[ nRF52833 ] How to set Non-Connectable Advertizing using Advertising Library / Module
In my experimentation to update advertising data during runtime, I am following the example @
 How to update advertising data dynamically using BLE Advertising library
It is using the ble_advertising.h library module
However I would like to set this advertising to non-connectable, non-scannable and non directed mode similar to
static ble_gap_adv_params_t m_adv_params;
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
However, the data structure used for the advertising module
ble_advertising_init_t init;
does not provide any provision to set the non connectable mode.
May be the init.advdata.flags could be set ?  But does it have the values that I can set to non-connectable
Very similar question has already been asked previously but still open
 How to set non-connectable mode in BLE
Can you please guide here ?
Abhi Ash
  • Hi Hung,
    Thanks for your response.
    My requirement is just sending out advertisements in non-connectable mode only. Connectable would be never needed.
    I have tried and used the beacon example however it directly uses the gap API and not the advertising library.
    I need to dynamically change the beacon contents.
    I inserted the line below in both fast and slow adv init functions
    p_adv_params->properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    However, sniffing the packet using the nRF Sniffer, the PDU Type is still shown as ADV_IND.
    and when I observe in the nRFConnect Android App, I can see the CONNECT option besides.
    May be something is still missing or going wrong
    Thanks
    Abhishek
  • Please attach your code where you do the modification.
    I don't see a problem modifying the beacon example to stop advertising, update the advertising content and continue advertising.
  • I reviewed my code once more.
    I was setting it at the beginning of the function and it was getting overwritten.
    It should be like given below
    // p_advertising->adv_params.properties.type =                BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    It works now and shows ADV_NONCONN_IND
    Thanks again,
    Abhi Ash
