[ nRF52833 ] How to set Non-Connectable Advertizing using Advertising Library / Module
In my experimentation to update advertising data during runtime, I am following the example @
 How to update advertising data dynamically using BLE Advertising library
It is using the ble_advertising.h library module
However I would like to set this advertising to non-connectable, non-scannable and non directed mode similar to
static ble_gap_adv_params_t m_adv_params;
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
However, the data structure used for the advertising module
ble_advertising_init_t init;
does not provide any provision to set the non connectable mode.
May be the init.advdata.flags could be set ?  But does it have the values that I can set to non-connectable
Very similar question has already been asked previously but still open
 How to set non-connectable mode in BLE
Can you please guide here ?
Abhi Ash
  • Hi Abhi,
    For doing non-connectable advertising, it's suggested to use the softdevice APIs directly, similar to what in the ble_app_beacon example. You can configure advertising using sd_ble_gap_adv_set_configure() and start advertising using sd_ble_gap_adv_start().
    If you want to use the ble_advertising library, you would need to modify the library to support non-connectable mode.
  • Hi Hung Bui,
    My requirement is to update the contents of beacon (non-connectable) dynamically and how can we implement this using only softdevice APIs ( i.e. without using the advertising library )?
    "If you want to use the ble_advertising library, you would need to modify the library to support non-connectable mode. "
    How is this possible for a normal user ?  Some are SV calls. Is it ok to modify the ble_advdata_t  ?  i.e. allow more values to the .flags ? Currently it uses values from ble_gap.h
    #define BLE_GAP_ADV_FLAG_LE_LIMITED_DISC_MODE (0x01) /**< LE Limited Discoverable Mode. */
    #define BLE_GAP_ADV_FLAG_LE_GENERAL_DISC_MODE (0x02) /**< LE General Discoverable Mode. */
    #define BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED (0x04) /**< BR/EDR not supported. */
    #define BLE_GAP_ADV_FLAG_LE_BR_EDR_CONTROLLER (0x08) /**< Simultaneous LE and BR/EDR, Controller. */
    #define BLE_GAP_ADV_FLAG_LE_BR_EDR_HOST (0x10) /**< Simultaneous LE and BR/EDR, Host. */
    #define BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE (BLE_GAP_ADV_FLAG_LE_LIMITED_DISC_MODE | BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED) /**< LE Limited Discoverable Mode, BR/EDR not supported. */
    #define BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE (BLE_GAP_ADV_FLAG_LE_GENERAL_DISC_MODE | BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED) /**< LE General Discoverable Mode, BR/EDR not supported. */
    Abhi Ash
    I don't see any reason you can't change the content of the beacon with the Softdevice APIs.
    Please be aware that the ble_advertising is just a firmware library, it uses the Softdevice APIs to do advertising.
    You are free to modify the ble_advertising to do what you want. You can't change the SVC call, but you don't have to.
    As I said, you can simply call sd_ble_gap_adv_stop() to stop the advertising, then change the advertising configuration/data with sd_ble_gap_adv_set_configure() then start advertising again using sd_ble_gap_adv_start()
    In ble_advertising.c,  I have added the line below in both ble_advertising_init() and ble_advertising_start() functions however I still see the adverizement type as ADV_IND
     p_advertising->adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    Can you please guide regarding where exactly the change needs to be made to make the advertising non connectable ?
    Regards
    Abhi Ash
  • Hi AbhiAsh,
    You would need to change it in set_adv_mode_fast(), set_adv_mode_slow() as well.
    But I don't see the point of modifying it if you only want to do beaconing. Unless you want to support both switching between connectable and non-connectable.
    Have you looked at the beacon example we have ?
