Is there an option (on cofig files etc.) to set it true for echoing what I typed on Serial LTE Modem firmware application?
Which serial terminal are you using to interface with the nRF9160?
I am not an expert in our cellular solutions, but a local echo seems more dependant on the serial terminal used than the application running on the board.
The Serial Terminal application available through nRF Connect for Desktop is using local echo by default.
Maria
Let's say tio. There is an echo on modem shell but not on slm.
The reason for the lack of echo in the SLM application is that CONFIG_SHELL is disabled in the application. For the Modem Shell sample, CONFIG_SHELL is enabled, which again enables CONFIG_SHELL_ECHO_STATUS by default.
So you will need to add shell functionality to the SLM application to get the functionality you want. CONFIG_SHELL_ECHO_STATUS should be enabled by default, but if it is not you can enable it manually.
Maria
Ok I've added CONFIG_SHELL but now I have another problem now:
normally my uarts were:
chosen {
ncs,slm-ppp-uart = &uart0;
ncs,slm-uart = &uart1;
chosen {
zephyr,shell-uart = &uart1;
[Sec Thread] Secure image initializing! TF-M Float ABI: Hard Lazy stacking enabled Booting TF-M v2.0.0 FATAL ERROR: SecureFault FATAL ERROR: HardFault
chosen {
For the referance this line of modem_shell firmware application does it: github.com/.../at_cmd_mode.c
