I am following DevAcademy Lesson 5, HTTP over Wi-Fi (Exercise 2), which involves adding TLS to an HTTP connection.
When I remove CONFIG_WPA_SUPP_CRYPTO_PSA=y
, I am able to successfully build the code for nrf7002dk_nrf5340_cpuapp
Will removing this configuration affect HTTP functionality?
Additionally, with CONFIG_MBEDTLS_RSA_C=y
enabled, I receive the following warning:
CONFIG_MBEDTLS_RSA_C was assigned the value y, but got the value n. Missing dependencies: NET_L2_OPENTHREAD || ((PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY || !MBEDTLS_USE_PSA_CRYPTO) && MBEDTLS_LEGACY_CRYPTO_C && NRF_SECURITY)
below is prj.conf file
# Wi-Fi
CONFIG_WIFI=y
CONFIG_WIFI_NRF700X=y
CONFIG_WPA_SUPP=y
# CONFIG_WPA_SUPP_CRYPTO_PSA=y
# Wi-Fi Credentials
CONFIG_WIFI_CREDENTIALS=y
CONFIG_WIFI_CREDENTIALS_STATIC=n
# Networking Management API
CONFIG_NET_MGMT=y
CONFIG_NET_MGMT_EVENT=y
CONFIG_NET_MGMT_EVENT_INFO=y
CONFIG_NET_MGMT_EVENT_STACK_SIZE=4096
CONFIG_NET_CONNECTION_MANAGER=y
CONFIG_WIFI_MGMT_EXT=y
# Support for shell commands
CONFIG_SHELL=y
CONFIG_WIFI_CREDENTIALS_SHELL=y
CONFIG_SHELL_STACK_SIZE=4400
# Logging
CONFIG_LOG=y
# DK library
CONFIG_DK_LIBRARY=y
# System settings
CONFIG_NEWLIB_LIBC=y
CONFIG_NEWLIB_LIBC_NANO=n
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_POSIX_MAX_FDS=16
CONFIG_NET_L2_ETHERNET=y
CONFIG_NET_IPV4=y
CONFIG_NET_IPV6=y
CONFIG_NET_TCP=y
CONFIG_NET_DHCPV4=y
CONFIG_DNS_RESOLVER=y
# TLS
# STEP 1.1 - Enable the TLS library and security relevant configurations
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
CONFIG_TLS_CREDENTIALS=y
CONFIG_MBEDTLS_DHM_C=y
# STEP 1.2 - Enable support for server name indication (SNI)
CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION=y
# Memory
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=153600
CONFIG_NET_TCP_WORKQ_STACK_SIZE=2048
CONFIG_NET_TX_STACK_SIZE=4096
CONFIG_NET_RX_STACK_SIZE=4096
CONFIG_NET_BUF_RX_COUNT=16
CONFIG_NET_BUF_TX_COUNT=16
CONFIG_NET_BUF_DATA_SIZE=256
CONFIG_NET_TC_TX_COUNT=0
# HTTP
CONFIG_HTTP_CLIENT=y
# For storing Wi-Fi credentials
CONFIG_WIFI_CREDENTIALS_BACKEND_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS=y
CONFIG_NET_L2_WIFI_SHELL=y
