRF Connect SDK v2.7.0-5cb85570ca43 ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    W: Failed reading image headers; Image=0
    I: Image index: 1, Swap type: none
    E: Image in the primary slot is not valid!
    E: Unable to find bootable image
    One thing i notice is that if I add the merged.hex to nRF Desktop Programmer it looks like the app layer is placed from 0x27e00 and I assume it would be from 0x28000
  • I tried to add the following code before the warning line
    struct image_header *out_hdr = boot_img_hdr(state, 0);
    uint32_t load_addr = out_hdr->ih_load_addr;
    BOOT_LOG_INF("Image header: %d", load_addr);
    And the output was
    I: Image header: 165481 <-- 0x28669
    Should image header be placed from the very first byte of the application?
  • For anyone interested this was the solution
    EMPTY_0:
      address: 0x14200
      placement:
        before:
        - s1_pad
    EMPTY_1:
      address: 0x24200
      placement:
        before:
        - mcuboot_pad
    EMPTY_2:
      address: 0xfa000
      placement:
        after:
        - settings_storage
    EMPTY_3:
      address: 0xf6000
      placement:
        after:
        - nvs_storage
    EMPTY_4:
      address: 0xe8000
      placement:
        after:
        - mcuboot_secondary
    app:
      address: 0x30000
    app_image:
      address: 0x28200
      orig_span: &id001
      - tfm
      - app
      span: *id001
    b0:
      address: 0x0
      end_address: 0x8000
      placement:
        after:
        - start
    b0_container:
      address: 0x0
      end_address: 0x8000
      orig_span: &id002
      - b0
      span: *id002
    mcuboot:
      address: 0x8200
      placement:
        before:
        - mcuboot_primary
      sharers: 0x1
    mcuboot_pad:
      address: 0x28000
      placement:
        align:
          start: 0x8000
        before:
      sharers: 0x2
    mcuboot_primary:
      address: 0x28000
      orig_span: &id003
      - mcuboot_pad
      - app
      - tfm
      sharers: 0x1
      span: *id003
      address: 0x28200
      orig_span: &id004
      - app
      - tfm
      span: *id004
    mcuboot_secondary:
      address: 0x88000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x8000
      share_size:
      - mcuboot_primary
    mcuboot_sram:
      address: 0x20000000
      orig_span: &id005
      - tfm_sram
      span: *id005
    nonsecure_storage:
      address: 0xf0000
      orig_span: &id006
      - settings_storage
      - nvs_storage
      span: *id006
    nrf_modem_lib_ctrl:
      address: 0x20008000
      inside:
      - sram_nonsecure
      placement:
        after:
        - tfm_sram
        - start
    nrf_modem_lib_rx:
      address: 0x2000a568
      inside:
      - sram_nonsecure
      placement:
        after:
        - nrf_modem_lib_tx
    nrf_modem_lib_sram:
      address: 0x20008000
      orig_span: &id007
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id007
    nrf_modem_lib_tx:
      address: 0x200084e8
      inside:
      - sram_nonsecure
      placement:
        after:
    nvs_storage:
      address: 0xf0000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - settings_storage
    otp:
      address: 0xff8388
      region: otp
    provision:
      address: 0xff8108
      region: otp
    s0:
      address: 0x8000
      orig_span: &id008
      - mcuboot
      - s0_pad
      span: *id008
    s0_image:
      address: 0x8200
      orig_span: &id009
      - mcuboot
      span: *id009
    s0_pad:
      address: 0x8000
      end_address: 0x8200
      placement:
        after:
        - b0_container
        align:
          start: 0x8000
      share_size:
      - mcuboot_pad
    s1:
      address: 0x18000
      orig_span: &id010
      - s1_pad
      - s1_image
      span: *id010
    s1_image:
      address: 0x18200
      placement:
        after:
        - s1_pad
        - s0
      share_size:
      - mcuboot
    s1_pad:
      address: 0x18000
      placement:
        after:
        - s0
        align:
          start: 0x8000
      share_size:
      - mcuboot_pad
    settings_storage:
      address: 0xf8000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - end
    sram_nonsecure:
      address: 0x20008000
      orig_span: &id011
      - sram_primary
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id011
    sram_primary:
      address: 0x2000c568
    sram_secure:
      address: 0x20000000
      orig_span: &id012
      - tfm_sram
      span: *id012
    tfm:
      address: 0x28200
      inside:
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x30000
      orig_span: &id013
      - app
      span: *id013
    tfm_secure:
      address: 0x28000
      orig_span: &id014
      - mcuboot_pad
      - tfm
      span: *id014
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
